Question about Ovens
How to bleed stanley super star oil cooker - Ovens
Ran out of oil, when refilled managed to get heating working but oven not
How to bleed and restart your oil heating. - Instructables
www.instructables.com/.../How-to-bleed-and-restart-your-oil...
InstructablesGo to the oil tank and make sure there's oil in it, or you'll be wasting your time. ... you to get lucky but it has happened to me and it seems to help get the fuel moving a ... I am thinking the boiler is not working so do not want to spend money buying lots of ... Bleeding brilliant - now the wife doesn't have to know we ran out of oil!Missing: oven
how to mend it .com - Clearing airlock from riello oil burner?
www.howtomendit.com > Heating, Oil Filled Radiators
The temp knob on my bosch oven has stopped working. ? Search: Go ... I've now replensihed the oil but the system keeps cutting out after a few moments trying to ignite the oil. ... With guests arriving to rent my house yesterday, I ran out if fuel,refilled and ... Have now managed to restore heating and hot water to my house.
My Craftsman lawn mower wont start after it ran out of gas ...
www.shopyourway.com > Manage My Life > Questions
Dec 21, 2015 | Ovens
Stanley cooker trips when heating comes on. Clock not working
heater has the highst possiblity that causing the tripping of unit .check also before calling ur tech maybe ur MCB tipping due to evrload of
Feb 22, 2015 | Ovens
I have a stanley brandon 80k oil range style cooker. The Hot water and oven work fine but the heating intermittently does not work when either set to come on via the timer or via pushing the override...
Sounds like you have a valve sticking or a safety switch causing it to shut down. Does this unit exhaust first then the burner ignites that might be your issue
Jan 09, 2015 | Ovens
Replacing a function selector knob
They are very easy to replace. All I need to do to replace it is, pull it off. You can use a blunt object such as a butter knife to help you lever it off if you're having trouble.
Then, get your new one and it'll only go one way so make sure its facing the right way, and push it on! Here is a short video for demonstrating how to do it.
http://www.espares.co.uk/advice/cookers-and-hobs/a/1/1336/how-to-replace-the-control-knob-on-a-neff-ove.html
Let me know if you need anything else.
Benjamin
Nov 04, 2010 | Neff B1641 Single circotherm super...
Apart from the main supply to the cooker terminals
So long as the earth is connected to the earth terminal, then there is no prob for you to worry about.
The normal twin and earth cable is adequate.
Please rate my comments.
Thankyou..
Mar 05, 2009 | Neff U1661 Double circotherm super...
Installing a B1641 oven
Providing it is just a single fan oven on it's own. then it will work fine from a normal 13 amp socket.
If it is a double oven, then it will have to be hard wired into a cooker control switch box, protected with a 30amp circuit trip or fuse.
Please rate my solution to your query.
Thanks.
Feb 19, 2009 | Neff B1641 Single circotherm super...
Electric oven & grill not working no digital clock display
If there is a display on the clock and you cannot reset it to manual, then the oven will not work, if you cannot reset then you will probably need a new timer fitting.
They can be bypassed, but not recommended unless you know what you are doing..
If there is no display at all , then check to make sure you have supply to oven
Plz rate my solution.
Thanks.
Dec 16, 2008 | Neff U1661 Double circotherm super...
Oven has 4 conductor power cable, moved to house with 3 conductor
Unless your cooker is totally different to the norm, then yes you can use 3 core cable. assuming you are in the u/k, then the following applys.Brown is live-Blue is neutral, andGreen/Yellow is earth.
Depending on the total wattage of the cooker, you will need to use a min of 6mm twin and earth cable, If in any doubt, consult an electrician
Please leave feeedback
Dec 03, 2008 | Whirlpool RBD305PD Electric Double Oven
Ovens Logo
91 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
