Question about Plumb Pak Actuating Lift Chain Fits American Standard PP830-46L
Picture of how to install plumb pak lift chain?
Toilet flapper doesn't stay up unless handle is held down until tank empties.
If the flapper won't stay up, you may be lifting it too high - you want to retain a little air inside it when it's lifted. Try adjusting it to a lower lift height.
Jan 12, 2014 | Plumb Pak Plumbing
How do u take coils out of burner from a landa pressure washer
If you are talking about the water coil for the burner it will depend on the specific model of the washer, however it is a similar procedure amongst all our washers. For horizontal coil machines you first need to remove the bolts securing the top wrap, then fold back the fiberglass insulation to reveal the coil. Next un-hook all plumbing from the inlet and outlet of the coil. Now if you look at the top of the coil you will see a threaded hole in the center. You can secure a chain to this with a 3/8 bolt and washer in order to help you lift it out.
For a vertical coil you will need to remove top cover from the burner wrap. Next un-hook all plumbing from the inlet and outlet. Now secure a chain to the top of the coil and lift it slowly from the wrap.
If you have any other questions please feel free to contact me using the information below.
Sincerely,
Aron Kerr
Landa Northwest
800.247.8103
503.255.6508
www.landanw.com
Feb 01, 2011 | Heating & Cooling
Need to tighten chain
Hi, first you need to use some pressurized air to blow out all of the debris from the attachment points of the bar. Then, loosen the retaining bolts for the bar . Find the tensioner screw beside the bar. You can spot this screw by looking at the saw head-on. Next, turn the tensioner screw clockwise until you can only lift the chain a quarter inch from the bar. Afterwards tighten the retaining nuts, but do not over tighten! Hope this helps.
Nov 16, 2010 | Homelite 33cc 38cc 45cc Chainsaw Oil Pump...
How can I remove the locknut and washer to install a handle?
A pump pliers is the best way but remember that the thread is left hand turning... opposite of normal...
heatman101
Sep 03, 2010 | Plumb Pak Home
Installing lift station. have 30 gal sump bucket
Depending on local codes, you may need to vent a 2" line separately out the roof. Otherwise, you may tie this vent into the other house vent line, but it should be a 2" vent conected to another 2" vent line. Again, you will have to check local codes. The drain connection should be made with a 2" connection into the top of a 4x2" wye 10' from any other connection. This follows most plumbing ordinances.
Nov 10, 2009 | Plumbing
Installing a new waste outlet hose
You will have to remove the outer shell to access the pump.
Remove the clamp from the outlet side.
Install is the reverse.
Thanks
May 15, 2009 | Plumb Pak Continuous Waste Center Outlet,...
Plumb Pak Corporation Twist & Lock sink drain will not drain
The small disk right under the strainer is adjustable and has a lock nut. You will need to try and adjust this. If it doesn't work, the I would sugest replaceing them. They aren't that expensive plus they are easy to replace. Good luck!
Apr 09, 2009 | Plumbing
Sherwood industrial dishwasher parts I need a waste pipe
The part you need is a common part sold at most all hardware stores, lowes, home depot, or plumbing supply stores.
Mar 11, 2009 | Plumb Pak Waste & Overflow Pipe Kit, 1...
Nintendo 64 console
Too many variables to answer this yet. Where did the expansion pak come from? Was it new or used? Was a jumper pak in place and the console working before you installed the expansion pak? Did you unplug the console before removing the jumper pak and installing the expansion pak?
Dec 02, 2007 | Nintendo 64 Console
Plumb Pak Actuating Lift Chain Fits American Standard PP830-46L Logo
126 people viewed this question
Top Plumb Pak Home Experts
Donni Steen
Tom Chichester
Are you a Plumb Pak Home Expert? Answer questions, earn points and help others
