Question about Fellowes SB95C Cross-Cut Shredder
Fellowes parts sb95c shredder - Fellowes SB95C Cross-Cut Shredder
fellowesrep
  • 102 Answers
SOURCE: Fellowes Shredder keeps running
You should be able to flip up the cd cover and visibly see the sensors in the center of the paper entry(look like little LED lightbulbs) Clean with a Q-tip dipped in rubbing alchohol. This should solve your problem. If it doesn't you probally have a burned out sensor. call 1-800-945-4545 to check with customer service.
Posted on Feb 22, 2008
fellowesrep
  • 102 Answers
SOURCE: Fellowes 220c-2 repair manual
call Fellowes Customer Service 1-800-945-4545
t_vinson57
  • 58 Answers
SOURCE: T7CM Fellowes shredder -- internal parts
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Posted on Mar 27, 2009
SOURCE: Fellows T7CM Shredder
Make sure you remove all five screws--there's one hidden under the sticker on the underside of the shredding unit.
Posted on Mar 16, 2010
  • 9 Answers
SOURCE: Fellowes shredder crc 32080 plastic gear stripped,
try thetapped@yahoo.com he has parts
Posted on Mar 18, 2010
Source for gear for fellowes 301101 DS-1 paper shredder
Replacement Parts - Paper Shredders Can I get my Fellowes paper shredder repaired or purchase parts for it?
The majority of Fellowes personal shredders (small shredders that can fit under a desk) are repairable and will have parts available. If you would like to check your model shredder to determine if parts are available, please click the "Ask a Question" tab above, and advise the model of shredder, the shredder's serial number and a description of the part needed. The serial number will be located on the bottom side of the shredder head below the bar code.
*** Please note: If your shredder is still within the warranty period, we ask that you do not open your shredder until speaking with a Fellowes Representative, as opening the unit may void your warranty.***
Fellowes office/commercial shredders (large shredders that cannot fit under a desk) are repairable and parts will most likely be available. Please do not try to repair the shredder yourself or you will void your warranty. Models included in the office shredder line are 125i Series, 225i series, 325i series, 380 series, 420 Series, and 480 series.
If you would prefer to have a local servicing dealer provide repair service to your office shredder, and would like to find a dealer in your area, please see the below link to search for a dealer by zip code.
http://www.fellowes.com/Fellowes/site/support/support_authorizeddealers.aspx
To order replacement parts, or if your model shredder is not listed, please click the "Ask a Question" tab above to ask us about your shredder. *** Please be sure to include your serial number from your shredder for the fastest service ***
Our office hours are 7:00 AM to 7:00 PM, Monday through Friday Central Standard time.
Jan 22, 2015 | Fellowes Office Equipment & Supplies
Parts for fellows sb-97cs
Check eBay for parts or Craigslist for a shredder you can cannibalize. Sometimes Fellowes can give you the part number which can help you search.
Jul 03, 2014 | Fellowes Manufacturing Powershred SB-97CS...
Spare parts for a fellows p45-c shredder
Can I get my Fellowes paper shredder repaired or purchase parts for it? The majority of Fellowes personal shredders (small shredders that can fit under a desk) are repairable and will have parts available. If you would like to check your model shredder to determine if parts are available, please click the "Ask a Question" tab above, and advise the model of shredder, the shredder's serial number and a description of the part needed. The serial number will be located on the bottom side of the shredder head below the bar code.
Go to
http://www.fixya.com/answer/answerpageslideview.aspx?ctg=176&fml=0&brd=mine&thid=24364827
and 'Ask a Question' give personal details, and that will give you details if spares are available
May 08, 2014 | Fellowes PS8C Shredder
Need the sb-95c plastic spur gear for the Fellowes Powershred. Where Can I get one?
Go to support on the Fellowes website. Enter your model number and you should be able to locate a parts finder. The shredders are rather inexpensive and the repair parts may not be available.
murf427
Aug 03, 2012 | Fellowes SB95C Cross-Cut Shredder
Fellowes S8-95C is full, but can't get it open. Help!
I was able to pull really hard and open the bin 1-2". I turned the unit on its side over the trash can and some shreds came out. I alternated shoving a sturdy metal rod inside (first an aluminum architectural ruler then the longer handle of a squeeze clamp) to loosen up the shreds and tipping the machine on its side to get some loose shreds out. After doing this enough times I was able to dislodge the dense clumps and remove the drawer. Now that the machine is empty there is a red light on and it does not shred.....UPDATE: turns out somewhere along this rough process (paper was in rock solid clumps) a small piece of the door that presses the "door closed" switch broke off. Jammed a piece of cardboard in there and it shreds again, although it does not automatically turn off when the door is open.
Jun 30, 2011 | Fellowes SB95C Cross-Cut Shredder
Part #540307-1 broken
Here is a link you can get the whole gear assembly for $30: www.sportslinkup.com/shop/0-Fellowes-gear-1.html (P-55C Gear Kit for Fellowes Shredders part #205993).
I need the same for my Fellowes P-57Cs shredder, same broken gear 540307-1
Sep 26, 2010 | Fellowes Powershred P-55C Shredder
Paper is passing through shredder without being shredded
Damaged bearings on the cutter shafts have allowed gaps between cutter shafts to prevent proper shredding, I think.
Apr 30, 2010 | Fellowes SB95C Cross-Cut Shredder
The blades do not turn
Any motor noise at all? Any lights? Have you tried the basics? Clean the sensors with swabs and alcohol.
Jun 22, 2009 | Fellowes SB95C Cross-Cut Shredder
Shreds halfway, then stops. Fellowes SB-95C
on the underside of the shredder, at the top of the space where the cuttings box is, there are 2 sensors, 1 at either end of the shredder blades. it sounds like these sensors could be either dirty, or defective. try to clean these with a cotton bud or similar. it may need new sensors, bu it is worth a try!
Jan 30, 2009 | Fellowes SB95C Cross-Cut Shredder
Fellowes SB95C Cross-Cut Shredder Logo
74 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
steve morris
steve morris
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
