Question about Poulan Pro PP4620AVX 46cc Gas Chainsaw With 20" Bar
My poulan pro pp4620avx leaks oil when not even running
  • 641 Answers
SOURCE: POULAN PRO 295: RUNNING VERY STRONG, FOR OVER AN
Remove the air filter, squirt a little fuel into the carb. Start and let run if it will for a few minutes. Could be you had some water in old fuel. and it is still in the intake of saw. If it still will not run after squirting some fuel into carb. You have a firing problem.
Posted on Apr 07, 2009
dontbother10
  • 2220 Answers
SOURCE: I have a Poulan Pro 380 that is leaking bar oil.I
I have 7 chainsaws. 6 of them if I forget to drain the oil reservoir will oil the surface of what they are sitting on. What you are seeing is normal.
IMO; use of the oiler creates a siphon. Any oil left in the tank will continue to siphon until the reservoir is empty. I could be wrong, I have been before.
Draining the tank works, nothing else I've tried does. HTH
Lou
Posted on Nov 06, 2009
SOURCE: Poulan prochain saw I need the wheel for the chain tensioner
Dontbother -- I'm in the same boat and would LOVE to convert to a more failproof chain tensioner. Details please! thanks
Posted on Apr 18, 2010
dontbother10
  • 2220 Answers
SOURCE: Poulan Pro Chainsaw chain tensioner is junk
Hammy if you scream loud enough Poulan may foot the bill for this.
Poulan “PP4620AVX” IPL (exploded parts list)
We are going to replace this page 2; item 70
http://weborder.husqvarna.com/order_static/doc/NIUS/NIUS2009/NIUS2009-PP4620AVX-545103410-952802169.pdf
Poulan “PP4620AVHD” OM
http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2005/NOUS2005_545047502.pdf
Poulan “PP4620AVHD” IPL
http://www.ordertree.com/modelinfo/PWE/PP4620AVHD-Gas-Saw/75.PP4620AVHD-Gas-Saw.1.59.1.html
With this; “Handle, Chassis & Bar Assembly” print; item 67; ChainBrake Assembly; $21.83.
You also need;
  • Item 68; Bar Mounting Nut; $0.56 each (need 2) and
  • “Engine Assembly” print; not illustrated; part number 545006011; Scrench; $9.75.
This is the configuration professionals have used forever. The only thing to remember here is to hold the nose of the bar up when adjusting and tightening the bar nuts.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Testimonial: "Thanks -- that's exactly what I was hoping to find. It's wonderful to be able to tap into expertise like this. Very Happy!"
Biggdex35
  • 333 Answers
SOURCE: need gas/oil mix for poulan pro pp4620avx 46cc
3.5 fl oz to 1 gal gas.
40 to 1
Posted on Jun 02, 2010
Poulan pro 46cc will not idle
fuel pump in carb is hard and not pumping. rebuild carb
Oct 07, 2014 | Poulan Pro PP4620AVX 46cc Gas Chainsaw...
Poulan pro troubleshooting
CHAIN STRETCHS AS IT HEATS - KEEP CHAIN TIGHTENED CORRECTLY AND ALWAYS KEEP OIL IN OILER AND MAKE SURE IT OILS THE CHAIN. IF THIS DOESN'T FIX - REPLACE THE CHAIN. IF IT STILL HAPPENS THEN REPLACE BAR. WILL FAIL AGAIN WITHOUT OIL. POULAN WILL NOT HOLD UP WITHOUT CHAIN LUBRICATION. WORSE THAN OTHERS. IF CHAIN OR BAR OVERHEATED YOU'LL WORK ON IT MORE THAN YOU CUT. OIL IS THE KEY TO CUT WITH A POULAN!
Aug 10, 2014 | Poulan Pro PP4620AVX 46cc Gas Chainsaw...
Oil to gas ratio for craftman 46cc chain saw
Run it on a 25-1 fuel oil mix with a two stroke oil designed for use in chainsaws.
Jul 08, 2012 | Poulan Pro PP4620AVX 46cc Gas Chainsaw...
What size of chainsaw file do I need for poulan pro PP4620AVX
hi there susan brown6
if your chain is a 3/8 lo pro chain the file will be 5/32nd ------- and if its a 0.325 size use a 3/16th file -------- or if its a 3/8 -0.58 chain use a 7/32nd file
but its more likly to be either 5/32nd( for 3/8 low pro chain ) or 3/16 th for .325 chain
cheers
pauly46
Sep 10, 2011 | Poulan Pro PP4620AVX 46cc Gas Chainsaw...
I would like to see part digram? for poulan PRO 20"
Poulan currently offers 2 46cc 20" bar chain saws which are virtually identical
model PP4620AV, and PP4620AVX
http://weborder.husqvarna.com/order_static/doc/NIUS/NIUS2009/NIUS2009-PP4620AV-545014314-952802075.pdf
if you are looking for a different diagram please include the model number you need in the post.
Thanks
Dec 28, 2010 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro Chainsaw chain tensioner is junk -- chain now goes from tight to falling off in 1 cut. Model PP4620AVX. Looking for more foolproof mechanism!
You also need;
Lou
Apr 18, 2010 | Poulan Pro Chain Saw 46cc 20"
Need chain adjustment wheel part # for poulan pro model pp4620apx chsain saw
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
I think this is the what you seek:
http://www.ordertree.com/modelinfo/PWE/PP4620AVX-Gas-Saw/75.PP4620AVX-Gas-Saw.1.59.1.html
The "Handle, Chassis, and Bar Assembly" detail
Items 63 through 69 are parts, I think item 70 is a complete assembly ($22.78 without a kiss).
Your saw without tooless adjustment.
Item 64 (complete assembly) $2.53.
If my saw I'd ask if it can be modified!!!
http://www.ordertree.com/cms/parts-lookup-help/73.html
I suspect a vert simple modification. HTH
Lou
Nov 18, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro PP4620AVX 46cc Gas Chainsaw With 20" Bar Logo
46 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
