Question about Grohe 23048002 Eurostyle Cosmopolitan Roman Tub Filler Chrome
What tool do i need to remove a grohe eurostyle cartridge mixer tap
5 Suggested Answers
  • 52 Answers
SOURCE: Trying to disassemble Ladylux Cafe faucet. Grohe
If it is just replacing the handle you will only need a smaller screwdriver set (pretty common) and an allen wrench. I don't know exactly what size you need but you can get a set of these wrenches pretty cheap at any tool or hardware store. Basically the tool is a hexagonal rod that is bent in the shape of an "L". You'll need the smaller set for this job sold usually in sets that have a range of sizes from .05" to 3/8" diameter. I would guess your hex nut is 1/8" or less.
On the bottom of the handle between the sink bed and the handle you'll be able to feel a small hole. When you stick the allen wrench in there it should fit snuggly if the allen wrench wiggles a lot go to the next size up. Since the screw is facing up you will pull the other end of the wrench toward you. This will loosen the screw. It will not take a lot of effort so if you have to force it make sure the allen wrench is actually seated. Kind of a pain but you'll have to reposition the wrench as you get it loosened to fully extract the screw.
Once the screw is out the handle will drop down and the cap just pulls off. Assembly is reverse but make sure that your screw is going into the threads without resistance before tightening. This will prevent cross threading.
Posted on Feb 15, 2010
  • 112 Answers
SOURCE: I have an old Grohe
It is in the mixer system,you may have put in repair kits with new springs,diaphrams,and o-rings or seals(washers).
Posted on Jun 12, 2011
  • 129 Answers
SOURCE: How to remove the cartridge
first shut off the water under the sink:) next put the stoppers in the sink so you dont drop anything in the drain:) then examine the handle closely and you will find a plastic/rubber "knob" like a wood dowel which is hiding the bolt we need to access to remove the handle. carefully remove it (it may be gone already depending on how old your faucet is and it will be pretty small) most likely you will need an "allan" key to remove it. now there is just the threaded ring which holds the cartridge in place. now its possible that grohe makes a tool designed to remove this ring. i am actually not familiar w/this model but you do not need it. you can use a pair of channel locks w/a dish towel and a lite touch to loosen the ring (ritey titey lefty loosey:) now the cartridge should come rite out but it may take a little coercion. just let me know if you need anything else and good luck:)
Posted on Jul 27, 2011
  • 44269 Answers
SOURCE: Does the grohe euphoria 180 with built in thermostat require a separate mixer tap or is it built in
that would be built in I believe
Posted on May 21, 2015
How do I replace flexible pressure hose in Grohe Eurostyle bathroom mixer tap. I can not just unscrew it at the bottom.
STOP and look it over really well . some of the newer ones are just a slip joint coupling others simply unscrew from below
Feb 07, 2015 | Grohe Plumbing
How to remove the cartridge from a monda sink mixer tap?
Jul 27, 2011 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Water pressure has dropped off with pressurised water system
hi Peter if you have a mixer tap there are no washers there is a ceramic cartridge in the centre but that should't be the fault
the most common rectification is to undo the airrator which is the filter that the water comes out of and clean any forein matter from it
May 10, 2010 | Grohe Chiara Neu Lavatory Centerset ...
I have a thermostat mixer shower but hot water has become minimal recently, even when water is piping hot from the taps? The shower is fed from cylinder tank on 1st floor, and cold water tank is in the...
The thermostatic mixing spool cartridge may be worn out. The low water pressure may indicate sediment in the cartridge as well. This can be easily removed by hand tools
Feb 17, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
Have a grohe euro plus,turn off shower and it drips.is it seals or pressure balancing cartridge?
if its a inwall mixer tap, you will have acartridge, ,depending on how old mixer is, I have found most of the time only the O-rings at the base cartridge wear out, by replacing these usally stops the drip. IF you cant find the right size o rings , you can purchase another replacement cartridge from most major plumbing stores
Nov 06, 2009 | Plumbing
Mixer tap in kitchen hard to turn on and off
It is a simple matter of on o-ring being out of align. REmove the valve cartridge fromthe faucet by first shutting off the water at the shut-off valves. Then remove the handle by means of loosining the set-screw on the front side of the handle. Then remove the valve cartridge by unscrewing the packing nut that surrounds the shiny stem that the handle was connected to.
Once that is removed then the cartridge will slide out, probably with a bit of force. Replace the o-rings and any other washers that may be there and coat liberally with plumbing grease before re-installing. This should fix you right up.
Bring the old cartridges, rings and washers with you to your home improvement store to make replacing easier. Should be about $15-$20.
Good luck.
Apr 25, 2009 | Grohe Classic Kitchen/Bar Faucet ...
Grohe 23048002 Eurostyle Cosmopolitan Roman Tub Filler Chrome Logo
Top Grohe Home Experts
Mike
Donni Steen
Are you a Grohe Home Expert? Answer questions, earn points and help others
