Question about Konica Minolta bizhub 200 Printer
Used to be able to print from computer to copier after entering user code & password, tech told us to remove & reinstall all printers, now unable to print to Konika minolta copier
Since updating no longer have opportunity to enter user name, passcode yet it show job being sent to printer & printing yet nothing prints
  • 208 Answers
SOURCE: Copier won't print - IP address was switched?
That is your issue. If you allow it to set up using DHCP it will drop off often.
You need to set static IP addresses for the router and machine.
You have to have matching IP addresses, Gateways for it to communicate properly.
Set them permanently.
Posted on Dec 20, 2007
  • 3 Answers
SOURCE: Konica Minolta Magicolor 2400W -- Only Prints on Reboot!
I've had that problem before too, and found out that there were copies of the printer that had somehow installed themselves on my computer. All I needed to do was to choose to print with "konica minolta copy 1" instead of the one that I *thought* was installed and it worked. I then deleted the original printer and just stuck with the copy.
Posted on Aug 11, 2008
Kevin Hayes
  • 167 Answers
SOURCE: Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
Posted on Feb 17, 2009
  • 15 Answers
SOURCE: Konica Minolta C450 status is offline.
Change the status to "Online". Sounds crazy, but most likely you print driver is set to enable "SNMP" on the port settings. Disbale this setting in the print driver, also set print Queue to "LPR" and name the LPR queue as "printer". Make sure there are no jobs int he queue when you change the port settings.
Posted on Jun 09, 2009
  • 43 Answers
SOURCE: Printer won't print until I restart my computer.
After you have this problem again. Go to Control panel and look for administrative tools. Click on services and scroll down until you see the print spooler service.. Right click on this and select restart. Let me know if the printer then functions after this.
Posted on Jun 17, 2009
FUJI XEROX 016 757 ERROR CODE
Could be: The entered password is wrong or
Auditron security (A Xerox feature) is preventing users from Printing.
Then: Enter the correct password (Default 11111) or
Disable Auditron security settings from the Administrator menu.
Xerox Error Code 016 757 Tech on Tour
http://es.scribd.com/doc/21054313/Fault-Codes-Xerox
http://arts.ucalgary.ca/it/kb/221/xerox-printer-giving-016-757-error
Jun 25, 2014 | Dell 3100cn Laser Printer
Lexmark wireless printer won't connect with my router?
Lexmark provides a line of wireless printers and sometime printer won't print with wireless...so here is what you may have to do in order to get this fixed
1.make sure your wireless password is right
2. uninstall the printer software and reinstall it once again ( make sure you configure the router with wireless router) for more assistance contact with Lexmark Printer Tech Support
3. now type the right password and try to print it
i hope this may help you
Mar 05, 2012 | Lexmark Office Equipment & Supplies
The printer is connected via network, and i installed it on my pc normally, and when i print a file i get a notification that the file is printed normally, but nothing is received or printed on the...
Sounds to me like your copier has user authentication turned on. This means that the copier is looking for a user code whenever print jobs are received and since it is not getting it, it simply ignores the print job request. The print job will disappear from the PC's print que as well. I don't remember enough about the specific steps but you have to log into the administrator mode on the copier and turn user authentication off. Or if you have used authentication in the past then you need to enter the user code in the print job screen when you print. The default password for administrator is 12345678
Good Luck and Thank You for using Fixya.
Wheatland Services
Feb 08, 2011 | Konica Minolta bizhub C250 All-In-One...
How can i password my photocopier/printer? Please forward the manual/steps. i will be much grateful. thank you
look my friend enter to user manual through press beside cancel yellow like this sign (&) and go through adminstating authentication and will see put code for every thing printing and every proces yo made yo have authority to control on it
Jan 31, 2011 | Gestetner Office Equipment & Supplies
How do i password protect our copies?
you can protect your copier with user code protection just fallow theis steps 1. Press the User Tolls Button 2. Tuch the System Settings 3. Tuch the Keyoperator tools 4. Tuch the User code managment 5. make copier ON & tuch OK 6.Tuch Next and Tuch Addressbook Managment 7. Tuch new program 8. Tuch User Code 9. Enter the number your choise & Tuch the # 10. Tuch the function Eg. Copier & Tuch the OK and Exit the user tools - thanks
Oct 29, 2010 | Gestetner DSm745 Black and White Copier
I have a Canon immagerunner 22706. How do I bypass the user id and password to begin printing without entering the user id and password. Thank you
To be able to bypass the user id and password and start printing. You have to first uninstall the printer/hardware from the control panel of your computer.
Install the printer back, then while it is running it asks if you want to use a user id and password, do not accept the user id and password mode, select the option that does not require a user id and password.
After doing this, you will be able to print without user id and password.
Take care
Sep 13, 2010 | Office Equipment & Supplies
I have a Windows printer set up for the Ricoh 12332C. Jobs are sent and clear the queue, but do not print. They appear to be accepted by the Ricoh - they show in the job history log, but they do not print...
Usually the setting of yout network with your copier/printer setting is mismatched so your printer.copier did not understand. What you can do you should check the system setting of your copier/printer and print it out then you should find the driver of your printer/copier in the add printer hardware secrtion in control panel of your computer network . Before you reinstall it , you should uninstall the previous driver so there is no conflict when you reinstall new driver . Try it
Apr 17, 2010 | Ricoh Aficio 1232C Color Copier
Panasonic dpc322 enter identification code
1. Function key
2. General Settings
3 key operator mode #9
4 Enter Keyoperator mode password protected
5. selected user authcentication Number (75)
6 select Copy/fax/print/scan
7 select on for auth or off no auth
Jul 20, 2009 | Panasonic Office Equipment & Supplies
Password to avoid the unauthorized Use
press the exposure light button for 5 sec n after that the indications wiil apear n on the display there will b 2 dashes blinking so u input 10 n press stars after that the no wiil blink 100 so u have to make 101 by pressing start then press c n then input 11 start n when 3 dashes blink input ur code only 3 digit n press start n press the expossure botton n cm out if there is any prblm call me on 9923483607
Jan 31, 2009 | Sharp AR-5320 Black and White Copier
Konica Minolta bizhub 200 Printer Logo
11 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
