SOURCE: Using SB 800 flash Master with 2 SB 600 as slave
Hi Frank, I use the same combination of the exact three flashguns you have. Works beautifully. I mount the sb-800 on my camera and set it to Master Mode (press and hold the center button till the menu comes up, select the master). Set the other two sb600s as slave. Please make sure the channel is set the same in all three flashes... when positioning the slave flashes, make sure that sensors on the remote will recieve the light from the main flash. For maximum coverage I use the sb-800 with a diffuser in bounce mode. You will be amazed at the quality of interior phots you can get with a 3 flash combo.
SOURCE: sb-800 sync
Make sure the slave is not set to rear curtain or slow flash. Otherwise
Send that back to Nikon for service. http://www.nikonusa.com/Service-And-Support/Service-And-Repair.page
