Question about La Crosse Wireless Outdoor Temperature Transmitter Tx6u
Weather station won't give outside temperure
Replaced batterys per insuctions twice . in both divies
31215 Wireless Outdoor Thermometer manual
With mine, the battery in the weather station has to be changed twice as often as the one in the external unit. Even though the display on the home unit is visible, it doesn't have enough power to pick up the signal from the outside sensor.
I am not familiar with yours, mine is national Geographic.
The reviews on yours are very mixed, but lots of questions are answered.
Amazon com Weather Station with Wireless Outdoor Thermometer 31215 Home...
Jul 24, 2016 | Measuring Tools & Sensors
Outdoor temperature on indoor station showing - -.
Check the battery in the outdoor unit, resync them per the instructions, if that does not work check for interference.
Jun 23, 2015 | Equity Time USA 31215 Wireless Outdoor...
Display station not showing outside temperature
Check battery status indicator on main weather station of remote unit. If no indication, replace battery in remote unit. If battery is good then check "channel setting" of remote unit to make sure the channel setting on remote unit matches the "channel" setting on main unit. many weather stations will take up to 3 or 4 remote units and they must use different channels to relay the remote imfo to the main weather station unit.
Jun 19, 2015 | Measuring Tools & Sensors
How do I reset the time on my smartgear weather station
I have two of these and they lose the signal occasionally. Per the manual: Make sure all batteries are good and then press the TX button on the remote sensor for 3 seconds so it sends a wireless signal to the weather station. It should beep. Then on the weather station hold the CH button for 5 seconds to make it search for the transmitter until the outside temp appears. Just removing batteries and reinstalling them in various orders doesn't work. You must re-establish the wireless connection between the outdoor sensor and weather station.
Mar 08, 2015 | Measuring Tools & Sensors
Outside temp
Remove all batteries. Reinstall batteries (or new ones) in the outside unit. Install batteries in the console. DO NOT TOUCH ANYTHING! Wait until the outside temperature displays on the console. Make any adjustments necessary.
Nov 05, 2013 | Davis Instruments Davis Vantage Vue...
Weather station won't work
i have the same problem and have had 2 of these now. outside unit blinks like it is transmitting but nothing on base. SYNC per manual does not fix it.
Jan 29, 2013 | Brookstone Wireless Weather Forecaster
Why is the outside temperature not displaying on the base?
After a battery replacement, the outside and inside units have to "talk" to each other before you can get a display. Also, the outside unit's batteries have to be replaced first. You should not press any buttons for 10 minutes until the two units have finished "talking"
Jan 24, 2013 | AcuRite Acu-Rite 00593W Wireless Weather...
C Tech Weather Station. How do i reset the outside temperature. Meter says it's off?
Is the outside unit LED on? I replaced the battery on the outside unit and in doing this reset the outside information.
Jul 05, 2012 | Coghlan's CTech Wireless Weather Station...
La Crosse Wireless Outdoor Temperature Transmitter Tx6u Logo
67 people viewed this question
Top La Crosse Measuring Tools & Sensors Experts
john milligan
Are you a La Crosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
