Question about Ultra Products Ultra Start 2w 2 Way Gsxr 3270 Remote Start Antenna
Need to reprogram ultra remote car starter
Remote stopped working
How can I reprogram the remote on a ultra car remote starter
Go to the car dealer of the make of car you have and they will set you up. I think they will reprogram for less than a new one.May cost a bit as those things I understand are about $130.00 or more new.
Apr 12, 2015 | Cars & Trucks
How do you reprogram (reset) the remote starter after the ignition sensor has been replaced? thanks for your help!
what type of car... what type of remote starter...who replaced the ignition sensor?
Nov 10, 2014 | Cars & Trucks
Ultra starter model 1270 keeps trying to lock doors
you will need to get the manufactures instructions or wiring diagram to wire the circuit correctly.
It appears that the circuit has an open short somewhere.
Jan 18, 2014 | Ford Cars & Trucks
Ultra Remote Start malfunction
it a factory options, this, if not, then its aftermarket hacks.
the 2008 is first year, for OEM remote starts. IIRC
if true a hack, then find who made it and get their books.
full documentation, if not found rip it out and try something that
works and is documented. fully.
some are dangerous... here is a selection of hack systems.
NON OEM.
http://www.ebay.com/sch/Remote-Car-Start-/33724/i.html?_dcat=33724&mvsub=1&_mcatda=true&_nkw=1999%20Jeep%20Cherokee&selfil=1%2C2%2C3&selvel=1999~Jeep~Cherokee~-~-
getting it to work right takes , picking one that is legal, and safe.
and reliable, and and installer that knows wire NUTS dont cut it.
etc.
id never do this to my primary wiring on any car.
and know how!
post the make, brand , and unit partnumber, or a photo
of the main box label.
and hope is possible.....
Jan 13, 2014 | 1999 Jeep Cherokee
Need programing for ast ultra remote car starter
You turn the key off to on, off to on, off to on;
Leave key in "on" position, then push and hold the little button on the antenna on the windshield - keep holding this button down on the antenna, and you'll hear 5 chirps; then push the unlock button on your remote control (and on your other remote control if you have two), then release the button on the antenna and then turn the car off.
You should be able to lock and unlock your doors now. Then try the starter. Do a Google search, and you'll find more Ultra info including a little video how to program your key fob.
Oct 14, 2009 | AST Vehicle Parts & Accessories
Remote starter
It sounds like your car is hooked up for voltage sense instead of running a tachometer wire. If you have run a tach wire you'll need to program the tach signal and make sure your remote start options are set for that.
Oct 09, 2009 | AutoCommand Remote Car Starter Add-On
Car will not start using the key fob all fuses are good, lock/unlock buttons work. i have had this remote starter in this car for nearly 3years
In some cases, if you hold down a button too long on the remote fob, the starter module goes into a setup "menu", which is possible. You didn't change the fob batteries lately, did you? It sounds like you will have to 'retrain' the fob with the starter unit so that it re-learns what to do when you push the start button. With the "Ultra" brand, you use the button on the windshield antenna to retrain your unit. I'm not sure about the Autopage brand. An installer should be able to reprogram it for you for $10, and that would be the easiest if you can't find the data by doing a Google search.
Oct 02, 2009 | Autopage Vehicle Parts & Accessories
Remote starter does not work
disconnect the battery remote starter need to be reprogram bring out the paper of remote and follow instruction to maner differente car starter hope it help fixya or post thanks pierre
Jul 15, 2008 | 1999 Chevrolet C1500
Ultra Products Ultra Start 2w 2 Way Gsxr 3270 Remote Start Antenna Logo
24 people viewed this question
Top Ultra Products Car Audio & Video Experts
xxxxxx xxx
Are you an Ultra Products Car Audio and Video Expert? Answer questions, earn points and help others
