Question about Honda Billy Goat Force Blower Leaf Vacuum 902 ()
Gas in air filter on billygoat QB554HC blower
I have a CCA24FCC that keeps shutting the furnace off for lack of air flow. The blower seems o be working well, i have replaced the filter even when it appears to be clean. Is there a sensor that measures...
There are 2 blowers to be concerned with. The main blower simply passes the household air over the heat exchanger to provide warm air for the supply vents. The other blower, which is more important, is the draft inducer blower. This is a smaller blower that starts first to create a negative pressure in the fire box to ensure that carbon monoxide gases will pass up the flue when the gas jets ignite. There is a pressure switch associated with this blower. When the inducer blower starts, it pulls air up thru the flue until the pressure switch activates. Then the gas jets can ignite, warming the heat exchanger. A few seconds later, the main blower will start to warm the air. If the inducer blower or the pressure switch is faulty, the furnace will not fire up.
Feb 24, 2015 | Filter Heating & Cooling
Shindaiwa leaf blower EB8520 loose power every 5 secondes for 5 secondes
Sounds like you are running it with the choke on - is it spitting black smoke?
Jan 12, 2013 | Garden
Gas blower engine surges and shuts off when engine gets hot
check your fuel lines for cracks, could be sucking air or could be your carb needs cleaning, make sure you clean the screen inside the carb, if you run it with the choke on partially does it smooth out and quit surging, if so it is definitely a fuel problem. Hope I helped you. 2StrokeJim
Nov 27, 2011 | Poulan 25CC Gas BlowerVac
Craftsman gas blower model #358.797130. replaced gas line and filter.Had to take gas tank out to connect line. Cannot find how to connect the carbuetor to stay on the gasket. diagram in the book doesn't...
Probably a couple of screws that you took out to access the carb from inside the air filter housing. Probably Torx head screws. You line up the carb and put the air filter housing back on over the carb, lining up the holes in the engine block.
Does this look like the answer you were seeking? Or did I mis-understand?
Nov 01, 2009 | Craftsman 4 Cycle Blower/Vac
Gas in echo trimmer air filter
your needle valve in the carb is stuck. carb needs rebuilding
Sep 18, 2009 | ECHO, Inc. PB-251C Handheld Blower
Gas blowback through the air filter
A certain amount of "spit back" is not abnormal in a 2 stroke engine without a reed valve (like the engine on your 155BT). If the engine runs well I wouldn't worry about it. However, this condition can be aggravated by an engine with a worn or stuck ring (other symptoms would behard to start and low power) or by running the engine at wide open throttle without load (pretty much impossible to do with a blower unless you block the outlet or have severe fan damage).
Apr 25, 2009 | Husqvarna 155bt Gas Backpack Leaf Blower
Honda Billy Goat Force Blower Leaf Vacuum  902 () Logo
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
