Question about Apple iPod MA446LL/A MP3 Player
Itouch is frozen on white screen & wont turn off
I was playing a game on my itouch, and noticed i couldn't get to the home screen no matter how many times i pressed the home button. The itouch wouldn't turn off so i tried just turning the screen off by pressing the top button. When i did this and then tried to turn it back on, the screen was white. I can't turn it off or get away from the white screen!
  • 61 Answers
Try doing a hard reset: hold the hard buttons for 20 seconds.
Heres a video to see for example.
http://www.youtube.com/watch?v=BuBWoZ0-gNM
Posted on May 06, 2009
Don't recharge the i pod . Put the i pod this situation till power off. If power is off, you can turn on your i pod. If power is no left, you should charge and then on.
Posted on Jul 11, 2009
SOURCE:
Itouch speaker playing while headphones are connected.
1> Disconnect the ear buds from the itouch
2> Reset the ipod - by holding down the sleep wake button and the home button at the same time until you see the apple logo - the ipod will reboot
3> reconnect ear buds mace sure they are flush with the top of the unit ( no gaps )
play a song to test
**If it is still playing out of both - call apple for repair or go to apple store
May 10, 2010 | Apple iPod touch
Tip
How do I make my iTouch Louder
<p>He the volume of the iPod Touch can be affected in some way, the definition of musical sound check the volume limit set in the settings device preferences. The tool of sound check, which can also be found on iTunes, check your iTouch music and video library for the stabilization of the equalizer song for a constant level, the volume limit reduces the volume to grow beyond a set point, which helps the potential adverse effects of hearing loss caused by loud music. <br /> <p><br /> <p>1. Press the button to the left of the iPod Touch. The volume switch top left of the iPod Touch increases the sound volume, and gives a volume icon on the screen as it grows. Accident on the volume button for the iTouch, it seemed sound problems. Touch the "Music" icon to start playing the song, press the volume for music to grow. <br /> <p><br /> <p>2. Adjust the volume control settings. Tap Settings on the iPod screen Touch, Touch "Music" and tap "volume limit." Slide the tab to the right of way to reduce the volume bar to change the limit of the maximum. Press the Home button to save and Settings. <br /> <p><br /> <p>3. Sound Check off. Tap "Music" in the Settings window and slide the guide Sound Check to the left to the sound check feature off. A Sound check song keeps playing very hard at the same level. While the function prevents sudden jumps in volume, can also lead to a series of songs to play very soft, depending on the quality of the music. <br /> <p><br /> <p>4. Adjust the volume to your headphones. Press the "+" button on your Apple headphones, the volume of a music or video playback to increase. If a song or video does not play, the volume control adjusts the volume on the iTouch. <br />
on Aug 05, 2011 | Computers & Internet
I got a itouch today and the person that i got the itouch from forgot the password and i cant unlock my itouch.
Put the iPod into DFU mode. It will wipe everything off your iPod but it will at least make sure you can get into it.
  1. Locate the Home and Power buttons on your iDevice. The Home button
    is the round button below the screen; the Power button is the
    rectangular button located on top of your iDevice.
  2. Plug your iDevice into your computer
  3. If you can’t count well in you head, look at a clock that displays
    the seconds because the timing of these steps is very important.
  4. Press and hold the Home and Power buttons for 10 seconds. The screen should cut off at around 8 seconds
  5. While still holding the Home button, release the Power button.
  6. Continue holding the home button for about 15 seconds.
  7. The screen will remain off and the iDevice will look unchanged,
    but, if you’re on Windows, you will hear the connected hardware sound;
    if your on a Mac, iTunes will open and tell you that your iDevice is connected in “Recovery” mode.
May 06, 2010 | AccessData Password Recovery Tool Kit (ftk...
Itouch conect problem
jus go through the previous posts and you will find the solution...anyways here it is:
  1. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPod touch to turn off.
  2. Press and hold the Home button while reconnecting the USB cable to iPod. When you reconnect the USB to iPod, the device should then power on.
  3. Continue holding the Home button while iPod starts up. While starting up, you will see the Apple logo.
  4. When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message:
  5. Restore and it'll download ~240mb firmware and you're done
Aug 31, 2009 | Apple iPod touch
ITouch stuck on screen with pic of USB pointing to ITunes logo
is it brand new??
if so then connect it to itunes
Jul 07, 2009 | Apple iPod touch
ITouch Just Cant Go Back To Home Screen
Press both the the on/off button and the selector button at the same time. that will reset you itouch..
then I'd avoid that website.
K
Jun 07, 2009 | Itronix Duo-Touch IX325 Tablet PC
Dark screen even after setting is at its brightest. Just happened mid game.
did you try restarting it?
hold down the home button and the button at the top until it restarts
May 15, 2009 | Apple iPod touch
Problem with PSP "home" button
Hiya i have that same issue. when i watched my hands intensely i found that i actually do tap the button accidently and dont notice it if im too involved in a game if you make sure your left hand steers clear of the 'home' button im sure you will notice a difference
Jan 16, 2009 | Sony PlayStation Portable (PSP) Console
Itouch black screen and wont turn on
I had the same problem. I pressed the power button and the home button at the same time for about 10 seconds and then the home page showed up.
Aug 05, 2008 | Audio Players & Recorders
Psp
i had the same problom but i noticed i was geting distracted by the game and i had my left thumb on the home button pay atention to wat you press
May 28, 2008 | Sony PlayStation Portable (PSP) Console
Apple iPod MA446LL/A MP3 Player Logo
338 people viewed this question
Top Apple Audio Players & Recorders Experts
Parshiv Luthra
Marvin
Marvin
Will Mishler
Will Mishler
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
