Question about Kenmore Magic Blue 24195 Bagged Canister Vacuum
Need to replace carbon brushes for kenmore magic blue vacuum
3 Suggested Answers
Kazong
  • 152 Answers
SOURCE: roller brush of vacuum not rotating
u might need 2 change the belt on the attachement there r 2 screws on top take em out after u take off cover there is a plastic cover over the belt take off c if the belt broke the rest is easy
Posted on Mar 02, 2008
johncaman
  • 201 Answers
SOURCE: filters on Kenmore Magic Blue vacuum cleaner
Yes, you do... only the 'motor protection filter' in the bag compartment is meant to be user cleaned.
Here's a manual, with a parts diagram near the end, if it's of use.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0408631.pdf
Please rate if this helps :)
Posted on Mar 05, 2009
I need a new floor attachment for my magic blue.
I need new floor head for my kenmore magic blue, where i can buy?
Jan 18, 2010 | Kenmore Magic Blue 24195 Bagged Canister...
Vacuum shrinks, power is still on but no suction
perhaps there is something stuck in the vacuum. Look where the hose fits in. There is obvioulsy no blockage in the hose because you have suction. Do the power brushes spin on the vacuum?? Take the bag off, and inspect the area the bag fits in for blockage.
Jer
Jan 16, 2010 | Kenmore Magic Blue 24195 Bagged Canister...
How to change carbon brushes
You need to know that very seldom will new carbon brushes alone `FIX`a motor in todays vacuums as they are higher RPM than those of 30 years ago.
On a salvageable motor a good rebuild procedure will generally include repacking bearings, cleaning suction fans and reseating new brushes with an abrasive seating stone at low speed with a motor run in device with variable voltage
That said, I have not done a HENRY in years but it likely will contain a generic AMTEK Lamb type motor as it is sold as more durable vac.
On a traditional vac motor, carbon brushes are removed by releasing a clamp over the brush. The brush holder will have either a flag terminal on it where the wiring will disconnect from the side, or a flat flag terminal which slides into a pocket on the carbon brush housing.
. If you are going to the trouble of replacing the brushes, remove and inspect the old ones for wear and chipping. Also inspect the commutator surface on the motor where the brushes contact. If there are any curved gaps between segments, or if the com is worn like an apple core , you need a motor complete.
If the motor has simply worn to the point where a brush has stuck or worn to nothing, you may be bale to reseat the new brushes, however any evidednce of BLUE sparks or noise is not a good sign . Best of luck. Post back if you need more help
Nov 01, 2009 | Henry Numatic "" Canister Vacuum
Can I buy a replacement powerhead for a Kenmore Magic Blue?
Power bar spins, but as soon as it't put on the carpet the beater brush quits spinning
Aug 11, 2009 | Kenmore Magic Blue 24195 Bagged Canister...
Kenmore vac producing burning odor
It sounds like you have bad carbon brushes on the motor. Get replacement brushes from a local vac shop, and take the unit apart. On each side of the motor their is a retangular piece of plastic with what looks like magnets in them. In most cases they are simply held by 2 screws. Replace these brushes and reasemble the unit. If the problem persists you have burned out the comutator on the motor and the whole thing must be replaced.
Apr 15, 2009 | Kenmore 22085 Bagged Canister Vacuum
Filters on Kenmore Magic Blue vacuum cleaner
Mar 05, 2009 | Kenmore Magic Blue 24195 Bagged Canister...
Good armature maybe needs new brushes
You can replace the carbon brushes and most repair shops should have them. Also tho, the armature could be causing the problem, if you put in new brushs and it still arcs badly, then the armature is bad.
Apr 16, 2008 | Kirby G4 Bagged Upright Vacuum
Roller brush of vacuum not rotating
Apr 15, 2007 | Kenmore Magic Blue 24195 Bagged Canister...
Kenmore Magic Blue 24195 Bagged Canister Vacuum Logo
24 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
