Question about Bugera 1960 Infinium 150 Watt Guitar Amplifier Head
Bugera 1960 infinium fuse
I need to know where I can find a replacement fuse for my amp. I know why it busted, got it taken care of. I just need to know how I can replace it.
Bugera v5
This is a common problem with Bugera. And, unfortunately they are made by Behringer who is known to have the worst customer service of all and do not follow through on their warranties.
Apr 22, 2014 | Music
Broken input
The Bugera 6262 takes a standard 1/4" jack -- readily found online, music stores, or even Radio Shack. If you can solder, this is a basic fix, but will require that you pull apart the amp a bit. If you don't feel comfortable doing that, then I would suggest sending it in for repair. Try finding someone local to do this, rather than shipping it to the Behringer repair center. Best of luck!
Apr 04, 2014 | Behringer Bugera 6262 212
Blinking standby light no power
When you turn the amp on, does all the tubes light up? please add more info to help you out.
Oct 07, 2013 | Bugera 333XL Infinium 120 w 3 Channel...
My new Bugera 333 212 combo has a weird "ringing" noise on the crunch channel. The noise can be heard on other channels too, but it is loudest on crunch. The noise is clearly mechanical, (it...
Microphonic tubes can be detected by tapping them lightly with a pencil. I cannot find if this uses a spring reverb, but if it does, vibrating the cabinet will get a clanky type sound from the reverb tank. This MAY use a digital reverb however which is immune to that. Next thing is to make sure your guitar can't "hear" the output sound of the amp because the strings can pick up the sound and resonate feeding back into the amp. You can detect if this is happening by quickly dampening the strings and see if ringing gooes away. You probably need 6 to 10 feet of clearance between the guitar and the amp OR put your body between the amp and the guitar. ALWAYS set sound level at safe levels. Get a sound meter and go no higher than 90 Db. I know a lot of near deaf musicians whose careers are near over because of hearing loss using too high level.
May 24, 2011 | Behringer Bugera 333212 120W 3 Channel...
I need the schematic for my vt series model-212 deuce, serial number 9 A-379 90
Here you go... the parts list is at the front.
http://elektrotanya.com/peavey_valveking_100_212.pdf/download.html
Scroll down to "Get Manual" at the site and click on it to download the manual.
May 05, 2011 | Peavey ValveKing 100w All Tube 212 Combo...
Hi , i have a Bugera 1960 and my problem is send-return...when i put my boss ge-7 equalizer in it i can t hear the fx and this is the same thing for my delay pedal...i can hear but realy realy little...
The problem is the BOSS is designed to handle a guitar level at -20Db and the effects level is designed to run at either -10 Db or +4 Db. You will get better match setting the Bugerra effects to the -10 setting on the back and reducing the level... HOWEVER the pedal will want to send -20Db out which is 10 Db under what the effects return wants to see. This is a factor of three roughly in gain so the signal will be low. This is the problem using a guitar pedal in a way it wasn't designed to be used. The effects loops are looking for "line level" NOT guitar levels.
Schematics aren't going to help. The normal thing is to connect your guitar to the pedal and send the output of the pedal to the amp.
Guess what? The same things apply to your delay pedal... they are intended to accept the signal from the guitar OR the guitar like level from another pedal such as the GE7.
Mar 17, 2011 | Behringer Bugera 1960 Classic 150-Watt...
I bought a 1960 bugera head for 100 dollars that I knew was inop. Before I take it to a tech does anyone know what might be wrong? The fuse is good, and the power tubes light up, the amp turns on but no...
Tubes lighting does NOT mean they are working... AND some have two heaters because they are two tubes in one... so you have to verify the small ones have two heaters working... that is a starting point. Next tests involve a bit of electronics test equipment, namely a multimeter to check the poower supply is working. There are lethal voltages in this unit so find someone with experience to do these checks for you.
Jan 30, 2011 | Behringer Bugera 1960 Classic 150-Watt...
Bugera 1960A - channel 2 has very low volume even when vol2 knob is turned fully UP!
The user manual is located at: http://www.bugera-amps.com/PDF/Downloads/1960_P0671_M_EN.pdf on page 5; When the HIGH 1 and LOW 1 (or HIGH 2 and LOW 2) connectors are used simultaneously, their sensitivity is the same (both LOW). This may be your problem however--- Try swapping input chanels to see if the problem follows ther cable or is in the amp.
Assuming it was working before, you may have a short in the cable or a bad component or tube in the amp. Tubes can be difficult to come by. If the other channel works correctly, It may be one of the small tubes. Hope this helps
Jan 04, 2011 | Behringer Bugera 1960 Classic 150-Watt...
My Bugera 1960 stopped working in the middle of a rehearsal. I was playing at about level 3/4 in the 1st input of the 2nd channel. The amp was connected to a Marshall 4x10 bass cabinet. The connection of...
Wiring harness connector to the power tube section is fried. A common problem with all bugera amps and many other companies also. A cheap fix. You can order the part you need from newark.com or call 1-800-4newark the part number is sku#85c0290 mfr#09-91-0500
Nov 25, 2010 | Behringer Bugera 1960 Classic 150-Watt...
Need Schematices
Try posting on some of the guitar forums. The schematics you are looking for are only available to licensed repair persons but you might get lucky and find someone who will send them to you. Be sure to state what model amplifier you want. If you are a tech try looking at some schematics for a similar amp and tracing the circuit.
Jan 21, 2010 | Music
Bugera 1960 Infinium 150 Watt Guitar Amplifier Head Logo
51 people viewed this question
Top Bugera Music Experts
Vito Vacirca Jr.
Are you a Bugera Music Expert? Answer questions, earn points and help others
