Question about Car Audio & Video
Were do I put the rem wire on my alpine 3537 amplifier
2 Suggested Answers
  • 58 Answers
SOURCE: need a wiring diagram for alpine ktp445 amplifier
bassmekanic_3.jpg For this end of the plug: I would plug the other end of the KTP-445 directly into it and match the color of the wires off the other plug, remember to write them down, but most of the wires look like standard plug wires on most stereo plugs. When this is complete you should be able to snip this end off. Then wire it the wiring harness inside the dash (using the notes you took on the wire colors)
bassmekanic_4.jpg This end of the plug looks to have all the standard wires that most after market stereos have, clip this end off and wire it to the wiring harness on your current stereo. (You may not use all the wires, just tape them off because you probably won't need them anyway)
This is just my opinion on how it would be done, I have not tried this myself. But since most aftermarket stereos have the same kind of wire set up I do believe this could work.
If you decide to try it, please give some feedback so others can figure out how to do this also.
Posted on Nov 09, 2010
Their are 2 power wires,2 negative wires and 2 rem wires...how is this wired..im getting ready to get this put i
Some amps come with extra, power,rem,ground, so you can , power up another Amp Without runing to many wires. , or using a power block.like a parallel, being your 1st Amp your power block, and your remote, ground .
Apr 03, 2016 | Jensen JXA8BA2 Amplified Subwoofer, Max...
My amp wont shut off when i turn off the car and take the keys out. just want to know how to turn off the amp. im out of town and cant go to the place i had everything installed at, for another week. just...
Hi, can you disconnect the wire from the "rem" terminal of the amp? The wire connected here is supposed to come from the head unit and is hot only when the head unit is turned on. It should be a blue wire.
Sep 12, 2011 | Alpine MRD-M1000 Car Audio Amplifier
How to hard wire a alpine ktp-455, i hooked it up and no sound. i didnt use the orange, pink,and blue wires.
guess you have to put blue wire to your sets amp rem to let it switch on
Thanks for using FixYa - a 4 THUMBS UP rating is appreciated for answering your FREE question.
Feb 26, 2011 | Alpine Car Audio & Video
It keeps blowing my fuse for my stock radio. Pushing a 10" sub.. Fuse on my amp is good. In-line fuse is good. But it keeps blowing the radio fuse in my panel.. ? Please help.. Thanks Ryan
Check the amp turn-on wire. It's a blue/white wire running from the radio to the amp. It's probably label REM at the amp. This wire sends a switched 12 volts from the radio to the amp. It is probably shorting out somewhere between the radio and the amp.
Nov 28, 2010 | Alpine MRP-T220 Car Audio Amplifier
What is rem
rem means remote on the amplifier which means your amp will turn on when ur radio turns on the remote wire goes from the back of the stereo usually always a blue wire to the rem on the input to the amp
May 23, 2010 | Rockford Fosgate Punch P5002 Car Audio...
Amplifier rem. wire issues- two amps in series, second amp in series turns on first amp does not.
man i hate to break this to ya but you might want to wire your first amp strait off the remote and i would defeinatly not tie it in series like that. It can cause your amps to over heat very easy. Take and wire it from your first amp then to your second but not in series see if that fixes your problem if not you may have one bad amp i dont know
Nov 11, 2009 | Alpine CDE-102Ri CD Reciever, iPod and USB...
Pyle pla2170
The power cable and the rem cable need to have different power sources. The best thing to hook the rem. to is a power antenna wire, or if you don't have a power antenna, you'd need to hook it to the ign. or accessory wire.
Jul 31, 2009 | Pyle PLA2180 Car Audio Amplifier
Install kicker ix254 into a Land Rover Discovery
that wire probs is your rem wire hook it up and try er out john
Apr 19, 2009 | Kicker IX254 Car Audio Amplifier
Kole kx2-1440 wiring da amp up right
It is correct to connect the amp turn on wire to the amplifier remote. 5V is sufficient to turn most amplifiers on... It should be 12V optimally.
If the amplifier is not turning on with the ant. remote, the problem is with the amplifier.
Dec 30, 2008 | Kole audio QX1-2400D Car Audio Amplifier
Car Audio & Video Logo
60 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
