Question about Garden
Ariens cultivator 948401
Need to replace electric starter with manual start system (eg rope).
co7196
  • 3433 Answers
SOURCE: sears craftsman garden cultivator
A lawnmower shop can rewind it in a matter of minutes. Just take the cover in. good luck
Posted on Sep 22, 2009
jdlipscomb41
  • 157 Answers
SOURCE: How do you replace the pull start rope on an
you may need to carry it to a small engine mechanic those springs will get very diffucult on those rewind tops
Posted on Oct 26, 2009
Tech_Mate
  • 680 Answers
SOURCE: Ariens 8.5 HP snowblower, 5
First I would take out the spark plug then try tugging on the rope. If no success take a ratchet and a deep well socket that fits the nut on the flywheel tighten and loosen the nut with out restricting the flywheel does the engine turn over? Does it move then stop after you loosen the nut? If it does then check the oil. If it is low or none in there then the motor froze up and needs replacement. If this was no help check in the shoot for obstructions like a newspaper stuck in the auger or the thrower.
Terry
Posted on Jan 10, 2011
kel1guy2002
  • 3740 Answers
SOURCE: mtd 31cc cultivator recoil rope
The re-coil spring is most likely broken in the housing.
Part Number is: MTD 791-613102
Parts diagram is here:
http://www.partstree.com/parts/?lc=mtd&mn=121R+21A-121R700&dn=07281000001
Image of broken part is here:
http://www.mtdparts.com/webapp/wcs/stores/servlet/parts/part-types/engine-parts/791-613102
Remove items 31, 34 and 40 of the first link to access the recoil. The spring has to be pre-wound during installation. I.e insert spring.. insert pulley.. wind spring mount pulley.
This video may be of some assistance: http://www.youtube.com/watch?v=3U_6V-1gf0Y
Thanks for choosing FixYa,
Kelly
Posted on May 26, 2011
SD Tech
  • 14553 Answers
SOURCE: replacing starter recoil rope on troy bilt 4-cycle cultivator
Either contact the company or Google the model number for a service manual.
Posted on Jun 15, 2012
Pulled starter rope, it's now stuck and won't recoil
Cool!
A Project.
Remove the spark plug lead just so you can't have it accidently fire.
Remove engine cowlings as necessary to get at recoil starter.
Remove recoil starter (that's the bit that the pull rope is attached to.
Dis-mantle it until you can find what is wrong. Fix or replace.
Put it all back together.
or
Take it to a small engine repair shop and pay a bunch.
Mar 06, 2016 | Bolens 31cc 2-Cycle Gas Cultivator BL410
Replace the recoil starter
You don't need to replace the whole recoil starter just the pull rope.
There a few different ways of replacing the rope depending which recil starter you have. The tension is the same for all of them. You tighten the pulley until it stops and back off up to one turn with the rope fully extended.
Jan 28, 2015 | Garden
I am needing the seriel number for ariens rocket
-If you need only the rope, you don't need the series number. Just go to Lowe or Home depot and buy 1/8" Dia at 4 feet. Unless you need the whole assembly kit. If so go to where you get it from.
Good luck.
Mai
Aug 27, 2014 | Garden
Why is the rope starter not engaging the motor how do i fix it or do i need to return it
Try pulling the rope slowly until the starter engages the flywheel (you should feel when it engages) then give a good pull to start the engine. Don't give the rope a quick hard pull in one motion. You will probably need to do this three or four times before the engine starts. Of course push the primer button the number of times called for in your engine instructions before trying to start the engine. If you still don't think the starter is engaging the flywheel if would take it back where you bought it if it's new.
Jun 20, 2014 | Troy-Bilt TB146 EC 4-Cycle Garden...
Recoil starter assembly
If you can post the engine make, model and serial number I can get a diagram for you. They are usually stamped in the engine housing. Start by removing bolts to remove cover and check spring. If spring is good you should be able to rewind. You will need to cut rope by handle and pull rope up between spindle and inner housing, rewind rope in direction of pull. Let it rewind while holding tip of rope. When satisfied with tension, push end of rope back through hole in cover and reattach handle. This can be tricky. I am thinking of posting a video of this procedure. Let me know if you have more question's.Good luck.
Dec 03, 2013 | Ariens Garden
I need to replace electric starter with manual starter for ariens 948401-210e series cultivator
you must go to the supplier manufactue to request service manual for this procedure. However you can do this:
Remove the mower deck:
  1. Make sure that the parking brake is locked.
  2. Place scrap lumber under the front and rear of the deck.
  3. Use the deck lever to lower the deck.
  4. Remove attachments from the deck.
  5. Remove the blade drive belt from the front pulley.
  6. Remove the front and rear deck fasteners, following instructions in your owner's manual.
  7. Use the deck lever to raise the deck.
  8. Remove the scrap lumber.
  9. Remove the deck from under the mower.
Adjust the drive belt:
  1. Remove the belt from the large idler pulley.
  2. Remove the belt from the adjustable idler pulley.
  3. Carefully remove the spring-loaded large idler pulley.
  4. Loosen the adjustable idler pulley and move it slightly toward the rear of the mower to tighten it-or move it toward the front to loosen it-and retighten the pulley.
  5. Replace the belt.
  6. Check belt tension and readjust as needed.
Nov 20, 2013 | Garden
Starter rope hard to pull on mantis tiller
Sounds like your engine may be seized up. Mine did the same thing and I had to replace the block. If any dirt gets past the air cleaner or if your fuel mixture isn't right it won't take long to lock it up. If you need info on where to find parts, let me know. Good luck.
Jun 20, 2012 | Mantis 2-Cycle Tiller
Replacing starter recoil rope on troy bilt 4-cycle cultivator
Jun 14, 2012 | Garden
Starter cord
remove top starter assy. cut grip from old rope ease rope into spool,
when slack remove center screw and carefully pull out spool, tie knot in rope and thread into spool, wind rope [make sure correct size rope]
around spool until full,carefully turn spool into spring 1 turn then replace screw. put rope into notch on spool and wind up 3-6 turns,
replace grip
May 19, 2012 | Mantis 2-Cycle Tiller
Ariens 8.5 HP snowblower, 5 years old, recoil starter will not let me pull the rope out and the electric starter is not engageing, thoughts?
Terry
Jan 10, 2011 | Ariens Garden
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
