Question about HP LaserJet Office Equipment & Supplies
HP LaserJet 600 Tray 2 won't lift
Tray 2 won't lift, we hear a clicking sound but won't lift
  • 25 Answers
SOURCE: My HP LaserJet 4200 prints fine from tray 2, but will NOT print envelopes from tray 1. It WILL print on regular paper from tray 1, but will not print envelopes. What gives? I've already rebooted the
Are there settings on the control panel of your printer?
Is the tray 1 the MP tray? (The one that flips towards you)
If so, can you change the settings of the Tray 1 to Envelope on the control panel?
I hope this helps.
Posted on Aug 14, 2008
frankzjm
  • 191 Answers
SOURCE: How to replace a pickup roller in Tray 2, HP LaserJet P3005n
please reference here:
https://www.laserpros.com/hp_P3005_tray_2_pickup_assembly.asp
hope you fix it well
Posted on May 13, 2009
DosHog
  • 168 Answers
SOURCE: 13.01.00 paper jam tray 2
The pickup rollers are worn out. Replace them and your problem will be gone. While you are sourcing them, use some alcohol. This may give them a little more life.
Posted on Jul 23, 2009
  • 4 Answers
SOURCE: HP Laserjet 4700 Always Defaults to Tray 1
Your tray 1 might be open (even just partially) or your manual feed setting might be on. You can find this setting under > Configure device / Printing / Manual Feed
Posted on Sep 18, 2009
  • 240 Answers
SOURCE: default paper tray selection for HP LaserJet 4200tn
1) When the printer receives a print job, it selects the tray by trying to match the requested paper type and size with what has been loaded in the trays. Using an “autoselect” process, it searches all available trays for the paper that satisfies the request, starting with the bottom tray and ending with the top tray (tray 1). The printer begins printing the job as soon as it finds the proper type/size.
2) If paper is loaded in tray 1 and tray 1 is set "TRAY 1 TYPE=ANY" and "TRAY 1 SIZE=ANY" on the
Paper Handling menu, the printer will always pull paper from tray 1 first.
Posted on Dec 10, 2009
Change default paper tray HP LaserJet 9050
When you click Print then right click on your HP ptinter - click Properties - Paper Quality tab - click Paper source and select Tray 2 - Click OK - then OK to print.
You can change the paper type in Tray 2 into Tray 1 and vice versa to save going into Properties to change the Tray selection.
May 31, 2012 | HP LaserJet 9050 Printer
Hp laserjet 4250dtn tray 2 & 3 will not lift
Any message appearing? like 60.X ? '*Open 'tray two' check 'open message (if No check switch 102) YES '*remove tray2 lift drive mechanism(RM1-1074-000CN) check is it working? YES '* check tray mechanism is it engaging to the lift mechanism? '* check connector/cable of lift drive motor* if not working replace lift drive mechanism '* mechanism is good replace DC controller.
RM-1074-000cn
Sep 06, 2011 | HP 4250dtn Monochrome LaserJet Printer
HP LaserJet 1012: The paper has stopped feeding. I hear the feeding mechanism rolling, but the paper does not feed.
Check the adjustment of the guides in the paper tray. There should be about an 1/8 inch of play from front to back so that the sheets of paper so they can be lifted from the tray. If the stack of paper is snug, move the rear guide back a little bit.
Feb 27, 2011 | HP LaserJet 1012 Printer
Please how do i resolve 60.02 hp printer error
Something is preventing tray 2 to be lifted.
Take tray tray out of the printer and check for obstructions preventing lifting of the paper.
Switching tray's is possible to ascertain if the problem lies with the tray or the printer.
If the problem is with the printer the lift motor is suspected to defect.
Dec 31, 2010 | HP LaserJet 9050n Printer
Hp Laserjet 8150. Does not pick up from Tray 3....but the tray does lift
Start by pulling out tray 2 and setting it on the floor. Next take out tray 3 and slide it into tray 2. Print from tray 2. If it works, take the tray on the floor and put it into the tray 3 slot. Print from tray 3. If it fails change the feed rollers.
Nov 11, 2009 | HP LaserJet 8150 Printer
Waititng for tray 2 to lift
if the tray doesn't lift than there may be a problem with the lifting motor. remove the right cover assembly and near the center bottom is the motor assembly. insert the tray and check to see if the motor is functioning. also check the tray, there is a gear on the tray that drive the tray up into position.
Sep 25, 2009 | HP LaserJet 4250n Printer
My printer is not working
A wire is broken off of the tray 2 lift motor. It can be resoldered.
Jun 13, 2009 | HP LaserJet 4250n Printer
HP laserjet 8000 tray 2 not empty
Do you hear the paper "drop" when you pull out the paper tray. If not, it could be a lift motor
You will have to pull the Paper Input Unit to repair it.
Small items are not available for us to purchase.
If you can't fix, you need a new unit. About $400.00
Feb 11, 2009 | HP LaserJet 8000 Printer
HP Laser Jet 4350tn issue
open tray 2 and tray 3 and try it.
Dec 03, 2007 | HP LaserJet 4350TN Printer
228 people viewed this question
Seeker5211
Seeker5211
