Question about Grohe Grohmix Thermostat Valve & Trim - 34436
I have a grohe shower tharmostaic valve with a water flow handle on top and a temperature handle below it. I do not know the model number. The temperature of the water is increasing each time it is used. I keep turning towards cooler water to correct the temperature and am now almost to the maximum cool setting. The water is still coming out hot. What do you think is wrong and how do I take it apart to fix it?
2 Suggested Answers
SOURCE: Installed new cartridge in grohe shower valve.
low pressure
Posted on Jun 23, 2011
Could my grohe thermostatic shower be letting cold water into my system? Some other taps run cool but the shower is running OK temperature
If you have single handle facute one bad cartridge in the system may be acting like a mixing valve and allowing cold water to mix with hot not allowing water to get hot enough .
Mar 10, 2015 | Grohe Water Heaters
My contractor installed a 4 port diverter. The hot and cold are ok, but when I turn the shower on, the flow starts in the hand held shower head and not the main shower head. According to Grohe, whichever...
I haven't had a lot of experience with Grohe brand but have had twenty eight years as plumber, 22 years as master plumber and the bottom port of every tub or tub/shower valve that I installed used the bottom as main supply port. As far as the instructions from manufacture like I said I have not used that particular brand much,so I really couldn't say. Hope this helps some. Thanks
Nov 10, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
Final install of handle ,control valve etc.
If you but a trim kit it has the installation instructions for the trim with it. Did you open the stops to let water in?
Jun 28, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
Install trim and adjust the thermostat on a Grohe shower faucet
Before you install the temperature control knob, adjust the valve body (47111) with a wrench to set the temperature to "100 degree or close to it". Now, place the limit ring to tdc (top dead center) and control knob with the red 100-degree align to it. Your problem may have been the valve's temperature setting is out range when you installing the temperature control knob.
Jun 28, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
Grohe valve Grohtherm Thermostatic Rough 34-126 I turn the mixer to full hot but the temperature remains tepid. All the other faucets in the
The thermostatic stop is set too low. Havent set a grohe before but most other thermostatic shower valves work similar. pull off the handle(however a grohe handle comes off . . ) there should be a notched ring or stop which keeps the handle from going all the way hot. pull out the ring and turn it a few teeth hotter put back and reinstall handle try water temp and adjust again if necessary.
Jan 23, 2010 | Grohe Grohtherm Thermostatic Rough-In...
The temperature in my shower is very luke warm only at the shower
Do you mean the other faucets in the house are hot and only the shower is warm? If so there is an anti-scald adjustment on the faucet that needs to be turned up a few notches. Havent adjusted a Grohe faucet but most faucets you rmove the handle and behind the handle is a nothced adjustment ring that prevents the faucet from getting too hot. This ring, or stop, is pulled out and twisted clockwise(or counter clockwise to set higher or lower max temp, then pushed back. maybe you can look up grohe to see which way ring or stop adjusts for hotter water.
Jan 23, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
Flow of water thru shower head is barely a trickle
There is a chance there is mineral deposits in the showerhead openings. You can try products sucha as limeaway by unscrewing the showerhead , soaking in the limeaway for a few minutes and rinsing with water. You may have to repeat this a few times to get it clean.
Jan 20, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
Grohe shower. I want to adjust the temp mixing valve. I can not get cold water. It is always a mix-never pure cold. I want cold water. How do I adjust it?
if you pull the handle off all the way back to the valve body there is a little black stopper around the cartridge body that you can adjust by pulling it out and sliding around the cartridge body this enables people to just turn the handle to one setting and jumpping in to their favorite temperature. in your case it doesn't allow you to have any cold water. so turn it one way see if you get what you want or try the other or some of them you can even just take the darn thing out and not even have to worry about it
Jul 29, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Installation problem: Grohmix shower valve 1 1/2'' extension
This is what you should have... Grohe Grohmix Thermostat Valve & Trim - 34436
  • Paraffin cartridge
  • Lever volume control
  • Grip ring temperature control
  • 1/2" NPT female connections
  • Service stops
  • Includes rough-in valve and trim
  • Integrated temperature and volume control
  • Requires Twin Ell (03 671) for shower/tub combinations with diverter spout Note:
  • Grohe Grohmix Thermostat Valve & Trim - 34436
    Mar 26, 2009 | Grohe Grohmix Thermostat Valve & Trim -...
    Grohe Grohmix Thermostat Valve & Trim - 34436 Logo
    52 people viewed this question
    Top Grohe Water Heaters Experts
    Paul Carew
    Craig Butler
    Craig Butler
    ray gallant
    Are you a Grohe Water Heater Expert? Answer questions, earn points and help others
