Question about Xerox Office Equipment & Supplies
Reset fuser xerox 4600 - Xerox Office Equipment & Supplies
3 Suggested Answers
  • 2072 Answers
SOURCE: how do ya reset fuser code (H-4) Xc1044 Xerox?
Performing a Fault Reset 14 will reset your copier and will help to clear error codes.
  1. Turn the power off.
  2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button.
  3. Locate the Auto Button the lower left corner of the Control Panel.
  4. Turn the power back on.
  5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear.
  6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5.
  7. Program the copier as if you were going to make 14 copies.
  8. Press the green [Start] button to store the reset code. The copier will return to the ready position.
  9. Run a test copy.
Posted on Nov 26, 2008
nakshatraipu
  • 241 Answers
SOURCE: How can I reset the Xerox Phaser 3100MFP fuser?
A hardware module is used to reset Xerox Phaser 3100 which work as permanent solution. After that you can refill unlimited number of times without any problem. www.nakshatraworld.com, 09713862555
Posted on Feb 11, 2010
How do I fix a fuser error in a Xerox Work Center 4250 printer?
Hello, my name is Steve.
Keep in-mind that you still need to "Reset" the fuser's Image count.
Resetting this will start the process from "0".
Hope this helps,Steve
Aug 18, 2015 | Xerox Office Equipment & Supplies
Reset phaser 3100mfp xerox fuser
Hi Anonymous,
What exactly did you mean, did you want to reset the printer or the fuser?
I would suggests www.xerox.com or the Xerox concessionaire would be the best place to start.
Regards.
Aug 25, 2014 | Xerox Phaser 3100MFP/S Laser Printer
Reset xerox phaser 5550
To reset the maintenance counter (assuming it is the maintenance kit you need to reset)
1. From the Main menu, select Information, then press the OK button.
2. Select Supplies Info, then press the OK button.
3. Select Reset Fuser Life, then press the OK button.
4. Select Reset Fuser Life NOW, then press the OK button to reset the fuser life.
Aug 01, 2014 | Xerox Phaser Office Equipment & Supplies
Xerox 5225 fault code 010-320???
If you have a Xerox WC5225 with Error Code 010-320, then you have a fuser problem. The fuser is the heated item which bonds the image, just before it exits the unit. The machine monitors the temperature sensors and heating elements on this part.
The fuser is sold as PN 126K24980. It is easy to replace yourself.
Nov 23, 2010 | Xerox DocuColor 3535 Copier
Out of fuser web.I need to reset it on nwm.How I can do it ? Please help Mashine is xerox 5790
1.start +0
2.6789
3.dc135 hsfi line 20 clear
4.nwm accsess
6.read write
7.reset 3984 to 0,
8.reset 3985 to 0,
9.reset 3986 to 0,
10.reset 3987 to 0
Then open mashine door,take out fuser web sensor and put it back.
Message out of fuser is gone.Now it is ready to make copies.
Apr 12, 2010 | Xerox DocuColor 12 Printer
Dec 15, 2009 | Xerox Phaser 3100MFP/S Laser Printer
Hello i hope someone can help me with my problem i need reset the fuser uit xerox phaser 7760,because the rollers both(up,low) are like new condition thank you
You can get more life out of the fuser by removing one end and placing a piece of tin foil OVER the THREE FUSES, which are designed to blow at set times. Just tape it in place with some tape.
Good Luck
Oct 03, 2009 | Xerox Phaser 7760/YDX Laser Printer
Xerox Phaser 3100 Printer Error Fuser Temp.
fuser Temp printer error problem.please give me the solution.
Sep 14, 2009 | Xerox Phaser 6120/YN Laser Printer
Xerox Phaser 6100 Fuser Error
Try this,
Reset Fuser Life
  1. Using the control panel buttons scroll to Maintenance, press OK.
  2. Scroll to Check Others, press OK.
  3. Scroll to Fuser, press Reset
Oct 22, 2007 | Xerox Phaser 6100/BD Laser Printer
73 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
