Question about Teac GF-350 CD Shelf System
Error 04 no graba de pohno a cd
Error #04-002 in samsung scx 4623fn
mi impresora se bloquea a penas doy la opcion de imprimir funciona y cuando supuestamente va a coger la hoja queda bloqueda ssale q es error #04-002 no se q hacerl ya le revise y no tiene atasco de hojas ni nada q debo hacer si solo dece q la apague y la vuelva a prender pero no funciona
Jan 29, 2013 | Samsung SCX-4216F All-In-One Laser Printer
Primero mi lectora Lite-on LH18A1P no leia dvd asi q la desarme y le gire un cuarto de vuelta hacia la izquierda el tornillito de calibracion de dvd. ahora los lee perfectamente, pero no graba dvd, cual...
you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver roll back driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options update driver roll back driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs Click Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
May 01, 2011 | Lite On LH-18A1P DVD RW Dual Layer Burner
NO GRABA Y NO REPRODUCE EN BANDEJA B
Use SONY Digital Audio MUSIC CD-R's only with this machine to record. Okay?
Jan 18, 2011 | RCA CDRW121 2-Disc CD Recorder
Hellow! I need to make a questions in spanish. Mi mp3 graba en archivos .act. cuando los paso a la PC no los puedo escuchar. Solo puedo hacerlo en el dispositivo. Como pueo escucharlos en la PC?? Muchas...
Hola gracias por usar fixya.com
Si no puedes escuchar los archivos de mp3 en tu computadoras es porque te falta el player. Hay muchos players gratias como windows media playar or itunes. Para bajarlo ve a www.itunes.com
Gracias
May 21, 2010 | Clarion DB365USB CD/MP3 Player w/USB
HL-DT-ST DVD-RAM GSA-H55N cannot detect dvd disc
I have same DVD writer and I am facing the same problem. During R&D for such failure on google I came to know there are two different Laser Diodes for CD and DVD. CD read write is working for me. I think DVD r-w laser has some problems. I am currently looking for options to get the new laser diode. As soon I replace the diode and see my DVD writer working. I will upload the video to replace the diode for you all.
Dec 26, 2009 | LG GSA-H55N DVD-RAM Burner
Need users instruction manual for a Sony HCD-XB200 CD Mini System
Tengo un Equipo Sony LBT-xb200 que traje de España a Lima Peru pero tengo el problema que desde que lo traje aqui esta fallando el sintonizador de radio y el sistema de grabacion de cassetes graba con un volumen muy bajo
Nov 03, 2009 | Sony Audio Players & Recorders
Que significa el error 0X4001100200001005 en una restauracion de
Acabo de recibir el mismo mensaje de error en mitad de una restauracion de pc. La solucion en mi caso:
1) Desonectar el cable de alimentacion y encender el pc para que se descargue de toda corriente, volver a conectar la alimentacion.
2) Limpiar el CD de restauracion (con el CD sucio no lee y da error) e introducirlo en la bandeja CD/DVD
3) Encender el pc y enseguida oprimir F12 para que arranque con CD/DVD
4) Esperar que eso lo solucione
Jul 06, 2009 | E-Machines (T2958) PC Desktop
Power light blinking orange/yellow. does not mount or recognise
IN SPANISH...USE TRADUCTOR OR TRANSLATE.... TRATA DE USAR UN SOFTWARE LLAMADO PARTITION MAGIC DESDE LA SE?AL C: O SEA BAJO DOS.... PERO ANTES CONTESTAME TU BOOT O SOFTWARE DE INICIO RECONOCE EL DISCO DURO?... SI NO LO HACE O ES UNA DA?O LOGICO O SEA DE LA TARJETA DEL DISCO DURO, O FISICO, DEL DISCO EN SI, LO CUAL EXPLICARIA EL RUIDO.... HAY EN INTERNET SOFTWARE FREE.... PARA DIAGNOSTICO Y HASTA REPARACION... UNO DE LOS MEJORES SE LLAMA HIRENĀ“S BOOT CD Y SE BAJA COMO UN ISO Y LUEGO LO GRABAS EN UN CD LUEGO HACES BOOT CON EL Y CORRES EL SOFTWARE QUE QUIERAS, INCLUYENDO EL PARTITION MAGIC, ESPERO QUE TENGAS SUERTE. SI PUEDO SERTE DE MAS AYUDA TENDRIAS QUE SER UN POCO MAS ESPECIFICO. HAY OTRO SOFTWARE BAJO LINUX LLAMADO KANOPPIX Y EL EN OCASIONES RECONOCE LO QUE OTROS SISTEMAS OPERATIVOS NO HACEN.... ASI POR LO MENOS RECUPERARIAS TU INFORMACION Y SI ESTAS DE BUENAS LO FORMATEAS DE NUEVO Y RECUPERAS TU DISCO. ESTE TAMBIEN LO CONSIGUES EN INTERNET Y ES FREE.
Jan 14, 2007 | LaCie (300728U) 250 GB Hard Drive
Open Questions:
Formatting a blank CD-R to an audio CD to be used in an Hi-fi CD copier Would you know of a share or freeware available, to format a blank CD-R(ecordable) into an audio CD ? To be more explicit, we can find two types of blank recordable CD on the market : audio and data. Only audio CD's can be used in an Hi-Fi CD recorder, while both can be read and recorded from a computer. Apparently, both differ only by the way they are formatted. I was wondering if there is a freeware available to format data recordable CD to audio's. Just a hint : with my CD recorder device, I got two software from Adaptec to create data and audio CD's. The problem when I create an audio CD using this software, is that it requires to copy on it at least one sound file, I cannot make an empty one Any hints ? Thanks and best regards Marc B. (France) Tried to burn to a Philips CD-R blank, which by the way there are four icons on the packaging, one of which is music notes presumably indicating audio, the others are a game controller, a camera, and a movie "clapper". The TEAC does not recognize the blank as an audio CD and so will not burn to it... The topic "Formatting a blank CD-R to an audio CD to be used..." was very informative and at the same time really ticked me off upon reading: "... only those 'audio-cdr' will work in hi-fi recorders. This was part of a deal cut with the record companies when the CD-R recorder first came out. Basically the extra cost of the audio-cdr goes to the record companies as royalties! That means that every one of us has been tried and convicted of pirating audio cd's and we all pay the royalties to compensate. And record companies wonder why they are so hated!" INDEED! At any rate, am I missing something re: the blank Philips CD-R's with the audio icon on the packaging. Does it NOT indicate that they are audio capable? Or what? If someone comes up with a way to format this type of blank for audio they will be highly revered and due many thanx from all of us!
Feb 27, 2017 | Teac GF-350 CD Shelf System
See all Teac GF-350 CD Shelf System Questions
Teac GF-350 CD Shelf System Logo
57 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
