Question about Kenmore 75180 Wall/Window Air Conditioner
Kenmore 18,000 btu Air Conditioner model # 75180 - Condensor Problem
My AC's condensor doesn't kick on when I lower the temp control down into the 60's and the unit begins blowing hot air. Please help.
Posted on Oct 20, 2008
  • Kenmore Master
  • 4,655 Answers
The problem could be many things bad temp.control, burnd out compressor, burrned or loose connection on the internal wires. It also could be the age of th AC
Posted on Oct 20, 2007
How doest it drain on air conditioner 25379081
most window units use the condensation to help cool the condensor. some days little to any drainage. a slinger ring on outsde blade side throws water on coil and evaporates.
Jun 29, 2014 | Kenmore 8,000 Btu Room Air Conditioner...
My ac is acting funky. my ac will blow cold air as im moving. once i stop and idle for longer than 3 or 4 minutes, something will kick on and then it will start to blow hot air. as this happens, my car...
Start by checking to make sure that the a/c condensor and radiator is not full off debris. If the condensor and radiator were full of debris it will limit the air flow from the engine cooling fan which in tern will cause a high discharge pressure on the discharge on the a/c causing poor or no cooling at idle and could also cause vehicle to overheat. Check and make sure that the cooling fan as well as the condensor fan are coming on together when the a/c is turned on if equipped with 2 fans.
Sep 12, 2013 | 2004 Chevrolet Cavalier
Brand new kenmore air conditioner 18500 btu, there is no place for the water to drain, no drain plug? water is getting high... model 70181
The new Room A/C's do not have drains as it uses the condisation from the pan to help cool the coils this makes the unit more effecient.
Sep 01, 2011 | Kenmore Room Air Conditioner
My goldstar 6000 btu window ac is dripping into the house
Sounds like you're using it when the outside temp is cooler than the inside temp. when this happens, frost will build up on the condensor. Turn the unit off until the ice melts off with a shim under the unit tilting it back towards the outside of the window to drain. If it continues to drip after melting all the ice off and letting it dry out, you have a small leak in the condensor, (unit must be old or worn out) that the freon pressure has leaked out causing it to condensate more. A good checklist would be to check the level of the unit, make sure the coils are clean and not bent, the age of the unit and for small areas of corrosion or white marks on the condensor before replacing it.
Aug 28, 2011 | Goldstar KG6000R Window Air Conditioner
Rv ac throws the breaker when outside temp gets high, unit works fine at night when outside temp cools down
Clean evap and cond coils
Place hand on a/c if too hot during the day but cool at night
then freon is being restricted in the condensor
Cleaning coils may help days
Put a trickle of water on the condensor during the day for a test.
.If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
Aug 07, 2010 | Dometic Rooftop RV Air Conditioner
My car keeps getting almost to the red in the temp gauge and the thermostat was already replaced I dont know what else to do
Most common problem is debris build up on the radiator front, or debris build up on the AC condensor causing no or little air flow through the radiator and AC condensor. The radiator and AC condensor must have good air flow to keep everything cool, debris on the AC condensor will cause your AC temp to be high even with a proper AC charge. If there is no debris on the radiator or AC condensor and there is no white smoke coming out of the tailpipe and no loss of coolant, I would suspect a stopped up radiator on the inside or a bad water pump, good luck, Gary
Jul 22, 2010 | Cars & Trucks
My lg wall unit (LWHD1009R) 10,000 btu the compressor keeps turning off after it gets going. even though I have it on a low temp. the comressor turns off after 5-10 minutes even though the room is not cold
either going off on low charge which would cause it to ice up, which means you need refrigerant. or high head pressure might just have to clean the coils or check condensor fan.
May 05, 2010 | LG Art Cool LA121CNP wall/window Air...
It making a humming sound and the fan is going around slow the temp in home is 74 the set temp is 65 so it should not be running what could be the problem ruud upka-035jak is model
If you are running A.C.,and the T-stat is set at 65,and the room temp is 74,the A.C. will run until the temp goes down to about 65 or so.Turn T-stat to 76 and the unit should shut down. Also,check furnace filter for dirt, and check condensor unit coils and see if they are dirty.If condensor coil is dirty it cannot breathe properly. That will cause the compressor, and the blower motor to overheat.Wash cond. coil down with water hose to clean .Start at top of coil and go sideways,slowly going down.
Feb 23, 2010 | Ruud Matching Split Air Conditioner
Ac unit freezing up
Either the coil is clogged, the fan is slow, or the freon is low... A solved rating is great motivation to continue giving priceless advise........
Oct 03, 2007 | Samsung AW0603B Air Conditioner
Kenmore 75180 Wall/Window Air Conditioner Logo
921 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
