Question about Invacare Lynx Lx-3 Scooter Model Sc3-78-bs1
WHEN I TURN ON IGNITION THERE IS A WHISTLING AND THE SCOOTER DOES NOT OPERATE
THERE IS NO MORE TO ADD EXCEPT WHAT DO I DO TO STOP WHISTLING AND MADE SCOOTER GO
When I turn it on an alarm sounds and won't stop. The scooter works well except alarm won't stop. It is as if you are pushing on the horn all the time.
hi Irene, sounds like you got water inside the button you push to activate the horn, the push button will need be dried out ....either by disassembly's or carefully placing a warm setting hair-dryer near the button and operate to get the water to evaporate .. but don't do it too hot otherwise the button will start to melt...
Regards
Rob
Apr 05, 2016 | Pride Go-Go Sport 3-Wheel Scooter
Why does my scooter make whistling sound going uphill?
A strain on the drive system will cause wear in the drive train, the brake can cause this. take a look at it to see if it has turned blue or rusty. a hanging brake will make high pitch sounds and put a drag on the speed.
Nov 06, 2015 | Health & Beauty
Why does my scooter run too slow?
Needs a check-up on the motor brushes.
Keeway hurricane 50 .the electricty went off suddenly
Hello and happy thanksgiving from the USA.
I would suspect that you have a defective igntion switch, the igntion switch is what powers up all of the electrical system when you turn the key to run, the contacts can get burnt or the connector or both. The switch is under/behind the ignition key cylinder which operates the switch or course.
Nov 24, 2011 | 2008 Keeway Hurricane 50
I have a celebrity scooter that powers up great and every thing seems to operate properly except it will not go forward or backward. It makes no sound when engaging thumb switch.
Make sure the drive lever/freewheel brake is engaged. Usually it is on the lower back bottom of the scooter or check your owner's manual.
Oct 29, 2010 | Pride Mobility Products Pride Celebrity XL...
I have a 2004 Honda Pilot. Whenever I use the front windshield washer, the wipers just keep going and don't turn stop until I turn off the ignition. Also when I turn the wipers on and turn them off they...
try renewing the intermitant relay for the wipers ,never worked on one as yet so i have no idea where the relay will be ,but just turn ignition on operate the wipers and listen for it
Jan 23, 2010 | 2004 Honda Pilot
When I stop the scooter after travelling a short
Hi. Yes, most, but not all machines have a "sleep" mode. More for safety than any other reason. Neil .
Oct 31, 2009 | Electric Strider Maxi 4 Wheel Mobility...
Maxi strider scooter
Hi
Are you sure it 's the cable ? and not the wig wam or throttle speed pot that you operate with your thrumbs.
Regards
GeWiz.
May 03, 2009 | Electric Strider Maxi 4 Wheel Mobility...
Invacare Lynx Lx-3 Scooter Model Sc3-78-bs1 Logo
19 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
MobilityRepairSpecia...
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
