Question about Konica Minolta Di3010 Di3010f Drum Unit Type 305
Change pc drum konica minolta di3010f
Can the counter be reset or does the drum need to be replaced? How hard is that?
  • 118 Answers
SOURCE: Konica Minolta Magicolor 2400W drum cartrige-how to replace?
Did you buy a whole new drum unit, or just change the cartridge? If so, the fuse may still be blown. Also, you may need to empty the spent toner out of the old cartridge.
Posted on Nov 18, 2008
SOURCE: in minolta bizhub 350 pc drum change
Two Options:
1) Reset the PC/life; I/C Life and DV counter and run F8.
2) The same than before but change the PC drum.
by : George Rivas ( OSI )
Posted on Apr 15, 2009
  • 192 Answers
SOURCE: After replacing black toner cartridge printer displays Drum Low
Ask you companey that surives you printer to look at it
Posted on May 20, 2009
SOURCE: error c2557 konica minolta 250/NEC IT2530
Reset it, start it with the right door open, go to service mode, clear the counters for drum and developer and go to functions menu. Close the right door and start immediately the F8 function. It should work.
Posted on Aug 23, 2009
SOURCE: Can I reset the drum counter for a Konica Minolta
The best way to reset the counter is to replace the fuse on the underside of the printer drum. That is not hard to do, but you have to be careful not to break the plastic tabs holding the original fuse in place.
Posted on Mar 29, 2010
Konica minolta 185 m2
Clear the counters for drum and developer, Replace the drum and developer, run required process, done, Do not reset without replacing because copier uses the counter if you reset without replace code and image problems will begin. Because copier will think drum and developer are new when in fact there are not and voltages set for new will be working on old stuff.
May 26, 2016 | Konica Minolta Office Equipment & Supplies
Konica minolta bizhub 195 shows M2 error after changing the developer how to reset M2 error?
Did you also replace the drum, clear the developer counter first before installing the developer, and run the required F 8 procedure after the developer was installed, As the machine uses the counter to control voltages to certain assemblies, not replacing the parts and resetting the counter will cause codes and image issues.
Jan 19, 2016 | Konica Minolta bizhub Office Equipment &...
Monolta izhub 362 hwo to reset drum counter
Bh 362 is the upgrade of Bh 200, 250 and 350 and on that model you need change drum and developer together. The drum counter message can be reset in service mode by a qualified tech after replacing those parts.
Aug 23, 2014 | Konica Minolta Bizhub 362 Copier
Reset konica drum counter
has it been replaced???????????????????????/
Has the drum been replaced? If not reset code for drum without replacing the drum is not good. Because the copier works based on the counters. If you reset the counters without replacing the require items, then the copier will adjust certain voltages to certain items such as the drum as those it is new because you reset the counters when in fact the drum is old and so you might be codes and image problems.
Feb 13, 2014 | Konica Minolta Office Equipment & Supplies
Drum konica minolta 250
Bizhub 250
The drum part number is 4068612. You need to replace developer at the same time, 8938451. You also need to go into service mode and reset the counters and run an f8 after parts are replaced.
Jan 28, 2014 | Konica Minolta bizhub Office Equipment &...
Error replace drum unit konica minolta 190
You dont!!!! You replace the developer and the drum
Dec 17, 2013 | Konica Minolta Office Equipment & Supplies
In Konica Minolta bizhub 362 it says ready to copy but I noticed it says "please change PC drum"
Thecopier has a counter the drum unit. "PC" means photo conductor, I don't remember if the copier will lock up if the drum unit is not replaced? There is a counter that needs to be reset once the drum & new developer is installed.
Jul 19, 2011 | Office Equipment & Supplies
NEED TO RESET THE DRUM LIFE AND STARTER . NEED THE PROCEDURE TO RESET THESE WARNINGS
Unfortunately The minds at Konica Minolta have figured out how to make the machine Inoperable if you reset the drum and or developer counters, the only way to reset the "change drum" condition on a Biz 350 is to replace the drum AND the developer and calibrate them both when you do it automatically resets the counters... sorry.
Sep 29, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Can I reset the drum counter for a Konica Minolta 2300?
Mar 10, 2010 | Konica Minolta magicolor 2300DL Laser...
In minolta bizhub 350 pc drum change
Two Options:
Feb 23, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta Di3010 Di3010f Drum Unit Type 305 Logo
41 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
