Question about Toastmaster Kitchen Appliances - Others
Toastmaster model t2001w
Carriage will not latch
How do you replace ask2000 printhead
Normally you can follow these given steps..It can be different for different model.....
Turn on the unit, and open the print-carriage access door by lifting the handle until the door locks into place.
The print carriage will move to the center of the unit. After the print carriage stops, release the gray print carriage latch and lift upward to access the printheads.
Remove the old printhead by lifting the printhead handle and pulling upward.
Being careful to touch only the black plastic remove the new printhead from the packaging and gently remove the plastic tape.
Using the printhead handle, push the new printhead firmly down into the appropriate slot; matching the color on the top of the printhead to the color on the printhead carriage.
Move the print carriage latch down, and make sure the loops catch the hooks. Snap the latch into place, and close the print carriage access door.
After the message to align the printheads appears in the front panel display, press Enter . A page prints to confirm alignment.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Dec 06, 2012 | FUJIFILM Ask2000 Thermal Photo Printer
I am looking for a color access door for a print carriage on an hp psc2210 all in one printer. (C8654A)
  1. If you are putting in a new cartridge, make sure to remove the tape.
  2. Turn on the unit, then open the print carriage access door. The print carriage moves to the center of the unit.
  3. Fit the cartridge into the proper carriage.
    • The carriage with the gray latch is for the black ink cartridge (HP 56), or the optional photo cartridge (HP 58).
    • The carriage with the blue latch is for the tri-color cartridge (HP 57).
    Slide the cartridge into the carriage at a slight angle, as shown in the illustration above. When the cartridge is fully inserted into the carriage, rock it upright.
  4. Hold the hinged flap of the latch out while lowering the latch.
  5. When the latch is fully lowered, release the hinged flap. It should catch under the tabs on the carriage, as shown in the illustration.
  6. Close the cartridge access door.
  7. The LCD display may indicate that the cartridges need to be aligned. Press Enter on the front panel. You may discard the alignment page that prints.
Remove cartridges
  1. Turn on the unit, then open the print carriage access door. The print carriage moves to the center of the unit.
  2. Press down lightly on the top of each ink cartridge latch and pull the lower section of the latch out to release the cartridge.
  3. Pull the cartridge out of the print carriage and relatch the empty print carriage. The print carriage may move to the right automatically, and if the latch is up, it could be damaged.
Aug 23, 2011 | HP PSC 2210 All-In-One InkJet Printer
How to change ink cart. in hp psc 2210 all in one printer
  1. Turn on the unit, then open the print cartridge access door. The print carriage moves to the center of the unit. Never attempt to move the carriage by hand.
  2. Press down lightly on the top of the ink cartridge latch and pull the lower section of the latch out to release the cartridge.
  3. Pull the cartridge out of its holder.
  4. Carefully remove the protective tape from the new cartridge.
  5. Reinsert the new cartridge into the carriage at a slight angle. When the cartridge is fully inserted into the carriage, rock it upright.
  6. Hold the hinged flap of the latch out while lowering the latch.
  7. When the latch is fully lowered release the hinged flap. It should catch under the tabs on carriage.
  8. Close the cartridge access door.
  9. The LCD display may indicate the cartridges need to be aligned. Load paper and press "Enter" on the front panel.Discard the alignment pages that print.
Feb 01, 2011 | Office Equipment & Supplies
Need instructions on how to install a HP 6110 Cartridge Return Belt. The belt came off but does not appear to be broken.
Hello HP 6110 Cartridge
Issue : installing Cartridge on HP 6110 Printer
Printer :Desk jet HP 6110
Analysis : it seems that you are trying for Replacing the print cartridges
Solution : Please try the following steps to replace which is very simple and easy. The most important part is to understand and then apply without fear..
1) Turn on the power of the printer
2) Lift the print carriage access door on the front of the unit
Observe : the print carriage will move into the middle of the access area.
3) Release the cartridge to be replaced by pressing down lightly on the top of the carriage latch (You Need to Press Of force Single finger on the top of the Carriage Latch) and then pulling the lower section of the latch forward. Lift the latch.
4) Grasp the sides of the ink cartridge and pull the cartridge out to remove it.
5) NOW by
Holding the cartridge with the printed label up, slide the cartridges, one at a time, into the print carriage.
Insert the black print cartridge (HP 56) into the right side (with the gray latch) and the tri-color print cartridge (HP 57) into the left side (with the blue latch).
6) Latch the cartridge by pulling the lower section of the latch forward and pressing the latch down. When the latch is down, release the lower portion of the latch so that it catches under the tabs. Do not use force or damage might occur.
7) Close the print cartridge access door..
Now check the by running a test print
Click Start , click Settings , and then click Printers .
Right-click the all-in-one print icon and click Properties
On the General tab of the Printer properties, click the Test Page option.
Try the above steps hope the best out of it
Happy new year
Jan 02, 2010 | HP OfficeJet 6110 All-In-One InkJet...
The on button and arrow button are flashing (cant Print)
Hi. This error means "A carriage jam has occurred".
The steps to correct this problem are (from HP support):
Step one: Move the carriage
1.Lift the top cover of the product.
2.Turn the product off, and then turn it on.
3.Unplug the power cord from the back of the product when the grinding noise starts.
4.Move the carriage towards the middle of the product (this procedure may take a couple of tries to get the timing correct).
Step two: Remove the cartridges
1.Press down lightly on top of the cartridge latch.
2.Pull out the bottom of the latch to unhook it.
3.Slide the print cartridge out of the carriage.
4.Repeat the steps for the other cartridge.
5.Close the top cover.
6.Reconnect the power cord.
Step three: Reinstall the print cartridges
1.Open the printer cover.
2.Wait until the carriage moves to the right side of the printer and is idle and silent.
3.Press down lightly on top of the cartridge latch.
4.Pull out the bottom of the latch to unhook it.
5.Hold the print cartridge so that the copper strips are on the bottom and facing toward the printer, and then slide the print cartridge into the carriage.
* Install the tri-color print cartridge in the left side of the carriage.
* Install the black, photo print cartridge, or the gray photo print cartridge in the right side of the carriage.
NOTE: To easily identify the correct side of the carriage in which to install the print cartridge, match the symbol on the print cartridge label with the symbol above the carriage.
6.Push down on the print cartridge latch until it snaps closed.
7.Lower the cover of the product.
For other errors indicated by the lights flashing follow the link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00575972&lc=en&dlc=en&cc=us&product=467980&lang=en
Hope it helps, if it helped you, please rate the answer. For further assistance please reply back.
Aug 03, 2009 | HP Deskjet 6940 InkJet Printer
Repalcement plates for Model 270A Toastmaster Waffle Iron?
There is no way you can get replacement plates for you Toastmaster cheaper than you can buy a new one, the most expensive Toastmaster waffle maker I found was $30. the cheapest was $15 shipping will be at least half of that.
Feb 09, 2009 | Toastmaster 287 Waffle Maker
How to change a cartridge on c4345
Installing new cartridge:
Remove cartridges:
Nov 26, 2008 | HP Office Equipment & Supplies
Toastmaster Breadmaker - bought secondhand, no manual, model 1148X Serial E6173
Oct,8'08 I found a Toastmaster BREADBOX Breadmaker Model 1148x but no manual. I just downloaded the pdf file for the 65 page manual and recipes from http://kitchen.manualsonline.com/manuals/mfg/toastmaster/1148x.html for free. There is a free signup for the privacy and terms and conditions.
Also, a couple of sites refer to an 800 phone number (did bnot call it so do not know if it works) that is the same as the one for customer service on the back of the manual Part No. 33519P02, copyright 2000 Toastmaster Inc. a subsidiary of Salton, Inc.:
Toastmaster, Inc. National Service Center, 708 South Missouri St, Macon, MO 63552
In USA and Canada call: Consumer Service 1-800-947-3744, Consumer Parts 1-800-947-3745
Hours: 8:00 a.m. t 5:30 p.m. CST, www.toastmaster.com, consumer_relations@toastmaster.com.
Hope this helps!
Sep 25, 2008 | Toastmaster 1148X FastBake Bread Maker
HP Officejet 7110
Try this:
Open door, disconnect power.
Move carriage to center by hand and ensure it IS latched.
Close door.
Reconnect power.
Mar 21, 2008 | HP OfficeJet 7110 All-In-One Thermal...
User Manual for Toastmaster 550C
One good source for manuals for the brand and model you have is to log onto http://kitchen.manualsonline.com/manuals/mfg/toastmaster and you will find exactly what you are looking for.
Aug 12, 2007 | Toastmaster TCM10 Coffee Maker
Kitchen Appliances - Others Logo
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
troup
Level 1 Expert
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
