When I turn the tv on, after the fan starts to run right when the lamp is suppose to turn on, I hear a clicking sound. The sound stops and starts again, then tv will shut off and the lamp light will start to blink. I didn't try to turn on tv for a while with busy schedule and one day turned on and it made a knock when tried to turn lamp on and then one second try lamp came on and tv was playing perfectly. Next day initial problem again.
SOURCE: please help
That is the blink code for the lamp ballast. Here is the more complicated explanation from the service manual.
IC2301(pin11) detects the error of LCD Power C.B.A. and Lamp,
then indicates the error when an inner malfunction of LCD Power
C.B.A. occurs, the Lamp voltage becomes more than 130V or
less than 30V, Lamp current becomes more than 5A, or the Lamp is blown
Hope this helps.
SOURCE: Panasonic PT40LC12 turns on and then shuts off after 15 seconds
Ballast Board it what turns Lamp on Call Encompass Parts Distr. or Look on their website.
SOURCE: 5 yrs old, blinking green then red, replaced lamp 4 months ago
You very well could have problem with the Ballast board that powers Lamp or your Lamp Fan maybe defective and if you need orinagnal hand unit for set Call Encompass Parts Distrubtion or Go to their website type in Model number they will list Parts /Prices for your model.
1-800-638-3328 Mats Electronics also sells handunits .To reset timer
Hold VOL- on front of TV and Menu on hand unit at same time for 5secs
if this does not work try it in reverse Hold Menu down on TV and Vol- on hand unit. Check your Lamp Fan see if it quits running while turning set on,if it starts and stops it is defective, other wise Follow wires that Lamp plugs into it will connect to Ballast board that powers Lamp CK it Problem M/B Ballast Board.
SOURCE: NO PICTURE, NO SOUND, TV TURNS ON THEN TURNS OFF
STOP THE PRESS!! I FIXED MY TV for a whopping $26.
I took a wild shot and purchased two STK392-110 convergence amplifiers from http://www.electronix.com/. They ship fast, placed my order on Tuesday evening after coming here and placing my comment. To my suprise the parts were in my mailbox on Friday. The parts were actually $12 but I also picked up a iron and a solder sucker.
So rarewish4us, If you're in the South Florida area I'd be more than happy to take that "JUNK" off your hands. LOL
If I were you, I'd give it a shot before you junk it.
Good luck,
Howie
SOURCE: Green flashing power light and ticking noise but wont turn on
Did you touch the Lamp? If you did it may have blown. the color wheel may be the problem or yes the balist
