Question about Garden
Need a diagram for cables on Toro Mower 20076
Need a diagram for cables on Toro Mower, don't know how they go on.
  • 57 Answers
SOURCE: Need linkage hookup diagram for Toro Super
Go to TORO.com and view parts for your model.
Posted on May 19, 2009
SOURCE: I am looking for a diagram for a toro 6.5 hp lawn
Hi, I am also looking for the same manual. Thanks
Posted on Aug 18, 2010
wentlanv
  • 710 Answers
SOURCE: model 20076 , serial# 270002127 2007
Hi gsrs,
Did you check all down the cable and see if the cable is in good shape, not stretched or frayed and connected at both ends where it should be?
Here is a website with a schematic that might help you: http://www.ereplacementparts.com/toro-20076-2700000012709999992007-lawn-mower-parts-c-121776_127291_127767.html
Choose picture I at the site.
I hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on Apr 18, 2011
Knucklebstr
  • 222 Answers
SOURCE: I have a Toro 20076
The Toro with the Tecumseh carb has a known problem that I've recently become aware of. The carb needs a good cleaning and if you're savvy you can do it yourself. I've found that the easiest way to get at the sideways-mounted carbs on these things is to first remove the muffler and then take the whole manifold and carb off together. Then separate the carb from the manifold. Remove the float bowl and give the carb a good cleaning with carb cleaner. But pay special attention to the bolt (main jet) on the bottom of the carburetor (here's the "Trick" I told you about). At the very top of the threads on that main jet (brass float bowl bolt), there is a VERY tiny hole you can barely see with the naked eye. Take the pin from the needle valve and stick it thru that hole and spray it out well with carb cleaner (scrub it with a brass brush if there's any crud on it). Be sure your carb is thoroughly clean and put it back together, making sure the linkage is correct and it should run fine. This fixes 90 percent of the Toros I work on. Best of luck to you.
Posted on Jun 28, 2011
  • 122 Answers
SOURCE: Do you know the belt size for a Toro LX423 riding
Here is a listing from amazon.com, looks like the belt is 96.5 inches long , to determine the width measure your old belt.
http://www.amazon.com/Replacement-part-Toro-mower-112-0340/dp/B003X9XGB0
Posted on Aug 30, 2011
Need wiring diagram for a Toro Riding Mower Model 74413,serial no. 250000194
go to toro web site enter model # and should be able to get diagram,if not go to mower repair web sites they should be able to provide diagrams.
Jun 11, 2015 | Toro Garden
I have a toro 20018. The bracket that holds the wire from the starter and battery has a cable that pulls the switch together at the bottom and off the kill switch at the top --- it has completely...
Bypassing probably isn't a good option as far as the kill switch is concerned because it is an important safety feature you want to always have. I'm not sure if you are in need of the bracket or the cable. Parts are available, finding them is the usual problem. OK
The cable can be found here. There are 2 listed. One is the traction (drive) and the other is brake (kill switch).
http://www.mowpart.com/partslookup.html#/Toro_Consumer/20018%2c_22%22_Recycler_Lawnmower%2c_2002_(SN_220000001-220300000)/HANDLE_ASSEMBLY/20018-25560-2002/3329%7c%7e334-%7c%7e3340008-0006
The bracket is possibly listed here as part number 6. It is listed as the mount for the switch. Your mower has different serial numbers and about 3 versions of diagrams are listed. This vendor has very good diagrams that include yours. Here is the diagram of the switch bracket with the starter assembly. If this isn't what you need, click on the menu tab above the diagram to view another location on the mower.
http://www.mowpart.com/partslookup.html#/Toro_Consumer/20018%2c_22%22_Recycler_Lawnmower%2c_2002_(SN_220000001-220300000)/ELECTRIC_START_ASSEMBLY/20018-25560-2002/3329%7c%7e334-%7c%7e3340009-0007
May 14, 2011 | Toro Lawn Mower With Toro Power Tools
Need belt diagram for toro 56145 serial 7010188
Go to www.partstree.com. Put your information in and will show you parts list and diagrams you are looking for this mower.
Good Day.
Oct 12, 2009 | Toro Lawn Mower With Toro Power Tools
Toro 22in Lawn mower. Loud gear noise when try to engage drive.
Problem is in the rear pinion gears on rear axle and the design of the axle itself. I have a 2005 model 20041 had the same problem. I found a Toro dealer that had the fix.The problem is creadted by the fact that there is too much "play" in the rear axle. You have to limit that play by installing shims, or washers First, but the 2 new rear pinion gears for the rear axle. While you're at it, you may as well buy 2 new rear wheels because the "grinding" has worn the sprockets on the reas r wheels.Next, get 2 "fender washers", 1/2" ID and about 1" OD. I found it easier to turn the mower over and set it on saw horses to work on it.( drain the gas and oil first). Remove both rear wheels, pinion gears and all the washers etc. (caution - keep all parts from one side together - do not pile all parts together - keep them seperated by wheel - the reason is I believe there is one more washer/shim on the right side than on the left). Now to put everything back together, find a spot on the axle where the washer will fit in between the standard stuff.Install new pinion gears and replace the rest of the washers/shims just as they came off. INstall new wheels and you'll be good as new!
Jul 07, 2009 | Toro Lawn Mower With Toro Power Tools
May 19, 2009 | Garden
The cable traction cable is broken on my toro personal pase lawn mower. part number 105-1844 how do i change it
I changed the cable on my toro mower but i cant make it go unless i pull back on the handle .i cant find a picture to see what i am doing wrongcan you help. Thanks
May 04, 2009 | Toro Lawn Mower With Toro Power Tools
Replacing traction cable
Go to toro.com then customer care then manuals and parts type in model then find owners manual to download.
Jan 22, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
