There is not much you can do except try some other data recovery companies. If your data is very important, in future you should consider doing data backups on a daily basis and/or build a fail safe computer or server system using RAID hard drives configured as a mirrored hard drives or a RAID 5 system with hot swappable hard drives. Also consider installing a UPS (uninterruptable power supply) to prevent a computer and server shutting down from power outages as this can will corrupt your data. I hope you will take this advice seriously.
I would suggest you to move the mails data from old server to new server by using copy method. i would like to know which mail client are you using in the old system, this will help me to identify the data type. Once this is known to i can send the instruction sheet or remote help in moving the data. Internet problem could be either due to configuration issue or the service outage. This can be figured out by online support.
If you feel i can help in this. Please let me know.
If you receive an error message that you are unable to connect to the server, it means that you have one or more ports blocked on your internet connection, either by your Internet Service Provider, or if you are using a router, by your modem with router function or firewall software.
Surfing uses a different gateway than data. Do you have a data plan or is cellular data turned off on your handset? To check this, press the power button, select Wireless Manager, go to phone and select Menu softkey and see if cellular data is on.
After installing, connect the player to your computer and select
'format' from the menu (This will remove all data from the player, so
you might want to make a backup). Now transfer your music files to the player using sonicstage.
If you don't transfer them using sonicstage, the player data will get corrupt and tell you there is no data.
Transfer songs to your player only with SonicStage. If you did with other software, format the player from the menu and transfer songs from SonicStage. Sonicstage can be downloaded here under SonicStage. Make sure you install the security update after installing the software...
