Question about Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU2400XTPT Dishwasher is on island of Utila, Honduras. Upon return after several months absence, light was flashing but dishwasher would not turn on, light would not turn off, no other buttons would light up. I am thinking a power surge might have hit it and maybe knocked something out. Problem is, I need a part from here to take down there and hope someone there can install it. Help! Thanks! Barbara Chaney
  • smilipanti Nov 04, 2007
    normal light constantly blinking, can't do anything even after turning off power to it. I think it's been hit by a power surge too. I know how to reset it, but can't do that either. Help!
I had a svc. tech come and he said I need a new "panel". Darn.
It's $133 plus labor. He said the "normal" button had shorted out,
especially since that's the wash I use all the time. It's only two years old, and I didn't buy an extended warranty. Oh well.
Posted on Nov 07, 2007
SOURCE:
Whirlpool dishwasher light flashing 3 times
if it's only 3 months old then it's still well under warranty, call either the manufacturer, the place where you bought it or who installed it and it will be fixed for free or replaced.
Feb 23, 2013 | Whirlpool Dishwashers
Clean light flashes 7 times on Whirlpool DU1148XTPB3 dishwasher and it won't run.
The light flashing 7 times indicates error code number 7 and E7 is a error code for the flowmeter. What the flowmeter does is measure the amount of water coming into the dishwasher. The E7 error code can be cleared aby pushing the buttons in this order
HIGH TEMP WASH-HEATED DRY-HIGH TEMP WASH-HEATED DRY -- OFF/CANCEL
The error code will be cleared after pushing the buttons in that order...if after running the E7 error code returns the flowmeter would need to be replaced
The flowmeter is the part on the left side of the tub it is where the water enters the tub
The part number for it is W10195536
GENE
Sep 05, 2011 | Whirlpool 24 in. DU1055XTP Built-in...
I have a Whirlpool DU1055XT. The unit will not work
The flashing light indicates the water is not heating, there could be several reasons for this, I have created instructions on how to reset the dishwasher so you can use it and why it may have occurred. If you follow these and still have trouble let me know and we can dig into it deeper.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 03, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
I have a whirlpool adp951 with a green light flashing
HI,
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode
thank you for using fixya,rate my answer,
vijay
Oct 02, 2009 | Whirlpool 24 in. ADP5966 Free-standing...
If the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive).
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Nov 03, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher blinking light
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models. I believe the problem is attributed to water supply temperatures being too low when filling. Apparently, there are some sensitivity issues with the temperature sensing circuits in some dishwashers. There is a reset sequence that you can try to clear the fault. Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation. To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen to heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line). The theory is that you will fill the dishwasher with hot water instead of the cool water that is normally in the lines before the hot water from the hot water tank heats the line. This should satisfy the requirements of the temperature sensing circuits. If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is. The flashing light will be a series of flashes, followed by a pause. If you indeed have a component problem, it will depend on what the flashing light sequence is in determining WHAT component is bad. Let me know if this helps you. Post back with your comments or questions.
PS Your dishwasher is actually manufactured by Whirlpool.
Feb 11, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
BF162 DISHWASHER HOTPOINT
I think if you push the heated wash and heated dry button several times until all the buttoms light up this will fix your problem.
 A clean light that flashed repeatedly 7 times then off. Reset as above with the heated wash and heated dry buttons. You may then noticed a reduced flow from the pump so dissasemble the lower arm and water inlet assy.You may find it mostly plugged with foregin matter and some othe junk. Upon removal of that stuff and reassembly,It may work as new!
Feb 09, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
There is a green light on with padlock next to it
Try holding the "heated dry" button for 3-4 seconds. It may be that the "child-proof" lock is on.
Nov 28, 2007 | Whirlpool 24 in. DU1100XTPS Built-in...
Whirlpool GU2400XTP Built-in Dishwasher Logo
83 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
