Question about Measuring Tools & Sensors
Briggs stratton wiring diagram
17.5hp original motor model 31g777. repalcement 21hp model 331977. color codes and pinouts dont match /
emissionwiz
  • 76132 Answers
SOURCE: audio wiring problem
Radio Constant 12V+ Wire: White/Green
Radio Switched 12V+ Wire: White/Red
Radio Ground Wire: Black
Radio Illumination Wire: n/a
Radio Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: n/a
Radio Antenna Location: Rear Glass
Front Speakers Size and Location: 6 1/2′ Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size and Location: 6′ x 9′ Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Posted on Apr 06, 2009
  • 473 Answers
SOURCE: 10 HP Briggs and Stratton Throttle assembly
www.briggsandstratton.com/maint_repair/manual_and_more/
Then print in model no etc. You should get owners manual as well as parts list.
Posted on May 05, 2009
  • 10865 Answers
SOURCE: need head bolt torque for Brigges Stratton 18 Hp
210 to 230 inch pounds. Torque in a crisscross pattern upper left lower right upper right or left or right.
Posted on Jul 10, 2009
  • 384 Answers
SOURCE: my friend has a 18.5 briggs stratton v- twin that
The engine fuel needs to be primed into the carburator and the choke set.
Posted on Sep 17, 2009
Testimonial: "thanks for your answer. I was quessing that the suction(prime) was in the throat of the carb a venturi action,but I'll simply prime the fuel to it."
  • 583 Answers
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Posted on Oct 25, 2009
I need a color coded wiring diagram for a john deere La130 automatic riding mower w/ 18 hp Briggs and Stratton motor
A wiring diagram is something you would have to request directly from John Deere.
Aug 13, 2016 | John Deere Garden
Carbarator linkage placement
well model number or what we are working on or something rellevent
Aug 19, 2014 | Briggs AND Stratton Intek 331977-0001-G1...
Need a wiring diagram for a briggs and stratton 21hp engine 3319770001G1
I hope this helps.. http://www.partstree.com/parts/?lc=briggs_and_stratton&mn=331977-0001-G1&dn=104340007 If there is a certain issue I could help with i would be more than happy to do so.. If you are matching a different engine to a mower and are trying to figure out what wires go where, let me know, I can help with the color matches by mower model and the engine number.. Best of luck to you..
Apr 22, 2014 | Garden
Riding mower keeps back firing and will not start
you have a sheared timing key it is under thefly wheel replace says the red neck
Sep 01, 2013 | Briggs AND Stratton Intek Briggs &...
Have a Yard Machine riding mower with 21hp Briggs Stratton engine OHV/IC V-Twin. when I turn on key nothing happens. How many switches control the start motor from the ignition and where are they located....
It depends on the model but most riders have the following;
1. Seat switch
2. Brake pedal switch
3. PTO switch
4. Neutral switch (if its a shift model)
All need to be closed in order to start engine.
Jun 03, 2010 | Briggs & Stratton Briggs Stratton Intek V...
How do I install a fuel pump on a model #31g777 0559 17 1/2 hp briggs and stratton engine?
remove the screws that hold on the fuel pump install new pump and torque screws to 16 inch lbs
Nov 17, 2009 | Briggs & Stratton Garden
Measuring Tools & Sensors Logo
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
