Question about PixiModo Reflection 15M 15-Inch Digital Picture
Won't completely shut off
When I push the off button on the remote it turns off the picture but leaves a soft grey screen. I have to unplug it to go to off black screen
    Scholar:
  • 140 Answers
Do you have a separate Cable Box? It sounds like you are shutting off the signal to the TV and may have to push a 'TV' button the remote then the 'off' button to actually shut down the TV.
Posted on Nov 21, 2013
JVC LT-22EM72 Solid red power indicator but tv won't turn on
Customer service told me to leave the unit unplugged for 24 hours.
Feb 22, 2013 | JVC Lt22em72 22-in Led 60hz 1080p Hdtv
My Mitsubishi wd-63527 turns on for a few seconds and shuts itself off.
The set may have (some models) a recessed reset button on front but that rarely does any good.
This model should have two resets other than that one----soft reset if it has it is with Mitsubishi remote: On, Menu,1,2,3 enter.
Set also has a hard reset which requires a four digit number code and resets set back to factory---it is a last resort and should not be done unless the soft one does not help.
I would have the remote tested as without it you cannot do any reset--
Most digital cameras in a dimly lighted or dark room will react on screen display when a remote is pointed at them and buttons pushed or most shops have a tester which will show and react to each and every button when remote is pointed at them and buttons pressed.
This model could have a keyboard lock feature which disables the keyboard but remote should still function.
First thing is to know if remote actually is working or not.
Apr 21, 2012 | Mitsubishi WD62527 62 in. LCD HDTV
Remote control won,t work
This is how to complete a remote reset for a Sharp television:
Turn off the television if it is on. Unplug the television. Please leave it unplugged. Take the batteries out of the remote control. Leave the batteries out of the remote control. Is the television still unplugged? Yes? Good leave it that way. Are the batteries still out of the remote? Yes? Good leave them that way. Point the remote at the television's remote sensor. Hold the power button down for 30 seconds. Release it. Press and release each button on the remote control. Plug the television back in. Turn it on with the power button on the television itself. Replace the batteries. Try adjusting the volume. Hopefully the remote works. If it still doesn't work the remote sensor on the television could have gone out or you may need a new remote. http://www.sharpusa.com may have a remote you can order or http://www.replacementremotes.com but if that isn't the problem you may or may not be able to return the remote.
Sep 23, 2011 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
My screen is just grey, no picture and when i push a button (any button except power) it says "button locked"
Hi there , maybe to late by now but sounds like the panel lock is on you can only remove it by using the remote and going into the menu and turning the panel lock off .
Feb 04, 2011 | AOC L26W861 26 in. LCD TV
I was watching TV and suddenly the screen went black. No picture, no sound. On/off timer LED on TV started blinking. I could not turn it on (or off) with remote or ON switch on TV. I found that if I...
The television is shutting itself off to protect itself. The blinking light is a code pattern. The specific code determines whether or not you need an LCD Controller Unit, Main Board, power supply or something else. You would need the service manual. There are parts distributors you can get it from and the parts as well. If soldering and tv repair is not something you are entirely familiar you may want to seek a tv repair person. The manufacturer's support may walk you through the service menus to complete a factory reset depending upon the symptoms.
Sep 28, 2010 | Televison & Video
I need instructions for a jumbo universal remote
im going to tell you automatic searching to operate your tv.... turn the tv on..
push the tv button and the on off switch at same time and watch if the led is steady ,leave the buttons., push play button and wait 5 seconds til the led finishes flashing you have to do this about 20 times to be complete secure your remote control doesnt control your tv....but if the control found the code the tv turn it off push reverse button and leave it and wait two seconds to turn the tv on and that set push stop. ........test all functions on your remote control to the tv.....saludos.
Nov 15, 2008 | Universal Remote Control Remote Control
Grey static then flashing button
Could be your flyback transformer or these caps 2200 mf16v 22035v 33035v. Check the caps for bulging.
Jul 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Playstion 3
I understand how frustrating that must be. How big is the hard-drive that came with your unit? Did you buy it brand-spanking new or used? Update to version 2.2. It came out last night. Then, once that is complete, shut down your PS3. Unplug everything from your memory card ports and usb slots. Unplug the power cable at both ends (from the wall and the ps3). Then switch the PS3 hard switch (on off, lever, not the soft method of turning it on by a mere touch). Leave it that way for 10 minutes. Plug power cable back in at the PS3 and then at the surge protector/power-strip (wall). Turn in on with the switch and then use the soft method (described above) on the front. That should fix it. If not, send it back for a warranty exchange. Good luck.
Mar 22, 2008 | Sony Playstation 3 (PS3) Console
PixiModo Reflection 15M 15-Inch Digital Picture Logo
69 people viewed this question
Top PixiModo Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a PixiModo Photography Expert? Answer questions, earn points and help others
