Question about Dell 922 All-In-One InkJet Printer
Error 1200 - Carrier Stall
I recently changed the black ink cartridge and now I just get the error code 1200 CARRIER STALL
  • Anonymous Oct 08, 2007
    The cover is closed completely but I don't see the head lock. I don't even know what it is or where it is!
  • 705 Answers
If you can move the head back in under the housing a little you may see that the head lock is sticking out and causing the head the jam. With the power off push the head back and look for the headlock. If you can see the lock, try using your finger to rotate the gears at the other end of the printer in a reverse direction. This is the direction the printer should run when it powers up to retract the head lock. Try to observe if the lock moves back in. If not, use a thin screwdriver and see if you can manually push the lock back in. If you manage to move the head lock back in, move the head by hand to around the middle of the carriage and power the machine on. If the machine returns the head to the home position and parks ok you are on your way. Power off and then back on to see if the lock now retracts by itself. If the head gets stuck again it would suggest that the locking mechanism is damaged and need either repaired or removed.
Posted on Oct 08, 2007
  • Inky Fingers
    Inky Fingers Oct 08, 2007
    Oh, the other thing to check is that the carrier lid is down. Use something thin like a sheet of heavy card or a small ruler, and push it under the housing over the top of the carrier. Press down and then try to pull the head out by hand.
    If it pulls out, you may now notice that the cover is not closed fully or has popped up after replacing the inks.
SOURCE:
THE UNIT SHOWS ERROR CODE 1200
The 1200 error is caused by a cartridge carrier stall. This can happen if:
  • The print cartridges are not snapped in correctly.
  • The encoder strip is out of place.
  • A foreign object is blocking the cartridge carrier's path.
You can check this article on how to solve that problem: http://bit.ly/XypLZK
Nov 11, 2012 | Lexmark F4270 Plain Paper Inkjet Fax
"Print carrier stall"?
Error 0502-Carrier Stall indicates a physically blocked carrier. This condition can occur for many possible reasons. Most often, the carrier is blocked because the ink cartridge lids are open while the printer is on (Figure 1).
Figure 1: Open Ink Cartridge Lids
Reseat the Ink Cartridges and Make Sure the Lids Are in Place
  1. Make sure the printer is turned on.
  2. Lift the printer's front cover.
    new_note.jpg Note: The ink cartridge should be in the up/loading position unless the printer is busy.
  1. Squeeze the tabs on the cartridge lids and lift the cartridge lids up. The cartridge pops up when the lid is fully lifted.
  2. Remove the cartridges.
  3. Make sure that all of the protective tape has been removed from the contacts on the ink cartridge.
  4. Replace the cartridges.
  5. Snap the lids closed.
  6. Close the printer's front cover.
  7. When prompted on the printer's LCD to choose New or Old, choose Old.
  8. Press Select.
new_note.jpg Note: For more information about reseating ink cartridges, refer to the Maintenance or Ink Cartridge Maintenance section in the Online User's Guide.
Back to Top
» Reposition the Encoder Strip
  1. Remove the power cord from the printer.
  2. Lift the scanner unit to expose the inside, where the printer cartridges are located.
  3. Gently slide the ink cartridge carrier to the middle of the printer.
  4. Gently move the top part of the printer belt to the right.
  5. Using an index finger, gently push encoder strip (Figure 1) down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
    Figure 1: Inkjet Printer Encoder Strip
  6. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
  7. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
  8. Once the encoder strip has been re-seated, close the scanner lid.
  9. Re-connect the power cord to the printer.
Jul 18, 2009 | Dell 922 All-In-One InkJet Printer
The printer has an error stating ERROR 1200
Jan 30, 2009 | Lexmark X4270 All-In-One InkJet Printer
Carrier Stall is the error
Please do the following..
To check the cartridge carrier:
  1. Unplug the printer.
  2. Move the cartridges to the left by hand and then take them out.
  3. Try to print without the cartridges in the carrier. Do you still receive a Carrier Stall error message?
  4. If not, put the cartridges back into the carrier and snap them in at the back. The message should no longer appear.
If the power light on the printer is not blinking, the error message may be caused by a communication error. Do the following:
  1. Remove any other devices attached to the USB/LPT port.
  2. Uninstall the Lexmark printer.
  3. Connect the printer directly to the PC and ensure that power is being supplied to the printer.
  4. Reinstall the printer.
Thank you....
Jan 26, 2009 | Lexmark X83 All-In-One InkJet Printer
Lexmark x83 carrier stall
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:95:0:0&framed=&docid=ENUS22722&relevance=0
Use the above link to trouble shoot the problem.
Error: "Carrier Stall" ID:470
Feb 24, 2008 | Lexmark X83 All-In-One InkJet Printer
Error 1200, printer carrier stall
check printer belt for missing teeth if none are missing lubricate carrier bar(big siler bar that ink cartrides trvel along) with 3in 1 oil with power off then back on to retry
Jan 06, 2008 | Dell 922 All-In-One InkJet Printer
I get message carrier stall - error 1200
Try this 1.Disconnect power to printer 2. Force the cartridges to the left and then to the right 3. Clean at the transparent strip behind the cartrigde holder (Encoder strip) Be careful not to pull on the strip Hope this helps.....
Oct 08, 2007 | Dell 922 All-In-One InkJet Printer
Ink cartridge
Not quite sure what you mean but if it is stuck under the housing then that would give the error. Could it be that the cartridge wasn't installed straight and this has caused it to become jammed?
Dell 922
TRY UNPLUGGING PRINTER FROM WALL AND PLUUGING IT BACK UP allow cartridges to unlock lubricate you carrige bar with 3in 1 oil while it is off the carrige bar is the silver bar the ink cartridge assembly travel along use only two or three drops of oil.
Oct 07, 2007 | Dell 924 All-in-One InkJet Printer
Dell 922 printer giving error code 1200
I get error 1200 and print carrier stall.  The carrier moves fine when I turn it on, in fact it slams to the right!  Will not print at all!
Mar 23, 2007 | Dell 922 All-In-One InkJet Printer
Dell 922 All-In-One InkJet Printer Logo
153 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
