Question about NEC Multisync 1770VX-BK Monitor
White screen completely White screen when the monitor turns on
    Champion:
  • 219 Answers
Bad card
Posted on Nov 27, 2013
How do I Fix LCD White Screen?
If you see "fractured lines" across the screen, it would appear that your LCD screen is broken. That's the only way these kinds of lines appear.
You need to replace the screen.
May 14, 2012 | Computers & Internet
Hi, I have a Dell 23 in monitor. Everything was working fine but one day we turned it on and it's completely white. The whole screen is just white. Is it there a simple solution?
please remove the vga cable from the back of the monitor, make sure that you don't remove the power cable from the back of your monitor.
If you see the power on self test or any other pattern of colors in the screen, if the screen display remains white or goes black it would mean that the monitor has gone bad.
Hope it helps.
Thanks and Regards
Anand Sachan
Oct 25, 2010 | Computers & Internet
When I power on my computer my monitor screen goes a solid whitish gray. worked fine yesterday, and then today nothing.
Laptop LCD screen turned completely white
What can you do if the laptop LCD screen turned completely white? From my experience I can tell that this problem may be related to the following:
1. Loose connection between the video cable and the LCD screen.
2. Defective LCD screen.
3. Defective motherboard (I assume the graphics card is integrated into the motherboard).
When you turn on the laptop, it starts but the image on the screen is completely white right from the beginning.
Most likely you still can use the laptop with an external monitor. Just connect the monitor to the VGA port on the back or side of your laptop and then switch the video output from internal to external mode.
On Toshiba laptops you can toggle between internal and external screens using Fn+F5 keys. Hold down Fn and press on F5 until you get video on the external monitor.
On IBM laptops use Fn+F7.
On HP laptops use Fn+F4.
It’s possible that you have to use a different key combination on your laptop but you get the idea.
On some laptops, in order to be able to use the external monitor, you have to connect it to the laptop and then restart the laptop so the external monitor is detected by the laptop.
I noticed that in some cases the laptop screen may turn white because of poor connection between the video cable and the LCD screen. If you want to check this connection, you’ll have to take apart the display panel because the connector is located on the back side of the LCD screen.
I always check the video cable connection first. Reconnecting the video cable may fix your problem.
If reconnecting the video cable doesn’t help, most likely you have a problem either with the LCD screen or with the motherboard.
The best way to find out which one is causing the problem is testing the laptop with another working LCD screen. Without this test you’ll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You’ll have to disconnect the video cable from the LCD screen and the inverter board. After that you connect another working screen and test video.
The original screen is white but my test screen works normal and I can see the image. After this test I can tell that the problem must be related to the screen.
After I assembled everything back together and connected the original LCD, it’s still white.
CONCLUSION.
In my case this problem is related to the LCD screen and it has to be replaced.
Feb 01, 2010 | Computers & Internet
The display turn white >>>what can i do?
CONCLUSION.
Jan 18, 2010 | Samsung NC10-14GW Notebook
When I turn on the computer the screen is white but the computer is booting up.
CONCLUSION.
Jan 14, 2010 | Dell Studio 17 Laptop
My monitor turns white when i turn it on every
Your monitor is about to go out. It may be a faulty bulb if an older monitor or if a newer one which utilizes a plasma or lcd screen, the liquid crystals maybe going bad or the light source could be going bad as well. When LCD's or Plasmas start going bad, the best bet is to get a new one because to fix one is almost as expensive as purchasing a newer one.
Nov 16, 2009 | BenQ FP71E 17" LCD Monitor
I have a newish netbook and the screen turns completely white.
do not try to do anything by yourself at this point call samsung and it should be covered under the 1year warranty..
Sep 17, 2009 | BenQ FP71G 17" LCD Monitor
Lcd monitor 20.1
The white screen is caused by a total lack of control over all pixels. The opposite effect; all black, happens when a failure turns all pixels on, blocking all but a small amount of light.
This could have more than one source; one output of the power supply has failed so the logic section no longer is receiving supply voltage or an external source has damaged the video input of the monitor. The backlight responsible for the white screen is obviously working as this is a separate power supply output to an inverter that powers the backlight lamp.  I'm afraid this is not a DIY repair.
Sep 17, 2008 | Westinghouse Computers & Internet
Screen completely white
dont warry,u just replace your lcd.
Apr 27, 2008 | Dell Inspiron E1505 Notebook
One gets to open it up and find out where the signal from the computer is lay aside. Hunt up the model number on the inside of the monitor (the ODM part numbers) for the service manuals if you can use them. Otherwise you can call Gateway or look for a shop (sometimes even buy repair insurance coverage with the thing in that nonfunctional state.)
Mar 31, 2008 | Gateway FPD1760 17" LCD Monitor
Computers & Internet Logo
26 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
