Question about HP 15.6" Compaq Presario CQ58-A10NR Laptop PC with AMD E1-1200
Doesnt swich on
I pluged it in it shows amber light where its connected to the power lead, and when I puch the on button it lights up for a couple of second and it goes out, but the screen stays black, you cant hear the fan starting, neither can open the cd-room. So it looks like its frozen compatley. But its brand ne, been used before a couple of time. What might be its problem, and what can i do about it to start it up again
  • HP Master
  • 2,001 Answers
This pc sold from 2012 to 2014 and is NOT NEW, at all.
sold with W7 and W8, only, new all have w10,
And HP does support still. (my guess till 2024)
no operating system stated by you btw.
ok,, I do the dead only.
wow a real service tag model stated. super good that.
can I assume the screen never ever show even 1 line of text?
ill assume that is true, and respond, i cant see your screens. so..
how to fix a LT , that is I presume DEAD .? black screen
simple steps on all DEAD LT
  1. take out the battery does it work now y/n???????
  2. does the ESC key BIOS key work? power on hammer ESC or F9 or F11, if those all work the BIOS IS GOOD and power is ok
  3. if BIOS is dead the power pack is bad. (or worse, worse in not limited at all with over 3billion transistors inside.
  4. see this?
The power pack is bad if the PC will not run with AC only. battery out.
the pack can be bad. AC line pack its like $15 , vastly less than the typ. $300 shop labor charge alone..
your support page is below!
Posted on Jul 27, 2017
  • Larry Ng
    Larry Ng Jul 28, 2017
    battery out first, start NOW?
    then power pack ok./ test it replace it if the BIOS is dead, BIOS screens are the first things that must work.
    this has a CCFL back lamp, LCD display
    if the CCFL goes bad, its black screen for ever.
    but you have a shorted battery take it out
    if still not run the power pack is dead
    the fan must turn ! spin,
    also all laptops are full of lint ,ever seen one not packed full. of lent
    clean that first. as lint packs the fan up.
    making me think power is bad when not .see?
    if BIOS IS DEAD totally (hit ESC to inter hp setup) not seen on the display is , lost of power
    or the CCFL tubes are gone.
  • 218 Answers
SOURCE: Blank/Black Laptop screen on HP DV-6000 notebook
Your symptoms sound like a known issue with the dv6000 series of HP laptops. Rather than go into a lot of detail here, let me just refer you to the HP web page about the problem. If it fits your situation, call HP at the special number shown on the page. They've been replacing motherboards even for units more than a year old. My son just got his back yesterday, and so far so good. I hope this helps.
Posted on Dec 26, 2008
  • 2002 Answers
SOURCE: on my laptop the vent fan starts then stop and the power goes out
These machines have a terrible overheating problem! You will have to clean the fan opening and, put sylicon grease on the heat pipe and, heatsink that covers the cpu
Posted on Apr 21, 2009
SOURCE: HP Pavilion dv 9205 us tries to start up, screen stays black
THIS IS A LONG REPLY POST BE WARNED : HOWEVER IS LIKELY HELPFUL TO OTHERS WITH INTERMITTENT LCD / PORT ISSUES. MY STORY,... Hi all. Ok, i'm gonna chime in here on this. I have the HP DV9205us and i've returned my unit a total of three times. Ultimately I was told (under warranty for 24 ms) that it will likely need to be repaired due to same intermittent display and other intermittent issues with most ports. I had three different people 'working' on it. Uh-huh. They advised it would likely need to be replaced. I sent it in. Two weeks later I got my same laptop back. The billing sheet was $0.00 however, it stated they replaced the MB, HD, memory and LCD. The first repair was exactly what you're commenting on for intermittent ports and most notably display failure at times. I, again went through phone troubleshooting with them. Had to send it in a second time for same issue. They then told me they had to replace the MB and memory this second time. It worked for awhile. Within a few weeks (maybe five) the same issue happened. However, accompanying the intermittent issues was a serious heat problem. My unit was running VERY hot. In fact one of the ports actually melted the plastic side face. They asked me to send it back a third time and the billing sheet went down the list of everything replaced. MB, HD, memory, LCD and this time replaced the power supply. Hmmm,... I though to myself. My unit overheated to the point of smoking and melting. They've now replaced everything at least twice or more. Now they have basically given me a whole different laptop with piecing it together and now my case is melted. I contacted them and they advised that it was 'cosmetic' and not covered by my extended warranty. I wasn't pleased to say the least being that they pieced together my supposedly new laptop over the course of hit and miss at my expense of course (time without laptop). I told them I took the extended warranty for almost $300 extra dollars and was told it was covered for EVERYTHING except intentional damage. i even bought the high joules-rated power compressor, blank media, screen wipes, plate cooler, etc. It didn't matter, he didn't relent. I was keeping this laptop. He stood his ground. Whatever my case may be it's not going to be as agreed. So, I moved on to the second question. Why was my power supply replaced the third time and not the first time? He began to state it was customary to troubleshoot in a chain method until it's resolved. I then posed to him, why they sent me a differnt power supply this time. Different model than I was sold. He stated it was the same model. I told him I recorded everything for my insurance and it includes serial / model numbers. He read to me what the model of the PS should be and asked me if that's what I have. Of course i've got that one now. Why was I sold a defective PS in the first place. To me, it's very clear that my problems were resolved not by replacing everything in the pc. But by starting at the most common sense place. The power distribution from the wall pack or the MB. Nothing more. To me it was overkill to replace EVERYTHING multiple times. It told me HP didn't know what they were doing. It was a clear sign of that.
As of this date, I have had a functioning laptop without intermittent problems. No longer overheating and still am reminded by the scars on my melted case. Cosmetic? Umm,... I think that's why they spend millions marketing colors and flashy things. The look is what brings customers to see what the laptop offers. I actually researched HP and am a Sony guy typically. I bought my wife the Sony and I bought my HP. I waited two years to make the decision. I not only took the leap, I also took their full coverage option. I feel taking a laptop without the + warranty isn't smart investment. It depends on how mobile you'll be. Many people are business, as am I. Downtime is critical. Needless to say, I got no appology from HP. Meanwhile, my wife has yet to even reformat her HD again. With a year plus in my pocket, i've had to personally reimage four times trying to troubleshoot with them on the phone. Also, the two or three HD's they put in.
The long and short of it. HP took me for a ride. I sat patiently. I did everything they asked. I went without. I payed additional. In the end, I have a port module melted that reminds me every day that HP will not be welcomed anymore. I am sorry to kick them to the curb, but going off of how I was treated and the idiocracies they subjected me to in troubleshooting, i'd venture to guess many of you feel the same way. I'm sure mine is a little more labor intensive. I just want you to know your complaints didn't fall on deaf ears. HP abandoned the 9205 and I haven't found quite the same problems with the newer models. Aside from my treatment, I love the look and feel of HP. I have fourteen Sony products in my home entertainment system. Guess where my first look will be in the future of laptops? I shouldn't have strayed. My wife is plenty happy and i'm jealous.
Maybe the PS issue is related. Maybe ohm and test it for output. Most techie nerds you know can do this for you. Look for intermittent power delivery. HP never acknowledged the problem in writing. I couldn't even get them to acknowledge my question on the phone. It was the slippery-trickery on the phone. So, i'm passing it on. When I troubleshoot such problems in the future. I'll start at the most obvious. However, I have no problems with any Sony products nor my wife's (Sony) laptop. So, I don't figure on having it happen ever again. This is likely helpful to a variety of laptop owners with intermittent LCD / Port issues. Glad to help.
Thanks for allowing me to vent. I think I feel better. No wait,... may be the whiskey.
Posted on May 14, 2009
  • 33 Answers
SOURCE: hp dv6000 won't start up at all, lights turn on, then off
You may need a new power supply, It may be putting a bit of power out but not enough to run thr comp
Posted on Jun 15, 2009
  • 61 Answers
SOURCE: compaq presario cq50-100em wont start up
I'm sorry to say this sounds like a system board failure. On my HP DV200t, a very similiar issue occured, eventually only the led where you plug in the power cord would turn blue. I replaced the system board and all the issues went away.
Hope this helps, and I am sorry to be the bearer of bad news.
Posted on Aug 31, 2009
Amber light contineu glow
The amber light verifies your monitor is connected to primary power. The internal power supply is dead, otherwise the amber light would change color when the switch was operated.
Sep 02, 2012 | Acer AL1916W 19" LCD Monitor
My tv showing an amber light instead of red standby light and now it won't switch on
Good day!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 20, 2012 | Televison & Video
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
If this the light is solid amber in the front of the computer.Try doing the following steps
1. Disconnect the power cable from the back of the system tower. Press the power button on the tower 30 seconds.
2. Reconnect the power cable to the back of the system tower and power it back on.
If the amber light is on the monitor power button and the tower power button is off or blinking amber it could mean that it is a bad power supply.
Thnaks for using fixya
Aug 10, 2010 | Computers & Internet
My Laptop doesnt start at all . I dont know what
1. remove all ext peripherals
2. remove battery
3. check first the ac adapter if it has led on (make sure ac adapter is not connected to the laptop)
4. try any other wall socket check if ac adapter will led stay on
5. if ac adapter stayed on then connect to laptop (without the batter)
6. after connecting the ac adapter to laptop check if the ac adapter led turned off, if yes then check ac adapter laptop pin on the side if is loose or damage.
7. if ac adapter stayed on after connecting to laptop press now the power button on the laptop just once. check if the power led on laptop will turn on (check if power led stays on or it blinks amber)
8. if it blinks amber then remove all CRUs such as dvd drive, memory, hard drive and wireless cards. put them back one at a time. make sure you turn off laptop when putting removed hardware. this will check and isolate which causing the power led to blink.
9. if the power led stays on then turn it off again then wait a couple of seconds then press and hold on Fn key then press power button. wait for about 5 minutes while the power led is steady on, until you hear beeps once you hear beeps it means that LCD has problems. try then connecting laptop to an external monitor if it shows display there. press on Fn + F8 to toggle the display from LCD laptop to the ext monitor. if no display replace the motherboard. if it has display replace LCD.
Oct 15, 2009 | Dell Inspiron 6000 Notebook
Monitor comes up white on computer start up
see if you have bent pins on cable.
Aug 19, 2009 | X2Gen MW22U Monitor
Amber light on power button
Check to see if there are any loose connections to the memory cards on the memory board. Make sure the data cable to the drives are connected properly. Is the fan in the power supply on?
Jul 27, 2008 | Dell Dimension 8300 PC Desktop
HP 15.6" Compaq Presario CQ58-A10NR Laptop PC with AMD E1-1200 Logo
24 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
