FISHER STEREO I have a Fisher MC-725, needs drive belt replaced and a needle. Trying to find a place within 50 miles of Montgomery, Al I can get this item fixed
Try---
pacparts.com
Posted on Nov 24, 2007
SOURCE:
Fisher mc-715, was working fine until my kid decided to play one of those cardboard records on it, (so he says) now the arm just skips over the whole record.
It will have either knocked out the stylus from it's resting position or broke of the tip.
Here's how to check. Lift up the arm so you can see the underside of the cartridge. The stylus or needle should be seen resting on the cartridge. If it is not there it might have fallen out, but it's more likely from what you describe still there. Next with your finger gently rub the stylus end. It should feel like a sharp point. If it doesn't you will need to replace the stylus. But you might need to do that anyway. All you need is the cartridge number. Put that into google and it should come up with a replacement stylus.
Mar 23, 2018 | Fisher Audio Players & Recorders
Please send me are Fisher mc 725 manual instructionThanks you Tomislav from SLOwenia
Instructions for obtaining your manual are as follows :
You can download a manual for almost any equipment by Googling the make and model followed by the word Manual note spelling, then follow the appropriate link(s).
Jan 16, 2017 | Fisher Cameras
I have a Fisher MC-712 from the 80's. It was playing slowly so I knew the belt was probably worn. I removed the platter to find the belt lying there. I know most platters have an access hole to stretch the...
Hi, place belt back on platter. Us a finger to get hold of belt and hook over motor spindle then put platter over centre spindle.. Keep em spinnin. John. Stylus City
Feb 07, 2014 | Audio Players & Recorders
I don't no what speakers work with my fisher mc-723
The speaker output connections on this stereo system unit are called RCA...named from the inventing company. Computer speakers use what is called a "mini-plug" and as you've found out, the two are not the same.
I would suggest checking at your local Goodwill or Salvation Army store for an inexpensive pair of speakers with the proper RCA connection you need. Second choice is the local Radio Shack store...tell them you need speakers with RCA type connections and you will also need two RCA to RCA speaker wires to make the connection needed.
Nov 05, 2013 | Fisher Model Mc-723 Studio Standard Audio...
Fisher and paykel aquasmart fault 235
Try cleaning the INLET and the outlet valves, it is possible that the filters are blocked. If not check the wiring harness from the panel, check for moisture within the panel, if so use a dryer to warm off and test. Please estimate before any parts are replaced.
Jan 20, 2013 | Fisher Paykel Fisher & Paykel AquaSmart...
Fisher cassette player and Fisher cd player need belts
I believe that FISHER was trade brand of Sanyo if that helps?
Mar 07, 2009 | Audio Players & Recorders
Stereo fisher
check outlets maybe its not getting enough power or a defect within power supply
Aug 12, 2008 | Fisher Audio Players & Recorders
448 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
