Question about Sylvania Electric Stove Heater Model SOQC935-MBK
My electric stove heater emanates a very bad smell when I turn on the heat and it does not go away, we are not sure how to fix it
When I turn it on, the stove emanates a bad smell that does not go away, it permeates the room and continues
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
All 4 rings get extremely hot immediately and don't cool down.
Appliance Science: The hot physics of induction cooktops ...
www.cnet.com > Appliances
CNETJan 12, 2015 - Induction cooktops don't heat up themselves: they create heat in the base of the cookware. ... the cookware, and so react quicker when you turn the dial up or down. ... US consumers don't like them because they grew up on gas rings. ...pans, they don't get hot when you put them on an induction cooktop.
4 Lessons I Learned From My Electric Stove - Life in the ...
www.thekitchn.com/why-im-grateful-fo...
Apartment Therapy's The KitchnFeb 24, 2015 - Electric stoves don't have a lot of redeeming qualities. ... "low" burners rather than wait for the front burner to sufficiently cool down. ... burner for all my cooking, as I did when I cooked on a gas stove. ..... I was used to looking at the size of the flame to gauge how hot it really was, I never looked at the dials.
Moving From Gas to an Electric Stove: What I've Learned So ...
How to Fix Problems With Burners on an Electric Stove ...homeguides.sfgate.com > Landlords & Tenants > Landlord ProblemsElectric stoves rely on electrical resistance to heat up the burners on the cooktop, which means they function much in the same way as electric heaters. ... When one of the burners stops working, you can usually trace the problem to the burner switch, theburner receptacle or the ...Electric Range Stove Repair: How To Repair Burner ...? 6:52https://www.youtube.com/watch?v=ndQU7RtqfRwJan 31, 2012 - Uploaded by applianceassistantHow to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... How To Test Stove ...Fixing Electric Stove Burners that Don't Heat Up Properly ...? 2:34https://www.youtube.com/watch?v=GfqaPcha__o
Dec 15, 2015 | Kitchen Ranges
2 hobs on my electric cooker are not working
? 2:34
Jul 2, 2012 - Uploaded by SamuraiRepairman
Fixing Electric Stove Burners that Don't Heat Up Properly ... Coil Surface Element Test - Electric Stove Repair - Duration: 2:04. by... Temporary Repair For Electric Plug In Range Stove Surface Element Burner Not Working ...
? 6:52
How to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... More Range and Stove Troubleshooting, Repair Help, And ... Fixing Electric Stove Burners that Don't Heat Up Properly - Duration: 2:34. by ...
Oct 26, 2015 | Ovens
Sylvania electric stove heater, black (model SO111R-MBK) stopped working
Got a stove electric space heater But it will not trunk on just the flame button but no flames and no heat what can I do to fix this .boxes the remote control have to light up....Albert Gomez..2124 North Keeler ave..Chicago Illinois..60639...18722062470.....
Dec 08, 2012 | Sylvania Electric Stove Heater, Black...
How can i get rid of a nasty smell of mice urine out of my stove? its a self cleaner but that didn't work
Vinegar with heat and then lavender essential oil with fresh thyme sprigs worked. Try it.
Feb 04, 2018 | General Electric Ovens
I have a Dimplex Ritz electric 2000w heater that is only working on the low 1000w setting. When the high setting is selected it auto turns off and there was a funny smell which I am assuming a fuse has...
Yes, it can be repaired, if Dimplex still stocks that particular heating element. It's not to difficult to replace the heating element, just mark all the wires before removing the old one. Also, it will require removing the logs inside the heater, because you will need to turn the stove upside to do the removal and replacement. Contact Dimplex Technical Support at 1-888-346-7539.
Hope this helps you.
Jul 06, 2011 | Dimplex Compact Electric Flame Stove...
I have a Dimplex Small Electralog Stove Fireplace CS1205, it's two years old but barely used until this winter. A couple months ago, the flame stopped working and now the heat keeps turning off after 5...
More than likely, the interior of the unit needs to be cleaned. When it's in operation, it sucks dust and link into the fan and heater elements. When it's not, spiders love to go into and build nests. If badly clogged, it can cause the heating element to over heat and shut off. Carefully, removing the back panel of the stove will give you access to just about everything. As far as the flame is concerned, the bulbs may need replacing. Although, it's unusual for all of them to go bad at one time. You or your nephew can replace them after the unit is cleaned. A vacuum that has a hose, brush attachment and crevice tool, will work well in the cleaning of the interior. Be sure to turn the Master ON/Off Switch to OFF & Unplug the unit, before attempting and maintenance on it.
If after performing all of the above, the unit still doesn't work properly, contact Dimplex USA, Technical Service 888-346-7539, for further advice.
Hope this helps to solve your problem. Please let me know.
Mar 17, 2011 | Dimplex Compact Electric Flame Stove...
Electrical burning smell in house
Mhenn, It is my guess that the 'electrical burning' smell is from your heating system. Since there is no smoke and the walls are not warm.... then there is no real problem. The smell maybe just dust has collected in the duct work that is burning off the central heating systems electrical heat strips. If you have electrical heat strips then that may be the problem. If you have a central gas heat system, it may be the same type problem. Hope this helps you. Henry
Feb 05, 2009 | Honeywell Electronic Programmable...
Fuel Oil Smell in House
With any internal combustion devise it needs oxygen to combust the fuel, I suspect that your house is sealed shut to keep out the cold.  I suggest that you raise a window slightly so as to cause a draft for the heater. Be sure that the raised window is not between people and the heater because the cold air will pass over them and they will get very chilled.
This is the same fix for smoking fireplaces.
Jan 29, 2009 | Rinnai Toyostove Direct Vent Heater:...
Extreme heat, electrical smell
there could be lint on the heater also. clean if ve t-statso. you could also have a defecti
Feb 18, 2007 | Kenmore 84152 Electric Dryer
Sylvania Electric Stove Heater Model SOQC935-MBK Logo
Top Sylvania Home Experts
john h
Tom Chichester
Are you a Sylvania Home Expert? Answer questions, earn points and help others
