Question about Neff B1421 Electric Single Oven
Neff b-ap22-7 single oven
When heat is selected power trips
  • 249 Answers
SOURCE: neff single oven
fan heating heating element gone replace it ;Ire close bye
Posted on Nov 28, 2007
SOURCE: clock setting
Press the fourth button from the left (that looks like a tick) then turnthe knob to the right of it to set time as required
Posted on Mar 29, 2008
  • 109 Answers
SOURCE: Oven not heating up! Fan works. Grill works OK.
Hi, The main problem I find with this fault is the fan element has blown. This usually cannot be seen without taking the fan cover off inside the oven. Thanks.
Posted on Jun 16, 2009
SOURCE: Neff U1410 main oven trips the main RCD. Occurs
I have a u1421 with the same problem! I notice the fan doesnt run too well, sometimes it doesnt run at all, needs a prod to get it running. I suspect with no fan, that the element gets far too hot, and then starts to leak to earth, tripping the RCD. I'm gonna try buying a new fan motor - you should ckeck if your fan is running full speed OK.
Posted on Nov 02, 2009
apart4u
  • 213 Answers
SOURCE: NEFF B1320 OVEN DOES NOT HEAT UP. POWER ON FAN WORKING
For all Free appliance repair videos visit our VIDEOTUTORIALS neff video
1, If the fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the NEFF element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your NEFF fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
Posted on Jan 12, 2010
Neff single oven won't heat up. Replaced the main element and grill heats but when switched to fan oven the fan and light comes on but no heat?
If the fan is working o/k, then the element is faulty, or it is not getting power to it, you need to test with a meter for a supply to it.
Sep 23, 2010 | Neff Ovens
Power tripping off at mains when switching oven on
It will probably be the main oven element that has failed.
This is located at the rear of the inner oven compartment behind a removeable cover.
Jun 03, 2010 | Neff B1641 Single circotherm super...
Oven not heating
blue waffle is nice and i like to pop fish up my **** go to google and type in lol fish and then click im feeling lucky and do the same with blue waffle xx good look it could help your oven.
Mar 31, 2010 | Neff B1421 Electric Single Oven
Fuse keeps tripping have checked and removed the inner bulb but cooker still trips the fuse, Fan and elements appear to be working
insulation breakdown on fan element will need replacing when heats up tracking down to earth tripping your rcd.
Jan 07, 2010 | Neff B1421 Electric Single Oven
Oct 25, 2009 | Neff U1421 Double circotherm Electric Oven
Looking for installation instructions for a Neff B1691 oven
Neff have some downloadable installation instructions at www.neff.co.uk select neff owners, then customer service, this opens a new window which has instruction manuals as an option, select this and then enter an E number for the model ( i tried B1664) a similar single oven and this brought up a pdf file. At the end p67 it gives cable sizes and types and connection details which should give you what you need.
Please remember to rate this solution.
Dec 08, 2008 | Neff B1691 Single circotherm super...
Oven not heating but the fan is working and clock flashing auto
You need to rest the timer. to get it off auto,otherwise the oven will not work.
Refer to your instructions.
Oct 20, 2008 | Neff B1421 Electric Single Oven
Neff b1421 single oven
I suspect that the thermostat has failed
Aug 07, 2008 | Neff B1421 Electric Single Oven
Neff single oven
Sep 04, 2007 | Neff U1721 Double circotherm Electric Oven
Neff B1421 Electric Single Oven Logo
Top Neff Ovens Experts
ashburton
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
