Question about HP Officejet Pro 8500 Wireless All-In-One InkJet Printer
How do I fix error code 0x600000c on hp officejet pro x476
The printer says there is a problem with the printer or ink system. I turned off and on and it didn't fix. I also can't access the ink cartridges. They won't pop up.
  • 3 Answers
SOURCE: HP K850 cartridge problem
I had the same problem, all cartridges lights came on.
I did two things:
1st: I clean the print cartridges plugs with Q-tips, just to insure there wasn't any ink build on the plugs. If you look were the cartridges are, you will see four plugs one for each of the cartridges. Each plug has four contacts. They should be a bright metal color. If they dull in color, they have ink on them. Unplug the printer and pull all the cartridges out and gentlely wipe the the contacts with Q-tips. Re-stall all the cartridges.
Note: The cleaning did not solve my problem but its good maintenance since in was looking for a solution.
2nd: What work for me was I un-stall my printer totally. Turn off the printer then turn off the computer, had a cup of tea, rebooted the computer and re-install the HP cd disk and drivers, turn the printer back on. After I reinstall the software and put the printer back on my network, everything is working fine for the last two days. The lites are off and the HP toolbox is reading the ink cartridges status correctly. I believe that a virus change the printer drives.
Solution by;
eagleeye140
Posted on Apr 19, 2009
pineworks
  • 4041 Answers
SOURCE: Ink System Failure code appears on Hp Photosmart D7360 printer
Hi ok try I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
  • 17 Answers
SOURCE: I refilled HP 88 cartridge but printer (Officejet
Under the cartridge is a black like pump - on a new cartridge this is hard and rests firmly on an area inside your printer. As you print, the pump becomes softer - this is how the printer determines it is empty. Once refilled, the pump does not get back to the original state. Open the bottom of the cartridge and put a firm solid piece of folded paper in there - make sure it is steady and re-close cartridge. It will now read as full but may also show full - judge ink levels by the quality of print. Also make sure chip has not expired.
Posted on Feb 17, 2010
SOURCE: OfficeJet Pro K5400...ink cartridge
Er, NO.
The answer to the above question is clearly misleading.
If you consult the documentation for your HP K5400, which can also be found online, you will find that the printer cartridge lights also blink when the print heads require replacing.
If you have replaced the cartridge and the light still flashes, this is the most common solution. Replace the print heads.
Unfortunately because the printer is badly designed, there is no way of indicating this, and you will have troubles if you attempt to get the HP Toolbox or any other diagnostic tools working.
Posted on Feb 22, 2010
  • 159 Answers
SOURCE: Ink Failure on HP photosmart premium C309g printer
Turn off the machine, unplug the power cord from the back of the machine, remove the ink cartridges (lift the lid up at the base of the control panel), wait 2 min, plug the power cord back in, press the on button, wait until the printer prompts that the ink cartridges are missing, then replace the ink cartridges. If this doesn't fix the problem you may have to re-prime the ink lines to clear the error. You can find instructions for this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Posted on Mar 15, 2010
Problem with printer or ink system
PDF]HP Officejet Pro X476 and X576 MFP Series ... - Parts Now
www.partsnow.com/.../Officejet%20Pro%20X476%20X5...
Parts Now LLCFigure 2-6 Printer status report-determining genuine HP ink usage . ..... Thesecartridges are linked by flow connections to the rest of the printbar and supply the ink..... The left door can be opened for jam clearance and has a hall effect .... The document feeder will not function when the document feeder cover is open.
db:: 4.32::Printer door will not close after printing 8p - Hivmr
www.hivmr.com/db/8p83f78d97fk8c883x9p9za3mf993scf
On the 50.8 error message, if power cycling doesn't fix the issue you may need to ...Opened printer cartridge access door and removed paper. ... HP Officejet Pro L7580, the latch to the ink cartidges broke, so the door won't close. ... Can not close the printer door on my HP B210a, after cartridge replacement need help?
Re: Do u need Help? -HP All-in-One's(Officejet,Psc's)
www.fixyourownprinter.com/posts/28357
Also, when reinstalling the HP it does print a test page, but will not print from ...Encoder Strip has been cleaned with water (had some ink residue). ..... when opening the door the cartridge does not move to the middle so i can remove it, clean it ...... Iopened the covering part of the scanner (with the glass) nad cleaned all the ...
HP Officejet 6210- repeated ' FixYourOwnPrinter
Dec 28, 2015 | HP Officejet 6600 e-All-in-One -...
How do I reset an officejet X476 printer
Keep in mind that these instruction clear everything. The challenge is that if your control panel is locked you may not be able to carry out these instructions. 25371336-krtaiyymi0dz0suct32fia1z-1-0.jpg
Jan 16, 2015 | HP Officejet Pro X476dn Color Inkjet...
How do I reset an OfficeJet Pro X476 ? printer's admin functions are locked.
Found some things that you will have to check. Are you the IT Admin?
http://data.manualslib.com/pdf2/48/4756/475532-hp/officejet_pro_x451.pdf?20be71eb5f9d0bcbf61131c493e0773d
  • These machines have a warning, that any problems beyond the basics you can generally fix, you NEED to call them.
Jan 15, 2015 | HP OfficeJet Office Equipment & Supplies
My hp 8500 officejet printer won't pump ink up tp the printer cartrigers
I'm not sure I understand your problem. Are you getting any error codes or error messages? How did you diagnose your problem, specifically?
Jul 25, 2014 | HP Officejet Pro 8500 Wireless All-In-One...
What is error 0xc19a0003 mean for the HP Officejet 4620
ink system failure - error 0xc19a0003 means ink system failure error usually occur if you have issues with your ink cartridge or printheads. Have you try replacing either of the two?
May 12, 2014 | HP Officejet 4620 e-All-in-One Printer,...
HP printer error code 0003
please clarify what is the exact thing the printer is doing whenever you get this code>where do you see this code isiton the computer or on the screen of the printer>this might have something to do with the ink systems
Feb 02, 2012 | HP Officejet Pro L7680 All-In-One Printer
I have a new hp officeet pr 8500 printer but on start up the screen displays error code 0060 and then goes blank. how to fix?
This error means there's an ink leak in your printer. HP recommends that you turn the printer off (using the power switch at the back of the printer), wait 20 minutes and turn the printer on (condensation may be causing error and the printer needs time to dry).
Mar 12, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
HP OFFICE JET PRO L7500/L7600/L7700
my hp office jet pro l7500 indicates the ink has expired in all cartages but the cartgages are new because they were just put in . Before the same error code came up and so bought new cartages. Also the door to the cartages will not stay closed without tape.
Nov 29, 2008 | HP Officejet Pro L7480 All-in-One...
HP Officejet Pro 8500 Wireless  All-In-One InkJet Printer Logo
184 people viewed this question
Seeker5211
Seeker5211
