Question about Ovens
Not working making noise
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 107 Answers
Not enough info
Posted on Nov 22, 2013
I can't make it stop , Its supposed to be off , minute minder is off as well as the auto control center . I just can't make the start time to go off , I hear noises ,like ticking noise.
if all elements are not warm then there is no quantity of power being used
have an electrician check out the stove as it may be a faulty minute clock
check around the room for a clock that is keeping the time as that is a ticking noise even though it is battery operated.
May 21, 2015 | Ovens
When I turn on the self cleaning oven, it makes a loud buzzing noise. Is this normal? If not, what needs to be fixed and how do I do it?
The buzzing sound comes from the relays located on the control board. Remember, the oven gets very hot during self clean, so the control works at full speed to get all the elements working.
Jan 03, 2015 | Kenmore 30 in. Electric Self-Clean Single...
Noise when oven running and stops when oven stops
Is it a convectional oven? If so, this is the fan turning on to circulate the heat. Being an electric oven, there really shouldn't be any noise whats so ever when on. I suspect your have a convectional oven and the fan is making the noise...either because it is working fine...or because its not and needs to be replaced.
Dec 02, 2013 | Thermador SC272T Electric Double Oven
What wrong when a jenn air convection over fan make noise
What kind of noise? Has the type of noise it's making different now then previously?
Nov 19, 2013 | Jenn-Air Ovens
Hotpoint BD32 built in oven is not heating up anymore, top oven/grill works fine. When it's switched on it makes the right "noise" but there is no heat or light. Is this an element problem?
you can check the element, just get a volt ohm meter, set to ohm's and make sure it shows a short, otherwise you have an open or bad element.
Nov 06, 2013 | Ovens
I have a lamona hja3400 oven and the element has stopped working. I'm trying to get the element out but it seems to be fastened on the back of the oven not inside it as with other types of ovens. Does...
hi my lamona oven started to make a noise like a pinging noise it was working the noise would come and go it would get worse half way through cooking. but last night the noise seemed to have lasted longer and the oven knocked itself off any ideas what the problem could be.
Aug 30, 2013 | Ovens
720 EF Fan oven fan making a scrreching noise now
It could be that cooking residue has run down the inside of the fan cover and it is restricting the fan movement. The fan cover is held on by four self tapping screws, one on each corner. Remove the cover and have a look to see if there are any rub marks on the inside. You should be able to remove some of the gunge by soaking the the whole cover in hot soapy water. If that doesn't work, buy the Lakeland brush on oven cleaner - that definitely works - you can use it on all of the inside of the oven. Whilst the cover is off, briefly turn the oven on to see if the fan still makes the same noise. If it does, it looks like the fan bearings are suspect and a new fan may be required. If not you have found the problem with the cover. Page 37 of the Handbook tells you how to replace the circulating fan.
Sep 23, 2009 | Stoves 720EF Electric Double Oven
Over the range Whirlpool microwave model# MH6600XX is not heating and makes a loud noise when running. It seems to work on ''Quik Defrost'' and doesn't make the noise on this level, but the other powers...
hi..Your micro hood is "shot".so it is not working properly.
The food may not be heating,but the electrical and the walls
of the unit might heat.This may cause sparking and melting
of the interior of the unit.
check it out..
thank u..
kindly rate my response..
May 09, 2009 | Ovens
Fan making loud noise
Hi
does the noise start as soon as you turn the fan oven on?
does the noise stop as you turn off?
just depending what make and model you have there is two fans
in it 1 is the fan motor inside oven at back and other
is the cooling fan which is at top of oven .you just need
to find out which one it is and just replace . then should be back to normal
regards dan
Mar 19, 2009 | Belling XOU174 Electric Single Oven
Ovens Logo
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
