I have a samsung eco bubble washing machine and it stops and displays suds on display
  • 66 Answers
SOURCE: Whirlpool duet washing machine
noisy may be the tub is hiting some thing. you can open the top of the washer and ck. it is very simple. sud are you using the he soap.
Posted on Feb 16, 2008
SOURCE: washing machine displaying E90 error
an E90 fault is a problem relating to the main control module found behind the front facia. it could just be a bad connection on the board connections though
Posted on Dec 13, 2008
Krazytech
  • 725 Answers
SOURCE: washing machine whirlpool awm8123/1 stopped and FH on display
If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed. OR If the control has turned the water valves on and after 8 minutes the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. Press PAUSE/CANCEL twice to clear the display.
check the fill hose screens or you my have to repalce water valve make sure water is turned on....
Posted on Sep 19, 2009
SOURCE: my siemens washing machine S14.39 keeps stopping a...
Hi
It is your pump that is failing / bolked with hair and treds behind the impeller. The pump is not the best design as ther can enter smal treds and hair behind the impeller into the paking ring (seal). There is only one sollution that help - change the pump. Can be don from the fron of the mashine. Only one screw on the right side has to be removed to remove the plastig cover and the one screw to losen the pump.
Posted on Aug 22, 2010
richroth
  • 9472 Answers
SOURCE: I have a samsung washing
WATER DRAIN ERROR - Display shows 5E.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
Posted on Dec 11, 2010
What does 5ud mean 10 minutes from finishing 5 Ud displayed can't open door?
The SUD (not 5UD) code is displayed when excess foam is detected (possibly because excessive detergent is being used). If your machine does not cure itself, you may have to run an "Eco drum clean" cycle (if your machine has it) or a 90 degree cotton cycle with no detergent and no load.
Aug 29, 2016 | Samsung Washing Machines
I have a Samsung eco bubble WF1804WPU model that started showing the error message SUD. Any time it happens the machine stops washing as if paused and I have to press the pause button twice for it to start...
The SUD error indicates an excessive amount of soap suds in the wash. It will be difficult for the machine to rinse / spin all the soap out during the cycle, and may need to be run thru the cycle again (do not add any more detergent!).
Remedy:
Stop using regular detergents! Front loaders specifically call for "HE" (High Efficiency) detergents as they require less detergent and clean better with the reduced amount of water in these machines. Look for your favorite brand and select the one with the distinctive HE logo show below:
Use only the amount as directed on the bottle - do not use too much. Clothes should come out clean and soap free - and the SUD error should no longer appear - if it continues - double check the amount of detergent you're using as it is probably still too much.
Jan 30, 2015 | Samsung Washing Machines
I have showing 5d does not spin what does it mean
This code indicates that excessive detergent suds occurred during the cycle. The washer will not be able to spin out water with the excess suds. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the wash action and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This process is necessary and may occur several times to eliminate the suds.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
Jan 04, 2015 | Kenmore Washing Machines
New Samsung 8kg washing machine won't spin during calibration mode
Hi, our eco bubble 2013 model stopped working yesterday, we've tried the calibration mode but it doesn't get past the clockwise motion when doing this, can you please help?
Aug 14, 2013 | Washing Machines
My washer is displaying the word Sud, what does this mean?
SUDS means that you have used too much soap creating bubbles and delaying the drain process. the computer allows time to drain. if it takes too much it may delay or stop the washer. on front loaders use a ¼ of a cup of soap if it is powder or ½ cup liquid and make sure it has a HE in the box or bottle. HE means "High Eficiently"
Feb 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My maytag clothes washer Bravo quiet series 300, keeps flashing a Sd error code. Or it may be 5d
What does the Sd code mean?
Use only HE High Efficiency detergent for BravosTM washers.
Is "Sd" displayed and the wash cycle dial is flashing?
This indicates the washer was not able to clear all the excess suds from the washer. Re-select your desired cycle using cold water. Press Start/Pause. Do not add detergent.
Is "Sd" displayed and the wash cycle dial is not flashing?
If "Sd" is displayed and the wash cycle dial is not flashing, allow the machine to continue running, even if it appears that nothing is happening. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the wash action will pause to allow the bubbles in the suds to break, and the washer will add water for better rinsing. This rinsing process is necessary and may occur several times to eliminate the suds.
Is the drain hose kinked or clogged?
Make sure that the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose.
To remove the error display, press Power/Cancel or Pause/Cancel once.
If Power/Cancel or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start/Pause.
NOTE: If the error remains on the display, and all of the other questions above have been checked, call for service.
Dec 27, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
Washing machine stopped and says "sud". What does that mean?
SUDS DETECTION
During Drain Routine
During the Drain Routine, the water level is checked continuously. Normal drain will occur until the
pressure switch senses no water in the wash tub and there is no foam (suds). The drain pump will
operate an additional 15 seconds after the pressure switch reports no water or foam.
If the drain routine operates for four (4) minutes and the pressure switch senses any foam (suds) in
the wash tub, the Central Control Unit will start the "Kill-Foam" Routine. (See description of this
Routine below.) After the Kill-foam Routine is concluded, the Drain Routine will restart. If, after
four (4) minutes the pressure switch still senses foam in the wash tub, the Central Control Unit will
go into Failure Mode. The digital display will show, F02.
During Spin (Extract) Routine
During the Spin/Extract Routine the water level is checked continuously. If, during this routine, the
pressure switch senses the presence of foam (suds) in the wash tub, the Central Control Unit will
stop the drive motor and the basket will stop spinning. The electronic control will count the number
of spin repetitions that are attempted due to foam (suds). There are a maximum of three (3)
attempts for each Spin/Extract Routine.
Kill-Foam Routine
1. The Remaining Time counter is stopped.
2. The digital display shows Sud.
3. The Drain Pump is turned OFF.
4. The Central Control Unit will fill the wash tub with 1 gal. (4 L) of cold water.
5. While the tub is filling the basket will tumble 1 sec. ON/15 Sec. OFF.
6. Once the tub is filled, the drive motor will turn OFF and the basket will rest without any
movement for five (5) minutes.
7. After the five (5) minute rest, the remaining time counter will restart and the digital display
will show the remaining time left in the routine.
NOTE: If the Kill-Foam routine was initiated during a Spin/Extract Routine, the tumbling action
will be reduced to a cycle of 3 sec. ON/13 sec. OFF. If, at the end of either the Drain or Spin/
Extract Routines, a suds condition still remains, the digital display will show Sud.
Sud will also be displayed for a short period at the end of a cycle, if a Suds condition was
detected during the cycle. This will alert the consumer to reduce the amount of detergent in
subsequent uses.
Oct 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Display window saying "Suds" and nothing appears to be happening inside; just seeing lots of bubbles. Did a cold load of bathmats, set on "towels" for extra rinse.
You have apparently used an excess of detergent for this process. Try draining the suds out to a reasonable level, then resume the wash if you can. Hope this helps!
Aug 05, 2010 | Samsung WF328AA Front Load Washer
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
