Question about Echo Pb-403T Leaf Blowers
Throttle cable connection to carburetor
I need to see how it connects
How do you put the throttle linkage on to the carburetor on a model 51 w/zama carburetor?
Husqvarna 51 55 zama Chainsaw Carburetor
if like most carbsy connected before fitting
looks like only one hole for a wire or throttle cable
Nov 02, 2016 | Garden
Ryobi weedeater throttle not working
Check the throttle cable connection at the carburetor throttle linkage, it (cable) may be broken or the carburetor linkage is broke.
Jul 09, 2016 | Ryobi Garden
Model pp4218 throttle stuck open
I assume you are referring to a pullen pro chain saw. If so, the cable that links from the trigger to the carburetor is stuck. This can happen due to trash and dirt stuck in the trigger area, or the carburetor needs cleaning. Or the cable or wire to the carburetor is bent. See if the connection between the trigger and carb moves freely when not running.
May 02, 2016 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How do i disconnect the throttle cable from the carburetor so that I can take out the carburetor and clean it.
the throttle cable DOES NOT attach to the carb on that engine. It attaches to the control panel underneath the carb. you have linkage rods that connect and they either have clips or you need to pull the carb mounting studs
Oct 18, 2014 | Husqvarna Garden
Tiller runs at full throddle and tines continue to turn. Unable to lower throddle. What do I do?
Sounds like the throttle cable is sticking or the carburetor butterfly is sticking.
Squirt some WD-40 into the cable that attaches to the throttle handle and onto the mechanism the cable hooks to at the carburetor. Carefully actuate the throttle and see if the mechanism is moving smoothly. It may need several squirts and some actuation before it become free.
Jun 08, 2014 | Mantis 2-Cycle Tiller
Engine Rev goes too high while starting
have tried lubricating the throttle cable and twist grip mecanism , is the cable routed correctly and no kinks in it ? where the carb fits to the engine check the rubber mount has no cracks or holes as it will draw more air than needed !
Apr 14, 2014 | 2006 Bajaj Wind 125
Throttle accelator
The throttle cable could be disconnected under the hood, the cable that connects to the throttle body or carburetor. The part where the air cleaner is attached or goes too.
Nov 05, 2013 | 2011 Ford Transit Connect
How much does a trimmer throttle cable cost?
A trimmer throttle cable can cost anywhere from $10-$25.
Jul 15, 2012 | Stihl Trimmer Throttle Cable Km 40 50 56...
Loose gas pedal, i need to push accelerator farther in
the gas pedal is connected by a cable that goes to the throttle body or carburetor on the engine. there should be a nut that holds the cable end in place where the steel cable comes out of the housing near the throttle body. it sounds like this may be loose or stripped out. you may need to replace the entire throttle cable.
Feb 17, 2010 | 1984 Toyota Xtracab
I need to how to connect the throttle to the carb on a briggs and stratton riding mower a diagram would be great.
Don't have a diagram. It's pretty simple, tho.
There is a throttle cable run from the throtle control lever on the dash down to the carburetor. There is a lever on the carburetor -- usually this has a hole in it where the end of the throttle cable hooks.
There should be a clamp in that vicinity to hold down the throttle cable housing to allow the cable inside to move back and forth without moving the cable housing,
May 06, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Echo Pb-403T Leaf Blowers Logo
29 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
