Question about Frigidaire MWS939Z Top Load Washer
How do I fix my leaking washer machine
I noticed my washer was leaking from the bottom, so I took the front panel off and pin-pointed the problem. It is coming from some kind of a seal I believe, but the leak is at the bottom of the tub where the spinning deal that spins the tub connects to the tub. So can I fix the problem with just some hand tools at home or do I need to call a profesional, or better yet is it fixable? And how?
Thank you! I just discovered the exact same problem with my 18 year old machine tonight. You saved me the cost of a service call from the plumber. I will go straight to the appliance store tomorrow and just buy a new one. Many thanks for saving me time and money.
Posted on Feb 11, 2008
    President:
  • 331 Answers
Lost, I'm afraid that the tub seal/bearing assy. is an extremely complex repair and should be referred to a pro. Not only for the reason of complexity, but they'll also put a warranty on their work. Now there IS a bright side to this if the unit is less than 5 years old. The transmission and seals have a 5 year warranty! You won't need your original proof of purchase/receipt. You will need your full model number and serial number, though. Then go to this site, http://www.frigidaire.com/support/support.asp and contact them. If your unit is more than 5 years old? Well, I advise my customers to replace the washer. Simply because the cost of the repair will far outweigh the overall value of the machine. Think of it this way... if your washer were in perfect condition at its' current age and you decided to sell it. What would you be able to sell it for? $125.00 max? This number should be the limit you'd be willing to spend for repairs. If you decide to replace it, look at the Whirlpool built units. Even the used ones are better made than the Frigidaire units. Hope this helps.
Posted on Oct 08, 2007
SOURCE:
The washer started making a noise about a month ago, kind of like change rattling in the bottom of the machine. Today the machine leaked water all over the laundry room and down the hall. It didn't come...
sounds like the water pump, is leaking or the rubber hose from the drum to the pump. its very hard for money to get thru the filter holes, of the drum to the pump
Dec 19, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Water leaking from the bottom of washer
I had this problem the other week we turned the machine around and took off the water hose got to the water pump and found 5cents, hair pins, badges ect in there once cleaned out and put back together worked great again and no more leaks!
Apr 26, 2010 | KitchenAid KAWS850L Top Load Washer
I have a maytag 6800 toploader. Water from bottom
If you feel OK to troubleshoot the Service Manual will give you some possible leak points to check. If you want to troubleshoot you beyond basic inspection you will need to remove the front panel and observe where the leak source might be. Worse case a tub seal issue. Easier fix would be a leak in the drain line; tub to drain pump/drain pump to output drain hose, one poster recently reported a cracked drain pump housing as their leak source. Here is a link for the manual.
http://www.fixya.com/support/r1655507-found_service_manual_neptune_top_load
The one leak source I would be concerned with is a leak described around the clutch pulley on page 28. If that is your leak source it’s a big project and you may need think about a service repair (BIG$ for labor but see if you can get a no cost quote) or a replacement machine if it’s not cost effective to repair. If you go the replacement direction call the Maytag CSV phone number at the end of the manual and complain, I got them to offer up a 25% rebate by talking to a supervisor on their Whirlpool, Amana, Maytag product line (don’t shoot the messenger). I’m a DIY’er and if I can’t fix this thing for under $300 with ebay parts I would move on. But let’s go one step at a time and try to ID the leak source.
To help you remove the front panel see page 33 Pic for the putty knife insertion point to raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base.
See page 41 for front panel removal don’t poke around in there with the power on just view for a water leak with a flash light while the machine fills in a Quick Wash cycle and as the machine proceeds through the wash cycle. Safety first, please follows the safety guide lines in the SM. Post again if you have questions and I’m sure I or other forum members will chime in for support. Good Luck.
Mar 04, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Water leaking from the bottom of the washer at the rear right corner!
firstly check that the inflow water pipes connected to the machine are connected correctly, feel around the pipes that touch the machine to see if there is any water. If there is the washers may need replacing on the pipe. Or the pipe may simply have got a bit loose through the machines spinning.
Oct 20, 2008 | GE Energy Star WCVH6260F Front Load Washer
Shock absorbers are broken
just buy the new shocks(should by pair)I know they had 2 way one they have pin anoter kind they have clip lock to the bottom of the sheet metal(push the clip lock on both side of the shock and turn c/cw.good luck
Sep 25, 2008 | GE WSXH208A Front Load Washer
Amana Distinction leaks
this is a very common probelm with AM washer you have a bad upper sping bearing and at this point you need to cut your loses and send this one to the washer graveyard because this repair in labor intense
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Jun 01, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Amana washer leaking.
Have your husband disconnect the power and water lines, pull the washer out and tip it back so he can check the hose connections to the water drain pump in the bottom of the washer. That pump should have two hose connections. In older machines, it is entirely possible that a hose has either come loose or cracked. If the hoses appear fine, check the pump itself for possible cracks. If all looks well, check the hose clamps for tightness.
Feb 23, 2008 | Amana ALW880WH Top Load Washer
Amana NAV5800 - How do I take off the lid/cover
Jon,
There should be two screws at the bottom of the front panel. Undo these screws and the bottom of the panel should swing out. The top will be held by clips or pins that will release as the bottom of the panel moves out. I suggest you lay a folded towel on the floor to prevent chipping the enamel finish when the panel drops free.
By the way, please ensure the machine is unplugged before you attempt any work on electric appliances.
Good luck
Bob Thompson (Australia)
Dec 22, 2007 | Amana NAV5800A Top Load Washer
Pin hole leak in metal under dishwasher
difficult to weld stainloess steel. another way is to drill out the hole slightly and fit a small nut and bolt with fibre washers
Apr 12, 2007 | KitchenAid 24 in. KUDI02CR Built-in...
Frigidaire MWS939Z Top Load Washer Logo
87 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
