Question about Panasonic SDR Video Cameras
Convert sdr2 convert file type
Can you explain the steps to convert a video?
According to me, youtube converter is one of the best video converters.The four simple steps to convert a video are:-
1. The first step to converting a video, you have to copy the video URL and you can find this Url from youtube or any other websites.
2. Secondly, you have to choose a format according to your choice.
3. Then click on convert and wait for a moment.
4. And at last, you have to download the converted file into your device or Dropbox.
Oct 14, 2017 | The Computers & Internet
Tip
PLAY VIDEOS ON THE MP3 PLAYER Check the specification of your MP3 player to...
Check the specification of your MP3 player to determine the type of video file format it uses.
Most common video files that MP3 players use are, AVI and WMV, there may be others such as FLV, MOV and DivX.
If your player cannot play a video then it is an incompatible video file format, then you need to convert that video file to a format that your MP3 player uses.
There are commercial and freeware video converters on the Internet. Use Google to search for Video converters. I found these converters useful, Kate’s Video converter, Any Video converter and CI Video Converter.
I suggest you try some freeware types first and convert a video file, then test this converted video file on your MP3 player.
To copy/download your video files to your MP3 player, connect the USB cable from the MP3 player to the USB port on the computer. Open the video folder on the MP3 player and copy and paste the video file/s from the computer to the video folder on the MP3 player.
on Sep 05, 2010 | Computers & Internet
How to put vedios on the mp3
It seems that this device only plays one video type. Meaning that you'd first have to run all your video files through a converter, and then you can put the converted file on the device, and only then will it be able to play video files. The supported file types are wmv and smv. There might be some others that I havn't come across yet though.
Here's a download link to a converter for this device: link Simply put the output type to either SMV or WMV and convert the file. Copy the converted file to your device and it should be able to play.
I hope I was able to help. If I did, please don't forget to rate my solution.
Jul 27, 2011 | Philips GoGear ViBE Digital Media Player
When i try to downlaod a video to my mp3 player it says unsoprted file type . and i do not have have the rca easy rip on my mp3 anymore because i accidentally deleted it from my device how do i put videos...
Hi staxxzack...
You need to download a format converter and convert you files to the type needed by your MP3 player.
I believe your MP3 player will use Windows Media Video file type
Free answer...Please rate me
You can download a free file converter at this website.
http://formatoz.com/
May 23, 2011 | Audio Players & Recorders
Can't convert videos that will play on my smpk8854b
Hi, to be able to the video file that Sylvania SMPK8858 MP3 Player plays, you will need to know the file format first before you can be able to convert the type of file you want to convert to play on your mp3 player.
You can use the below link to convert the file type of video you will want to convert to.
http://search.brothersoft.com/index.php?act=search.index&keyword=Total+video+convert++download&stype=windows
There are different types of converter available you can pickone and download..It's free.
Have a nice day..
Feb 17, 2011 | Sylvania SMPK8858 MP3 Player
Cant match the video file. what file should i use?
it all depends on the phone your using.
Phones have different type of format of video file,in other to save you stress, Find out the video file type that your phone uses and download from the internet a video converter (precisely total video converter) and use it to convert any format of video file that your phone uses.
Take care.
Jun 16, 2010 | Cell Phones
Is it possible to splice 2 msv files (one after the other) so they become one file? These files have already been transferred to my PC.
OK well in that case you could convert them to WAV and join that and play it that way? Download and install the Switch Audio Converter. Switch can convert between numerous audio file types and has the capability of reading MSV files.
Add the MSV file you would like to convert to the Switch converter. Click on "Add File(s)" and browse for the file in the search window that comes up. When you locate the file, click "Open" to import it to the converter.
Select WAV as your output file type. The .wav extension is one of the options in the "Output Format" drop-down menu at the bottom-left corner of the Switch screen. Choose an output folder for your WAV file. To find a folder, click "Browse" next to the "Output folder" box. Locate the folder where you would like to save the WAV file on your hard drive and click "OK."
Click "Convert" to begin the conversion process. The "Convert" button is in the bottom-right corner of the screen. When you click "Convert," a small window with a progress bar will pop up to monitor the status, and a pop-up message will inform you when the conversion is complete. The WAV file will now be available in your chosen output folder. http://www.softplatz.com/freeware/wav-joiner/
http://download.cnet.com/Switch-Audio-Converter/3000-2140_4-10703967.html
Feb 16, 2010 | Sony ICD-MX20 Digital Voice Recorder
What type of file to I need to convert my video files to in order to add it to my SanDisk Sansa e280?
Use the Sansa Media Converter to convert all videos - it is available on Sandisk's website if you have lost your installation CD.
Jun 25, 2008 | SanDisk Sansa E280 MP3 Player
Sansa c200 mp3
You must use the Sansa Media converter to convert the pictures into the proper format. The media converter will not recognize ALL picture types pre-conversion, so you will have to check your manual for the list of compatible file types. In general, if the media converter won't find the file in the folder in which you stored it, then the file cannot be converted AS IS. The solution would be to convert the file to jpg or bmp format, and then run the file through the Sansa Media Converter.
Jun 02, 2008 | SanDisk Sansa c200 MP3 Player
Video Cameras Logo
24 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
