Question about Keurig Coffee Makers & Espresso Machines
Lead contamination in Keurig coffee makers
Is it safe to drink the coffee made from the Keurig?
  • 211 Answers
SOURCE: lead in the coffee maker
It does contain a small amount of lead inside a copper coil located in the electronics of the machine. This part does not come in contact with the water, heater or any other part that would cause lead contamination of your coffee.
This page has a great write up explaining it:
http://coffeebreak.today.com/2009/04/08/keurig-lead-warning/
Posted on May 28, 2009
SOURCE: I cannot get a full cup of coffee from my Keurig
I HAD A SIMULAR PROBLEM...AFTER DESCALING WITH VINIGAR I NOTICED THAT MY COFFEE CUP WASNT ALWAYS SERVED FULL....THEN AFTER A LITTLE DIGGING ON THIS SITE IT BECAME OBVIOUS....I HAD A PIECE OF SOMETHING STUCK IN THE ONE WAY VALVE...SO TO SOLVE THIS I DISCONECTED MY KEURIG,BROUGHT IT OUT TO MY SHED AND CAREFULLY BLEW OUT THE THE ENTIRE UNIT WITH MY AIR COMPRESSOR BEING CAREFUL NOT TO USE TO MUCH PRESSURE AND BLOWING OUT A SEAL.....BROUGHT IT BACK IN,FIRED IT UP,WORKS PERFECT AGAIN...EVEN THE DESCALE LIGHT NOW STAYS OFF.NO MORE PINCHING THE RUBBER RETURN VALVE IN THE RESIVIOR JUST TO BREW A CUP OF COFFEE. HOPE THIS HELPS SOMEONE........................
Posted on Jun 14, 2009
cmccune04
  • 213 Answers
SOURCE: Missing Keurig part
This is actually an ebay store. They have any Keurig part you could possibly need! It's the only steady keurig part business operating right now. Prices are fair products are in great condition. Seller has 100% positive feedback with 100's of satisfied customers who voiced their opinions of them.
They have parts for Keurig B30 mini, B40 Elite, B60 Special Edition, B70 Platinum, and B77
http://www.igotsweetdeals.com or
http://stores.ebay.com/Igotsweetdeals
Posted on Apr 13, 2010
espressonist
  • 1711 Answers
SOURCE: my keurig coffee maker turns its self off, even
If you can also see there are a lot of inquiries about the same or similar problem. We have already investigate the matter and it is a design problem from Keurig and it not any much that you can do,
We have a tip at the link that it explains it some more
http://www.fixya.com/support/r5543433-keuring_coffee_maker_b60_b70
Moreover you can contact the keurig customer service which we here that they are more than happy to help you and in many cases they have replace the machines with no further question, you can try also since you are a customer with rights.
Good luck
Posted on Aug 15, 2010
  • 40 Answers
SOURCE: platinum B70 keurig coffee maker water heats up
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
Posted on Oct 07, 2010
My coffee from my keurig is too hot
Coffee is mostly water, so can't pass over 100?C. All coffee makers work under the principle of boiling the water and pass the steam through the grinded coffee
If you wait some time, it cools off to a confortable temperature to drink.
Just guess you wanted to ask something else. In some coffee makers you should not use coffee grinded too fine or should not compact the coffee because it get's "explosive"
Oct 24, 2015 | Keurig Coffee Makers & Espresso Machines
Truth about Keurig Coffee machine
It is safe, but it is fake, some of the coffee grounds are mixed with instant coffee to make a better colored drink.
Sep 30, 2014 | Keurig Coffee Makers & Espresso Machines
Lead in verismo coffee maker
The plastic is safe and the interior heater compartment is like all other makers and uses the same metal components.
Dec 17, 2013 | Keurig B70 Coffee Maker
Keurig smell
The Problem is the USER. Follow directions and use a Filter and Distilled water as suggested. Bad house water will smell.
Feb 28, 2012 | Keurig B70 Coffee Maker
Keurig bad taste
I had that bad Keurig taste/smell for the first few months I owned it and almost returned it, but then someone suggested I run vinegar (1/3) and water (2/3) through it as though it was time to clean it and flush with just water for 3 cycles (see instructions)... and it worked!!!
Feb 08, 2012 | Keurig Coffee Makers & Espresso Machines
Keurig lead and chemicals are they dangerous
Yes, lead is dangerous in any amount. Most chemical are bad in some form or another. Please do more research on this matter. Google is a great search engine. Good luck.
Jun 14, 2011 | Keurig B60 Coffee Maker
What should the ideal temperature be for the coffee?
According to the SCAA, the optimal water temperature for brewing coffee is 92 - 96C (197.6 - 204.8F) for 90% of the contact time.
That's too hot to drink, since the human tongue can only stand about 140 degrees F.
Charlie
Jan 11, 2011 | Keurig Platinum B70 Coffee Maker
We have had our Keurig Limited Edition B 66 Keurig brewer for almost a year. Worked fine until now. The Power will not turn on. We tried plugging other things into the same outlet & their is power;...
Sorry to read about your problem, I hope this helps you out.
It sounds like you unit has a major malfunction. and they do break
Keurig does not make repair's or carries replacement parts for their units. you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | Keurig B50 Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
