Question about Canon Imageclass D1350 Multifunction Fax Copier Printer Scanner Bw
ERROR E733-0000 TURN MAIN POWER ON
Error code c4801 For C284e
You may have main board issues. Maybe Try error code reset.
Open front door and locate main power switch on the bottom left and turn off.
Press and hold the reset button , button on control panel.
Turn main power switch back on whilst pressing reset.
after 1 - 2 min a white screen with 1 button saying"error code reset will appear , let goo of reset button.
Press error code reset and then turn main power switch of for 20 seconds. turn main power switch.
If code returns contact me on my phone to discuss
Sep 02, 2014 | Konica Minolta bizhub Office Equipment &...
My canon MF4412 is power on but display is coming turn the main power on E202-0002
my mf4412 printer displaying a problem e202-0002 and red button continue burning
Jun 24, 2012 | Canon Office Equipment & Supplies
Canon MF4412 turn the main power on E000-0000
Apr 18, 2012 | Office Equipment & Supplies
How can I solve my Canon iR 2016 copier system error E019 problem?
If you have an error code E019 on the screen. Turn off the main power, wait 10 sec. and turn power back on. If you still have error code,
press "additional functions" key
press at the same time the "2" and "8" keys
press "copier"
press "function"
press "clear"
press "ERR"
press "OK"
press "Reset" key 2 times
turn main power off for 10 sec.
turn main power on.
Nov 03, 2010 | Computers & Internet
After 5 or 6 copies taken an error E000070-0202 and E000070-0101 will occured. what is the problem
E070 there is an error in the detection of ITB home position
00xx The home position of the intermediate transfer belt is not detected within
a specific period of time .
The ITB HP sensor is faulty.
Turn off the main power, and check the DC controller PCB and the
ITB HP sensor; then, turn on the main power.
01xx The period of time between when the home position of the intermediate
transfer belt is detected and the next home position is detected is longer
than specified .
The presence of a tear may have caused the sensor to wrongly identify it
as indicating the home position.
Turn off the main power, and check the drive of the intermediate
transfer belt; then, turn on the main power.
02xx The period of time between when the home position of the intermediate
transfer belt is detected and when the next home position is detected is
shorter than specified .
The intermediate transfer belt slips on the drive roller, causing a delay in
the timing at which the home position is detected.
Turn off the main power, and check the surface of the intermediate
transfer belt for a tear; then, turn on the main power.
03xx The detection of the home position of the intermediate transfer belt has
failed once.
ITB home position sensor B and ITB home position sensor A must occur
alternately; however, the same state has been detected continuously.
ITB HP sensor; then turn on the main power.
Jun 30, 2010 | Canon imageRUNNER C5800 Copier
Canon iR 3100 CN Fehlercode 000602-0202
Hdd error - call service!!!!
But if you want do something on your own:
A:1) Make the following selections, and enter '1': COPIER>FUNCTION>SYSTEM>CHK-TYPE.
2) Make the following selections, and press the OK key to perform: COPIER>FUNCTION>SYSTEM>HDCHECK*.
3) When done, turn off and then on the main power.
B:
1) Find the appropriate CHK-TYPE from the table 'HDD Format' ; then, make the followingselections, and type: COPIER>FUNCTION>SYSTEM>CHK-TYPE.
2) Make the following selections, and press the OK key to perform: COPIER>FUNCTION>SYSTEM>HD-CLEAR.
C:
1)** Start up the machine in normal mode (i.e., turn on the main power while pressing the 1 and 7 keys ; then, make the following selections, and press the OK key:
COPIER>FUNCTION>SYSTEM>DOWNLOAD).
2) Perform formatting of DOSDEV4 using the Service Support Tool.
D:
1) Replace the main controller (main) board.
2) Remove the image memory (SDRAM) and the boot ROM from the previous board, and attach them on the new board.
E:
1)** Start up the machine in safe mode (i.e., turn on the power while pressing the 2 and 8 keys).
2) Format the HDD (ALL) using the Service Support Tool, and download the system software (SYSTEM, LANG, RUI).
F:
1)** Replace the HDD, and start up the machine in safe mode (i.e., turn on the main power while pressing the 2 and 8 keys).
G:1) Make the following selections, and enter '1': COPIER>FUNCTION>SYSTEM>CHK-TYPE.
H:
1) Turn off the main power; then, turn on the main power while pressing the 1 and 9 keys (so that the machine will automatically start its remedial program*, turning
the control panel solid black).
2) When done (i.e., when the control panel turns white), turn off and then on the main power.
If the machine does not run its remedial program in response to the foregoing step, go to E.
I:
1) Find the appropriate CHK-TYPE in the table "HDD Format"; then, make the following selections and enter CHK-TYPE.
2) Make the selections, and press the OK key to perform: COPIER>FUNCTION>SYSTEM>HD-CHECK*.
J:
1) Make the following selections, and enter '4': OPIER>FUNCTION>SYSTEM>CHK-TYPE.
2) Make the following selections, and press the OK key to perform: COPIER>FUNCTION>SYSTEM>HD-CHECK (1 to 5 min).
* Takes about 30 to 50 min.
** As necessary, ask the user to use the RUI to collect address book data, transfer settings, and user mode settings.
May 09, 2010 | Canon iRC3100 Printer
Will not power up. Stays in standby mode.
these particular tvs are very sensitive to voltage changes spikes etc.first turn off main power switch wait at least 30 sec if standby come on wait another 30 then turn off main power again and unplug tv for 1 min then plug in turn on main switch wait 30 sec then turn on tv with remote resets system.then buy a ups and always wait at least 30 min after turning tv off to turn back on if not causes power failure and after each press of power button wait 30 seconds before trying again lmk good luck
Jan 08, 2010 | Hitachi 42HDS69 42 in. Plasma Television
The printer has stopped functioning all together.
C3851: Abnormal Low Temp. (Heater)
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Mar 31, 2009 | Konica Minolta bizhub C250 All-In-One...
Canon Imageclass D1350 Multifunction Fax Copier Printer Scanner Bw Logo
96 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
Tony
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
