Question about Canon DR-3080CII Path-Through Flatbed Scanner
Calibration sheet for canon dr-c125 scanner - Canon DR-3080CII Path-Through Flatbed Scanner
zone48
  • 25 Answers
SOURCE: DR-2050C Scanner all sheets feed thru only one scans
Do you get an error message after the first scanned image? If not, check your software settings to see if you have the option of single page /multipage scanning. Some software lets the customer choose a single page scan when the SCAN button is pressed.
Check the "Feed Select Lever" to make sure it is in mutifeed position. If not, it will grab all of the docs at once.
Posted on Jul 07, 2008
mohanchennai
  • 490 Answers
SOURCE: drivers for Canon DR 3080C
You can get them from the following site
http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2341&modelid=512
S. Mohan, Chennai
Posted on Sep 25, 2008
mohanchennai
  • 490 Answers
SOURCE: error message -4431
If the scanners keeps blinking while powering on, it is because it has not been intialised. Check for loose shreds of paper in the paper path. Unless the scanner intialises, it cannot scan. If simpel 'countonly' option works, then the scanner is okay.
S. Mohan, Chennai, India
Posted on Mar 18, 2009
neferty
  • 31 Answers
SOURCE: Canon DR-7080C Missing page size selection in scan properties
tried this? http://software.canon-europe.com/software/0025523.asp?model=
Posted on Jun 10, 2009
mohanchennai
  • 490 Answers
SOURCE: Canon DR-9080c scanner not lifting error no page found in feeder
There is a paper sensor just under the rolers in the lifting tray. Clean the area thoroughly with a damp cloth. Keep some sheets and try ]count only'. If it works then the sensor is okay, then you can try your scanning. If it is not sensing paper, check the sensor or connections to the sensor.
S. Mohan, India
Posted on Jul 10, 2009
Unable to attach scan to email
if the scanner works properly, then you should have a save file. Depending on your email software, you should have some sort of attachment button. Click that...find the file you want to attach...click that...it should be part of your email and you can send it. If the scanned file is too large your email software may not load up the attachment.
Apr 10, 2014 | Canon DR-C125 SCANNER
I have a canon dr-9080 scanner that does not recogniize slip sheets. the rollers have been replaced and the scanner is clean.
There is a minimum size required for a page to be scanned. Please ensure that your sheets exceed that. (2.2: x 2.8")
S. Mohan
Apr 03, 2012 | Canon DR-9080C Path-Through Scanner
When scanning, there are lines on the image I have scanned.
Use a blank sheet of paper (as white and clean as possible). Put it in the scanner landscape ( you will need to cut off about 1/2 inch of the paper to make it fit. The run the DR-3080CII Shading tool (DR3KUserSh.exe) C:\Program Files (x86)\Canon Electronics\DR-3080CII\DR3KUserSh.exe
May 19, 2010 | Canon DR 3080C Path-Through Scanner
Canon dr-7580 scanner how to initialize cis
If the Black lines are jaggered and are vary in size with different levels of brightness, then most likely it is scratch on the glass. If the lines are sharp and perfect and does not change when different brightness is chosen, then it could be failure of CIS module (Try this under B&W mode). To the best of my knowledge there is no concept of initialising the CIS, you may need to clean the Shading sheet.
Apr 10, 2010 | Canon DR-7580
Need the adjustment sheet to calibrate my canon dr3080cii, where can I download?
I'm sure the adjustment sheet is printed when you do a print test with the Canon control program, look in the windows programs menu for the Canon group and you should find the right program to run.
Mar 01, 2010 | Canon DR-3080CII Path-Through Flatbed...
Canon DR-2050C Scanner gets verticle line down image
I have the same issue with mine and there are 2 image sensors on this scanner. 1 in the back that you will see when you open the front that has a meteal shield covering the top half, and one in the fold out front that faces the inside. These are the "glass" sections everyone is refering to. Problem is, they are plexiglass, not glass and mine has a tiny scratch in the lens that is causing the line. This could be your problem. find the lens and use a LED flashlight to inspect your lens for scratches. If its scratched like mine, the entire module has to be replaced to fix it. The canon part number is MH7-7038 and they range from $125-$160 if you replace it yourself. The one in the front is easy to do, but the back one is a little tricky. Hope this helps. E. Alexander, Field Tech, Cummins-Allison
Oct 26, 2009 | Canon DR-2050C Path-Through Scanner
I have a canon dr-3080c that will scan all but the last page have to put blank sheet of paper to complete scan job, have replaced roller kit for other problem and the kit repaired that problem but still...
I think this is rubber roller problem. Obviously, the scanner cannot find out which is the last page. If the paper available is less, the roller is not pulling the last few sheets.
S. Mohan
Sep 30, 2009 | Canon DR 3080C Path-Through Scanner
Jun 10, 2009 | Canon DR-7080C Flatbed Scanner
Dr 5010c feeds one to five sheets, then stops
Clean the rubber rollers (pickup and ******) with a damp cloth, loosen the papers to be scanned. Clean all the rollers in the scanning path. What is the eror that is displayed? Download the user manual from this site http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2341&modelid=11293 (5010um.pdf). Change the rollers if they are old.
Apr 16, 2009 | Canon DR-5010C Scanner
Canon DR-3080CII Path-Through Flatbed Scanner Logo
old marine
old marine
