My washer washes, but doesnt rinse...
Ok, the washer works on all cycles to wash, and spin out, but wont fill for rinsing.. I stops and makes a low buzzing noise. If i pop the start in and out the water comes out, if i do it fast enough it begins filling like regular. Im so confused.. Please help..
  • 2 more comments
  • Anonymous Nov 24, 2007
    the child lock will not unlock
  • tanyawilliam Nov 26, 2007
    Mine does same thing, except the "on" light blinks. It will sit blinking with a slight hum, for days if i let it
  • Anonymous Jan 07, 2008
    my smart
  • msmae Mar 11, 2009
    the wash cycle works fine. the rinse cycle begins filling with water and the water drains out. the water continues to run until the cycle is manually stopped
  • 94 Answers
I sounds like it needs a new timer.
Posted on Oct 08, 2007
SOURCE:
Whirlpool top load washer no low-speed agitation. The unit fills, starts the wash cycle with normal agitation, but after a few minutes it just sits there soaking until the it's time to drain/spin. Drains...
Either the wire going to motor for non working speed is loose or damaged, or motor is bad. It could also possibly be timer not sending power to motor for that speed.
Sep 27, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine wont rinse or spin
it fills up with water but it won't spin and then makes like a grinding noise someone told me it could be a clutch
Aug 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine doesnt rinse and spin
IT SOUNDS AS THOUGH ITS NOT HEATING IF IT DOESNT IT STAYS IN WASH MODE AND WONT COMPLETE CYCLE NEW HEATER REQUIRED
Aug 12, 2009 | Bosch Exxcel WVT 2850 Front Load Washer /...
Washer will not complete cycle
washer fills up but wont start washing i can turn the knob just passed the numbers and the little marks and it starts washing and when it gets to the rinse cycle it wont rinse but when it gets to spin cycle it spins good
Mar 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washing machine won't rinse or spin
sounds as if you have a faulty lid switch, for safety reasons if the machine doesnt think the lid is closed it willnot spin/drain the waer out.
Feb 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Rinse cycle doesnt work
the humming noise is probably the cold valve operating but no water. check tap not turned off. slowly loosen cold water feed and check if water present
May 02, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines Logo
542 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
