Question about LG 42LC2D 42 in. LCD HDTV
Brocking screen PART NUMBER LC420DUN (SE)(r2)
How to brock a number
Put that number under screened calls
May 13, 2014 | Nokia 2630 Cellular Phone
I would like the multi zone code for a samsung V6800 dvd
Make sure the player is switched on, and is at the Samsung logo
screen. Also check the tray is shut and that there's no disc in the
player.
Now press the REPEAT button on the remote, followed by a five digit
code. This code is different depending on what region your player is
*currently* set to:
R1 - 29334
R2 - 38767
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
So for example if you have an R2 player, press REPEAT-3-8-7-6-7.
If you've done this correctly (and your player is compatible with the
hack), you should see a number at the top left corner of the screen
corresponding to the current region.
Now, pressing any number from 1 to 6 will change to the corresponding
region. Or, press 9 for auto-region mode.
Next, press OPEN/CLOSE to open the tray, followed by Standby (or DVD
POWER) on the remote to close it and put the player into Standby mode.
The next time you turn your player on, the new region will be set.
Don't forget that if you want to hack it again, you'll need to use a
different code, as listed above. If it's currently set to region 9,
use the code for the last *proper* region you set it to.
Sep 28, 2008 | Televison & Video
Repair headphones
You have to take to an electronic repare shop.
Jan 31, 2014 | Samsung Yp-R2 4Gb R2 Toledo Mp3 Hd Player...
Location of Mazda r2 diesel engine number
i need to know the same did you find out where it is?
Aug 07, 2012 | Computers & Internet
WHERE IS THE EXACT ENGINE NUMBER LOCATION OF KIA SPORTAGE R2 2006 MODEL
Engine number for sportage 2.0 r2 diesel engine is right behind the A?C compressor.
Apr 22, 2012 | 1999 Kia Sportage
Want to turn off Auto-restart function of haier split ac
I do not know anything about this but from a manual I have seen its tied in with Timer and Sleep functions there are a lot of instruction manuals ou on the web but you description is to generic you need a model number of which there are a lot.
HSU-09LEK13/R2(DB)
HSU-12LEK13/R2(DB)
HSU-18LEK13/R2(DB)
HSU-24LEK13/R2(DB)
HSU-09LEK03/R2(DB)
HSU-12LEK03/R2(DB)
HSU-12CKAS(R2DB)
HSU-18CKAS(R2DB)
HSU-12HKAG(R2DB)
HSU-18HKAG(R2DB)
Just a sample look for a number on the device which may be under a cover.
As its software controlled they do need to reset themselves as to how long this takes varies from machine to machine.
Hope this helps
Apr 05, 2012 | Heating & Cooling
Emergency brake cable snapped.
cable get rusted and will brock,is wery semple to fix .poll taire and se if is brocen,cable is conected to rear caliper
Mar 12, 2009 | 2002 Chevrolet Malibu
Region code Samsung BD - P1400
1. Make sure the player is switched on, and is at the Samsung logo screen.
2. Also check the tray is shut and that there's no disc in the player.
3. Now press the REPEAT button on the remote, followed by a five digit code.
4. This code is different depending on what region your player is *currently* set to: R1 - 29334 R2 - 38767 R3 - 56732 R4 - 76884 R5 - 53814 R6 - 24462 So for example if you have an R2 player, press REPEAT-3-8-7-6-7.
5. If you've done this correctly (and your player is compatible with the hack), you should see a number at the top left corner of the screen corresponding to the current region.
6. Now, pressing any number from 1 to 6 will change to the corresponding region. Or, press 9 for "auto-region" mode.
7. Next, press OPEN/CLOSE to open the tray, followed by Standby (or DVD POWER) on the remote to close it and put the player into Standby mode.
8. The next time you turn your player on, the new region will be set. Don't forget that if you want to hack it again, you'll need to use a different code, as listed above. If it's currently set to "region 9", use the code for the last *proper* region you set it to.
or this...
Multi-Region on a Samsung BD-P1000 R2:
1. Switch on unit
2. Remove any disc
3. Wait fo NO DISC message
4. Press REPEAT on the remote control (NOT REPEAT A-B)
5. Type 57538 followed by the desired region number on the remote control
NOTE: 9 = Multi Region mode
6. Press OPEN/CLOSE on the remote control
Switch unit off
7. Enjoy :0)
Apr 27, 2008 | Televison & Video
Screen is blank
IT IS THE RIBBON CABLE THAT CONNECTS THE LCD TO DAUGHTER BOARD ..ABOUT 32 $ PLUS LABOR LET ME NO IF THIS HELPS I HAVE PART NUMBER SOMEWARE
Feb 28, 2008 | Samsung SC-D353 Mini DV Digital Camcorder
LG 42LC2D 42 in. LCD HDTV Logo
Computer Repairing
Computer Repairing
