Question about Garden
Need a diagram for the cables on Toro 20076
Don't know how the cables go on Toro 20076
3 Suggested Answers
wentlanv
  • 710 Answers
SOURCE: model 20076 , serial# 270002127 2007
Hi gsrs,
Did you check all down the cable and see if the cable is in good shape, not stretched or frayed and connected at both ends where it should be?
Here is a website with a schematic that might help you: http://www.ereplacementparts.com/toro-20076-2700000012709999992007-lawn-mower-parts-c-121776_127291_127767.html
Choose picture I at the site.
I hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on Apr 18, 2011
Knucklebstr
  • 222 Answers
SOURCE: I have a Toro 20076
The Toro with the Tecumseh carb has a known problem that I've recently become aware of. The carb needs a good cleaning and if you're savvy you can do it yourself. I've found that the easiest way to get at the sideways-mounted carbs on these things is to first remove the muffler and then take the whole manifold and carb off together. Then separate the carb from the manifold. Remove the float bowl and give the carb a good cleaning with carb cleaner. But pay special attention to the bolt (main jet) on the bottom of the carburetor (here's the "Trick" I told you about). At the very top of the threads on that main jet (brass float bowl bolt), there is a VERY tiny hole you can barely see with the naked eye. Take the pin from the needle valve and stick it thru that hole and spray it out well with carb cleaner (scrub it with a brass brush if there's any crud on it). Be sure your carb is thoroughly clean and put it back together, making sure the linkage is correct and it should run fine. This fixes 90 percent of the Toros I work on. Best of luck to you.
Posted on Jun 28, 2011
Throttle linkage diagram for toro 22035
This is the site I use frequently. There is a blowup diagram of the linkage. http://www.partstree.com/parts/?lc=Toro+Consumer&mn=22035
Dec 13, 2014 | Toro Garden
I have a Toro 20076 that starts but will not continue to run, one time previous I moved the cables and it fixed the problem, but not this time.
Jun 26, 2011 | Toro Power Lawn Mower
I have a toro 20018. The bracket that holds the wire from the starter and battery has a cable that pulls the switch together at the bottom and off the kill switch at the top --- it has completely...
Bypassing probably isn't a good option as far as the kill switch is concerned because it is an important safety feature you want to always have. I'm not sure if you are in need of the bracket or the cable. Parts are available, finding them is the usual problem. OK
The cable can be found here. There are 2 listed. One is the traction (drive) and the other is brake (kill switch).
http://www.mowpart.com/partslookup.html#/Toro_Consumer/20018%2c_22%22_Recycler_Lawnmower%2c_2002_(SN_220000001-220300000)/HANDLE_ASSEMBLY/20018-25560-2002/3329%7c%7e334-%7c%7e3340008-0006
The bracket is possibly listed here as part number 6. It is listed as the mount for the switch. Your mower has different serial numbers and about 3 versions of diagrams are listed. This vendor has very good diagrams that include yours. Here is the diagram of the switch bracket with the starter assembly. If this isn't what you need, click on the menu tab above the diagram to view another location on the mower.
http://www.mowpart.com/partslookup.html#/Toro_Consumer/20018%2c_22%22_Recycler_Lawnmower%2c_2002_(SN_220000001-220300000)/ELECTRIC_START_ASSEMBLY/20018-25560-2002/3329%7c%7e334-%7c%7e3340009-0007
May 14, 2011 | Toro Lawn Mower With Toro Power Tools
Broken selfpropell cable. Need to replace
To replace the cable you would have to go to a Toro dealer and purchase tjhe cable I don't know of another way to get the right cable. themn Remove old one and install the new one. There are some universal cables out ther but they can be tricky to adapt to some mowers.
Aug 31, 2009 | Toro Lawn Mower With Toro Power Tools
Toro 22in Lawn mower. Loud gear noise when try to engage drive.
Problem is in the rear pinion gears on rear axle and the design of the axle itself. I have a 2005 model 20041 had the same problem. I found a Toro dealer that had the fix.The problem is creadted by the fact that there is too much "play" in the rear axle. You have to limit that play by installing shims, or washers First, but the 2 new rear pinion gears for the rear axle. While you're at it, you may as well buy 2 new rear wheels because the "grinding" has worn the sprockets on the reas r wheels.Next, get 2 "fender washers", 1/2" ID and about 1" OD. I found it easier to turn the mower over and set it on saw horses to work on it.( drain the gas and oil first). Remove both rear wheels, pinion gears and all the washers etc. (caution - keep all parts from one side together - do not pile all parts together - keep them seperated by wheel - the reason is I believe there is one more washer/shim on the right side than on the left). Now to put everything back together, find a spot on the axle where the washer will fit in between the standard stuff.Install new pinion gears and replace the rest of the washers/shims just as they came off. INstall new wheels and you'll be good as new!
Jul 07, 2009 | Toro Lawn Mower With Toro Power Tools
Need linkage hookup diagram for Toro Super
Go to TORO.com and view parts for your model.
May 19, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
