Question about Haier ESAD4066 Split System Air Conditioner
How to set hair thermocool ac to cooling - Haier ESAD4066 Split System Air Conditioner
I punctured a hole in my ac unit and Freon came out what to do this ac unit is a unit for apartment house upstairs and down stairs
Call a refrigeration company, tell them you put a hole in the unit. They will solder it and refill with gas.
Number one tip, don't use pointy objects. Hair dryer, heat gun, or hot water, plastic scraper.
Apr 20, 2018 | Heating & Cooling
What's best way to insulate a house
Best insulation is by making thermocool ceiling. Next easiest thing is put curtain to all windows. Avoid dumping unused materials inside the ac room as it also produces some heat. Tnq
Sep 03, 2015 | Heating & Cooling
My ac unit doesn't blow out cold air but everything else works do you know what the problem could be,it's a standup one
Probably needs a recharge... should be able to get the kits at a hardware store..... unless it was. Blowing cool when you started it and then it quit a few hours later... if that is the case place it in the bath tub and let the ice from moisture build up ( around the cooling coils high humidity will cause water to form freeze and layer up until it renders the ac useless until completely thawed... takes about 2 hrs... lots of water may run out as it thaws, that is why I suggested the tub... ps. This will happen to every ac and is not a big deal just a pain... and no don't use a hair dryer on it or warm water unless you don't like your ac... just time.
Jun 22, 2015 | AC Cars & Trucks
What are some correct blow-drying techniques?
to smooth hair while still creating volume blow out hair with a round ceramic brush. Roll hair around the brush, hit with hot air setting for few seconds, and then let cool before removing the brush. Continue working in sections until hair is dry, bouncy and smooth
Oct 08, 2013 | Sexy Hair Health & Beauty
When do you use the cool setting on a blow dryer?
Use cool air when you've finished blow drying your hair or doing anything else to your hair with hot air. When you blow cool air afterwards, it helps keep the style.
Jan 10, 2013 | Health & Beauty
Indoor ac coils have ice build up and not cooling the house. can i melt it away with a hair dryer?
I have found that hot water cuts the ice better, my question to you, is why is the coil ice up?
Setting the temp to low below 72 degrees, a dirty air filter or coil, closed vents, I always have to ask is the outdoor coil clean?
Jul 12, 2011 | Heating & Cooling
Ac does not put out very much cool air nor volume. Coolant has been charged.
The problem isn't with the ac , it's with the blower fan - apparently it only works on the lowest speed. Check the fan button and the wiring from it to the fan.
Jun 26, 2010 | 2000 Toyota Celica
Sharp Air Conditioner. Model # AF-S85NX. Does this A.C. fan cycle on & off in the auto cool mode or does remain on continuously. I need a small A.C. that cycles off and on with the compressor.
If you set you r AC to FAN mode the unit will not cool, it only runs in the indoor but the outdoor will off. If you set to AUTO the unit will cool but the indoor blower will automatically run slower when the room is cool or attain the room temp. setting. If you set it to COOL the fan speed is fix depending on your setting and it also operate in cool.
Apr 19, 2008 | Heating & Cooling
Problem with cooling of HAIER HVT12ABS
not to much experience with tecs, but a tec has a hot and cold side so turn the tec around and that should solve your problem and also some good thermal paste should be used on the hot side. good luck and let me know how you got on.
Feb 22, 2008 | Haier HVT12ABS Compact Wine Cooler
Haier ESAD4066 Split System Air Conditioner Logo
18 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
