Question about Humidifiers
Idylis humidifier 10 140
Display panel reads Ee
How can I get an owners manual for this humidifier?
'This humidifier'? The one you have in front you that we can't see and don't know what it is?
Google is your friend in such cases. Google
Make model manual.
Feb 09, 2016 | Idylis 2.5-Gallon Ultrasonic Humidifier...
Mine is leaking badly. It is not overfilled. any ideas why?
It most likely it the valve on the supply tank not properly stopping the flow of water into the basin resulting in it overflowing. Mine is doing the same thing and I am trying to find replacement parts.
Jan 22, 2015 | Idylis 2.5-Gallon Ultrasonic Humidifier...
Idylis S55C-AE1 humidifier leaks water on floor
My idylis humidifer is lealng where you put the water canister, after about 15 minutes from starting unit
Feb 26, 2014 | Idylis 2.5-Gallon Ultrasonic Humidifier...
Idylis #0484756 unit shuts off tank emply but take is full
Just purchased a Idylis model 0484756 and it has no
operators manuel. Is there one available?
Where?
Thanks
Jan 20, 2014 | Humidifiers
What are the setting recommendations for idylis humidifier #1 HUM 10 140 whole house system?
I plugged my Idylis whole house humidifier Model #1 HUM 10 140 in and all it shows is two lines. Will not work? What is wrong?
Nov 27, 2013 | Humidifiers
Will not power on
Throw it in the trash and buy you a better one !
Nov 10, 2013 | Idylis 2.5-Gallon Ultrasonic Humidifier...
No manual for Bonaire humidifier BCM 4510-U
If someone put it togetherm you can take it apart.
See if the dicharge grill slides up and the bottom vcan be pulled out like a window screen. If so, ,other panels may also do so in order to access the internals, Unplug unit when in the water or around fan. Do not run unit without panels in place. Any fan cleaning use something like 409 spray and rinse off with a spray bottle also. Keep water out of all and any electrical. Rinse and leave no cleaner in humidifier to be mixed with misting. Good Luck
May 17, 2009 | Crane Frog EE-3191 1 Gallon Humidifier
Humidifiers Logo
82 people viewed this question
Top Humidifiers Experts
Mack Baxter
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
