Question about Lexmark X940E All-In-One Laser Printer
LEXMARK X940E 100K MAINTENANCE KIT - Lexmark X940E All-In-One Laser Printer
Lexmark 463de maintenance reset
To reset the maintenance page counter to zero:
1. Touch Reset Maintenance Counter from the Configuration Menu.
2. Reset Maintenance Counter appears in the header.
3. Touch 100K Kit or 600K Kit. Yes and No appear in a menu.
4. To cancel the reset operation, touch Back or No. All other button presses are ignored.
5. To initiate the reset operation, touch Yes.
Dec 03, 2012 | Lexmark "x463de multifunction laser...
How i reset the warning mentenance adf kit
With the printer off try unplugging it for 2 minutes.
If that did not work try turning the printer on and pull the power plug for 2 minutes before plugging back in.
Jul 11, 2012 | Lexmark X940E All-In-One Laser Printer
Hi, i have five LexMark X940e in my wor, i installed it and it is fine< but i could not setup the email in the printer so i can scan and send email dirctly from the printer every time i tray to send...
Can you provide us more information about the mail server that you are using? is this an exchange or regular server?
This can be an issue with the authentication type, like the username and password.
For further assistance, please contact Lexmark Technical support
Mar 31, 2011 | Lexmark X940E All-In-One Laser Printer
Error 80 on a lexmark t642
Hello. Welcome to Fixya
Actually Error 80 is "Scheduled Maintenance Message"
You can reset the maintenance count by going to the Configuration Menu
Follow the given steps to solve it:
  • First of all Turn off your printer
  • Hold the 2 and 6 buttons while the printer is off
  • Turn on the printer but don't release the buttons yet. Keep holding those buttons for about 10 seconds
  • On your Operator Panel, you should see "Configuration Menu"
  • Scroll down and look for "Reset Main Count" and select it.
  • Exit Configuration Menu and turn the printer off then back on
I hope it will be solved, If it doesn't work then
You are required to purchase the maintenance kit and have it replaced even if the printer is still under warranty. Some maintenance kits can be installed without the assistance of a technician. However, some warranties cover on-site installation of the maintenance kit by a technician after you have purchased the kit.
In this case you must be contact to LEXMARK service provider, To get support by LEXMARK on phone, then call at 1-800-539-6275
I hope this solution will surely helpful for u
If its is helpful then please don't forget to click on Four thumbs which are given below this solution
THANKS & Keep Using Fixya
Feb 28, 2011 | Lexmark T642 Laser Printer
After replace of a 100k kit, how can i make the reset of this?
Turn off the printer.Press and hold the Select and Right Arrow buttons simultaneously.Turn on the printer.Release the buttons after 10 seconds.Select Reset Maintenance Counter from the Configuration Menu.Reset Maintenance Counter appears in the header.Select 100K Kit or 600K Kit. Yes and No appear in a menu.To cancel the reset operation, select Back or No. All other button presses are ignored.To initiate the reset operation, select Yes. Gerrit Jan
Nov 10, 2009 | Lexmark C935dn Laser Printer
80 scheduled maintenance
This issue is just like changing your oil or the timing belt on your car. If you don't fix it correctly it leads to other problems. So, be warned. :+)
Here's what the Lexmark KB says:
On the Lexmark T520/522 series printers, we recommend that the maintenance kit be replaced after every 250,000 pages. If possible, an authorized service technician should replace the maintenance kit parts on these printers.
On the Lexmark T620/622 series printers, we recommend that the maintenance kit be replaced after every 300,000 pages. The maintenance kit parts for these printers are customer-installable, but some dismantling of the rear area of the printer is involved.
Note: The maintenance kit may need to be replaced more often if the customer is running heavy media (like card stock or labels) through the printer.
It is possible to clear the maintenance error message without replacing the kit. The printer will still operate, but some print quality problems may arise. However, this is not recommended as the message serves as a reminder that maintenance is due. If the printer is under warranty, the customer has to purchase the maintenance kit and have it replaced in order to keep the warranty active, although the on-site replacement itself may be covered under the warranty.
The parts that make up the maintenance kits are:
A fuser unit
A transfer roller
A charge roller
To find the part number of the maintenance kit needed for your printer, see Printers / Maintenance kits.
Clearing the maintenance message
To clear the message, you will need to go into the printer's configuration mode. Do the following:
  1. Press and hold the SELECT and the RETURN buttons as you power the printer on.
  2. Hold the buttons for six to eight seconds after turning on the power, then release them. (If you receive the maintenance message, press the Go or the Select button to continue past it.)
  3. Now, press the right Menu arrow until you see RESET MAINT CNT.
  4. Select this. You may need to press the Select button again. The printer display should briefly flash SAVED.
  5. Power the printer off and then back on in the normal way. The printer should now power up normally.
  6. If it does not and the error returns, repeat the above procedure.
Jun 11, 2009 | Lexmark T522 Laser Printer
Lexmark T642
There is a great video that shows step by step how to install the fuser, transfer roller, charge roller, pick up tires and then reset the 80 Scheduled maintenance message
Apr 03, 2009 | Lexmark T642 Laser Printer
Lexmark x642e MPF Reset maintenance counter
Hi~
You can reset the maintenance count by going to the Configuration Menu.
Step 1: Turn off your X64x printer
Step 2: Hold the 2 and 6 buttons while the printer is off
Step 3: Turn on the printer but don't release the buttons yet. Keep holding those buttons for about 10 secs
Step 4: On your Operator Panel, you should see "Configuration Menu"
Step 5: Scroll down and look for "Reset Maint Count" and select it.
Step 6: Exit Config Menu and powercycle your printer (turn it off then back on)
Hope this is helpful... =)
<<ichtuscheeky>>
Jan 30, 2009 | Lexmark X642e All-In-One Laser Printer
Paper will stuk in meddle printing
Probably the page count of your printer exceeds 100k pages. Maybe u will have to change the maintenance kit of your printer. This printer have no HP original maintenace kit, but u can buy the parts one by one.
Fusing assembly
separation pad
feed rooler
Good luck
Dec 15, 2007 | HP LaserJet 1100 Printer
Lexmark X940E All-In-One Laser Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
